Civic101 6th Gear April 25, 2013 Share April 25, 2013 Tried Caltex 98 recently compared to SPC Levo 95, feels that the gear shifting is smoother. ↡ Advertisement Link to post Share on other sites More sharing options...
Juliagezm1 Neutral Newbie April 25, 2013 Share April 25, 2013 It will solve the problem.. Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 25, 2013 Share April 25, 2013 Tried Caltex 98 recently compared to SPC Levo 95, feels that the gear shifting is smoother. What got petrol do with gear shifting.??? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 25, 2013 Share April 25, 2013 At what ratio u add 2T to petrol? Did all these cars hv a cat? When 2T is added to car, its usually at very low ratio. I have tried from 1:1000 ratio, all the way to 1:500 ratio. Compare to 2T bike that uses 1:25 to 1:50, thats a very small amount. Ive been using it for years and doesnt cause any problem to my Vios. Try to look for such topic in BITOGS and you will find many car owner doing the same thing... The effect is very obvious, the engine will become smoother and quieter... some claim that the FC improved but for me, if improved FC is not really significant. Link to post Share on other sites More sharing options...
Civic101 6th Gear April 25, 2013 Share April 25, 2013 Not sure, but I feel that the automatic gear up-shift during acceleration is smoother than before. Link to post Share on other sites More sharing options...
Solar Turbocharged April 25, 2013 Share April 25, 2013 When 2T is added to car, its usually at very low ratio. I have tried from 1:1000 ratio, all the way to 1:500 ratio. Compare to 2T bike that uses 1:25 to 1:50, thats a very small amount. Ive been using it for years and doesnt cause any problem to my Vios. Try to look for such topic in BITOGS and you will find many car owner doing the same thing... The effect is very obvious, the engine will become smoother and quieter... some claim that the FC improved but for me, if improved FC is not really significant. +1. same observation. smoother n quieter. fc negligible. Link to post Share on other sites More sharing options...
Proton 1st Gear April 25, 2013 Share April 25, 2013 My Daihatsu Sirion 1.3 has min RON of 91. Always been pumping 95RON until recently, pumped 2 tankfuls of 92RON discovered some sluggishness whenaccelerating and mileage dropped by about 1km per litre. My friend who drives a petrol driven Toyota Hiace school bus also told me he pumped 95RON due to lack of power for 92RON. is this true, or must engine timing be retard for it to accept 92RON? Wan power?get a turbo car.. Link to post Share on other sites More sharing options...
Proton 1st Gear April 25, 2013 Share April 25, 2013 When 2T is added to car, its usually at very low ratio. I have tried from 1:1000 ratio, all the way to 1:500 ratio. Compare to 2T bike that uses 1:25 to 1:50, thats a very small amount. Ive been using it for years and doesnt cause any problem to my Vios. Try to look for such topic in BITOGS and you will find many car owner doing the same thing... The effect is very obvious, the engine will become smoother and quieter... some claim that the FC improved but for me, if improved FC is not really significant. Wad is tat snake oil? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 25, 2013 Share April 25, 2013 Wad is tat snake oil? its lubricant for 2 cycle engine, mainly use n motobike. Just like our engine oil but its design to be burn. Use it on 4 cycle engine as upper cylinder lubricant to make your engine smoother n quieter. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 26, 2013 Share April 26, 2013 When 2T is added to car, its usually at very low ratio. I have tried from 1:1000 ratio, all the way to 1:500 ratio. Compare to 2T bike that uses 1:25 to 1:50, thats a very small amount. Ive been using it for years and doesnt cause any problem to my Vios. Try to look for such topic in BITOGS and you will find many car owner doing the same thing... The effect is very obvious, the engine will become smoother and quieter... some claim that the FC improved but for me, if improved FC is not really significant. Of course in theory adding oil wil lube valves n pistons but too much wil cause unburned oil to destroy yr cat n add carbon build up to piston n valves. The trick is to add small amounts which wil b completely burned off in e combustion chamber. Add too much n u wil hv problems. In fact even adding small amts of engine oil wil achieve similar results but 2T is specially made to burn off more completely n less likely to cause problems. If its so good....why dont manufactures design 4T engines wh an oil injector to add oil to e petrol going into e chambers. Same as why racing engines also dun hv oil added to e petrol. If not done carefully...it WIL cause problems. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 26, 2013 Share April 26, 2013 (edited) Of course in theory adding oil wil lube valves n pistons but too much wil cause unburned oil to destroy yr cat n add carbon build up to piston n valves. The trick is to add small amounts which wil b completely burned off in e combustion chamber. Add too much n u wil hv problems. In fact even adding small amts of engine oil wil achieve similar results but 2T is specially made to burn off more completely n less likely to cause problems. If its so good....why dont manufactures design 4T engines wh an oil injector to add oil to e petrol going into e chambers. Same as why racing engines also dun hv oil added to e petrol. If not done carefully...it WIL cause problems. yup, agree, adding too much 2T will caused problem, even completely burned off, some cheap 2T will leave carbon on the valve, piston & combustion chamber. That's y only use TCW3 rated or Jaso FD rated 2T. These high quality 2T not only lubricate, at the correct ratio, it could even help to clean the piston & combustion chamber. How do I know? Just go to any bike shop and see them service those 2 stroke bike.... those that use cheapo 2T will have a thick layer of carbon left on the piston head... Where those using quality 2T is sparkling clean.... Oh yeah, Jaso FD & TCW3 rated 2T is cat safe btw, of course, at the manufacturer recomended dosage... Edited April 26, 2013 by Tigershark1976 Link to post Share on other sites More sharing options...
Wormvirus 1st Gear April 26, 2013 Share April 26, 2013 today go back full tank 98, poor gearbox has to work harder for 95 Link to post Share on other sites More sharing options...
Cltey Clutched April 26, 2013 Share April 26, 2013 I think add 2T to petrol will cause more carbon stuck the piston & ring. As I know my bike 2T engine every time service got 1 layer of carbon stuck on the piston & engine head need scrapper to scrap it, carbon also stuck at piston block exhaust. In long run is no good to the engine. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 26, 2013 Share April 26, 2013 yup, agree, adding too much 2T will caused problem, even completely burned off, some cheap 2T will leave carbon on the valve, piston & combustion chamber. That's y only use TCW3 rated or Jaso FD rated 2T. These high quality 2T not only lubricate, at the correct ratio, it could even help to clean the piston & combustion chamber. How do I know? Just go to any bike shop and see them service those 2 stroke bike.... those that use cheapo 2T will have a thick layer of carbon left on the piston head... Where those using quality 2T is sparkling clean.... Oh yeah, Jaso FD & TCW3 rated 2T is cat safe btw, of course, at the manufacturer recomended dosage... Where wud i b able to get e recommended 2T? What brand n how does e bottle look like? How much a lit? Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 26, 2013 Share April 26, 2013 Where wud i b able to get e recommended 2T? What brand n how does e bottle look like? How much a lit? Lim Ah Boy,at Kelantan Lane,very famous for motocycles parts...used Putoline 959 for my RX-Z,not bad. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 26, 2013 Share April 26, 2013 Lim Ah Boy,at Kelantan Lane,very famous for motocycles parts...used Putoline 959 for my RX-Z,not bad. Ok tks. Maybe i try a bottle next time i passing by. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 28, 2013 Share April 28, 2013 (edited) Where wud i b able to get e recommended 2T? What brand n how does e bottle look like? How much a lit? I bot castrol 2T (FD rated) in Alexandra village for $20 if i remember correctly, thats the pricing 5 yrs ago liao....its gold colour bottle. The 1L bottle can use very long if you mix at 1:500 ratio... as for the TCW3 rated 2T, I bot from Mal. Edited April 28, 2013 by Tigershark1976 Link to post Share on other sites More sharing options...
Throttle2 Supersonic April 28, 2013 Share April 28, 2013 My owners manual says that the recommended octane rating is 98 but the engine can adjust itself to suit 95 if 98 is not available. I have also tested using both 98 and 95 just to see the difference. Not surprisingly, my car performs better , feels smoother and has better mileage with 98. So no reason for me to use 95ron. ↡ Advertisement Link to post Share on other sites More sharing options...
Carbonics Cold Air Intake System - Full Handmake CF
More MRT Lines Announced
Low sex drive be careful, expert warning : Double the risk of death
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
