What make and model worth renew COE after 10 years
Maskedrider
One thing to check on is the availability of parts for your car model that you wish to renew COE. You may want to talk to a few workshops that you are servicing your car with to get a feel.
Picanto offers very little collision protection.
I think all small cars offer little collision protection. I have already taken that into consideration. Thank you.
Thank you for your advise. Did not think about it before. But how to check? Any recommended workshop?
  • Praise 4
If part value of another 6k is a concern, maybe you should consider to save up more before taking the plunge.
Car ownership has unexpected hidden cost that might weigh on your budget.
Edited by Hamburger
Supercharged
It is never about the model and make of car. But the condition of the car and how well the previous owner/s took care of it.
You can try reading thru the Korean makes threads to see which workshops and stockists are good with Korean cars. Then probably give them a call to test water that you want to do major servicing like cooling, gearbox overhaul etc to see whether they can do. For stockists you can check whether have power windows, side mirror and exhaust parts which are quite specific to car models.
If you can find a Picanto chatgroup will be even better.
Adding on I think exhaust is one of those potential headaches because if it gets corroded or damaged and there are no parts (even scrapyard) to replace, it can take a long time to import and the cost will be very high.
Couple with the yearly inspection for COE cars and their low tolerance for exhaust repair marks you can be stuck with undrivable car.
Edited by Elmo
I have driven Sunny and Presea close to their 20th year mark, never had issues with exhausts. May be Japanese makes could be a better option? Edited by Albeniz
Think it is a matter of luck. When I was modding my exhaust...legally...the shop mentioned some models like Subaru R1 or R2 who kena undercarriage damage when it got into accident. The exhaust was so rare that they had to indent from Subaru Japan and waited 7 months and cost $6K. That was almost 10 years ago.
But the story does serve to tell how rare car models may have problem getting parts.
Thank you for your valuable input.
I think there are quite a number of Picanto still running in Malaysia, so should not be a problem. But LTA check on exhaust condition?
$6K is a lot! Cost much more than other wear and tear parts, such as tire and battery.
  • Praise 5
Not LTA per se but during annual inspection for renewal of road tax the inspection centres may be very particular with any welding mark if repairs for rust spots or cracks were done.
If you don't repair the exhaust rust spots or cracks, it may result in loss of power, noise and other smell (depending on which part of the exhaust), should they become worse.
Would like to get some forummer advice here - I have an Audi A5. Lovely ride. But coe expires Feb 2010.
I’d like to renew the coe but seems that it’s on uptrend. The current pqp for April is 35k.
If I renew by end April, I’ll secure 35k renewal but I’ll lose 9 months of existing coe.
The OMV is 47k.
What do you all think? Renew now or wait until next year and bet the poor economy will bring coe down?
The OMV is 47k.
you have the same problem as I am.  My COE due in late Dec with a OMV of $54k.
Before i go into PQP, i like to touch on maintenance.  You need to take into consideration of reliability of Audi, if you are comfortable with its reliability because  you have been driving it, then it is  fine.
You also need to understand the fact that older car would need more frequent repair,  is the repair cost of Audi expensive ?  this is a  consideration because the cost will stack on, again it is your comfort level.
Next is about parts supply.  Audi is not a most common COE brand, letting alone A5 is not the most common Audi model, so you have to consider parts availability after say 5 years.
Now lets consider PQP which is a tough question.  First is whether PQP would go up by say $10k in Feb? no one knows but it is possible. Question is what is your linear depre write off now ? if your linear depre is $13k/year, then if you renew COE now, you will have to write off  10 months of depre which is about $10k. dont forget, you also lose driving the car for 10 months, meaning in 10 years later, you will have to buy a new car 10 months earlier as compare to you renew your COE in Feb next year, that would add on another $5K of additional expense(because the depre of your COE A5 should be around 7k ayear). All in, 10k+5K about $15k.
So your risk of renewing COE now is $15K if COE will to stay at current level. But COE staying at current level is not very high. Soyour risk is likely to be lower than $15k.
But if you delay your re validation, assuming  COE will to go up by 20K? your risk of delaying is only $5k compare with you renew now with a write off of $15k.
Which  one would you  bet on? I have no answer because I am in the same boat as you are, same boat but different car.
Edited by Ct3833
  • Praise 3
Great information. Btw, what is the model of your car pending COE renewal?
  • Praise 2
HI, PM you, old car already,  I dare not to mention to many times here before i get scolding.
Iâd like to renew the coe but seems that itâs on uptrend. The current pqp for April is 35k.
If I renew by end April, Iâll secure 35k renewal but Iâll lose 9 months of existing coe.
The OMV is 47k.
Well said by bro CT3833.
Beside condition of the car and part supply. U also need to know there is no resale value for COE car should u decide to let go next time. How i know? Bcos i am experiencing that with my COE car. Dealer only take in at paper value. Thankfully the car is not giving me problem, just that my backside is itchy to change. Haha.
Regardless of car present condition, i dont think parts like gearbox and engine can last 20 yrs without overhaul. The servicing cost will be higher bcos each time u will realise this one must change, that part must change, and so on.
Same situation for me. My COE due only in Aug 2020. So a bit too far away to consider early renewal despite the low PQP.
I will just wait and see and if by then the PQP is too much to stomach then I get another expiring car and play the same game again. Haha...
another one in the same boat, haha .  is your cat A or B? I think if depre is not too high, can make a decision shortly.
