Andy123 1st Gear March 13, 2016 Share March 13, 2016 Does any one know how to unlock door . From manual it state key off ,driver door open then all 4 foor will unlocked. But my unit dont work. Just 40km it will lock. Tried to put P to change way of lock and unlock. But it dont work. Any one have same ezperience? ↡ Advertisement Link to post Share on other sites More sharing options...
Kindaixin 1st Gear March 13, 2016 Share March 13, 2016 i have a habit of switching to neutral gear at red light with handbrake. Is that a bad practice for Altis? Should you leave it a D and press the footbrake? Link to post Share on other sites More sharing options...
turbonow 1st Gear March 13, 2016 Share March 13, 2016 Does any one know how to unlock door . From manual it state key off ,driver door open then all 4 foor will unlocked. But my unit dont work. Just 40km it will lock. Tried to put P to change way of lock and unlock. But it dont work. Any one have same ezperience? I managed to get it changed to unlock whenever I shift the gear into "Park" position. You need to close all doors and shutdown your engine first. Then put engine to "On" position (not "Start"). Then, remain in "Park" gear, press and hold "Unlock" button for 5 seconds. That's it. Link to post Share on other sites More sharing options...
Andy123 1st Gear March 15, 2016 Share March 15, 2016 Any one had changed speaker ? It is bad quality sound from original set speaker Link to post Share on other sites More sharing options...
turbonow 1st Gear March 17, 2016 Share March 17, 2016 Any one had changed speaker ? It is bad quality sound from original set speakerTo me, the speaker sound quality is good enough. Just need to adjust the front balance to F+5. Link to post Share on other sites More sharing options...
turbonow 1st Gear March 23, 2016 Share March 23, 2016 To me, the speaker sound quality is good enough. Just need to adjust the front balance to F+5. Went to BM to install the tweeter speaker at the position at the wing mirror. But I don't think it sound better. Anyone installed this? Can advise what audio settings to get the best sound? Link to post Share on other sites More sharing options...
Toyota62 2nd Gear March 24, 2016 Share March 24, 2016 Any one had changed speaker ? It is bad quality sound from original set speakerFor me I will definitely change it . I remembered the SE laugh when I turn up the volume . She said I am different as normally people will turn off the vol to evaluate the road noise . Told her that I also needed to test the speakers SQ and I confirm that it need to be upgraded. To me the 2 impt add on are1. Car camera 2. Better speakers than stock First one is for safety Second is that you will be in the car most of the time and if there are jam/ heavy traffic ..nothing beat a good sound system with soothing music to relief the stress. For me I am not into cosmetic upgrade or to change things like rim/ tyres, $$ on those expensive PPS . Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear March 24, 2016 Share March 24, 2016 For me I will definitely change it . I remembered the SE laugh when I turn up the volume . She said I am different as normally people will turn off the vol to evaluate the road noise . Told her that I also needed to test the speakers SQ and I confirm that it need to be upgraded. To me the 2 impt add on are 1. Car camera 2. Better speakers than stock First one is for safety Second is that you will be in the car most of the time and if there are jam/ heavy traffic ..nothing beat a good sound system with soothing music to relief the stress. For me I am not into cosmetic upgrade or to change things like rim/ tyres, $$ on those expensive PPS . Everyone got their poison is all I will say (Like 1 of my friend, scuff plate is his poison) . I will advise just do what you deem is worth it and don regret in future, even if its wrong just embrace and learn from it Link to post Share on other sites More sharing options...
Bennyong11 Neutral Newbie March 26, 2016 Share March 26, 2016 Anyone knows of any car camera that can record even at the sides when parked and engine is off? Link to post Share on other sites More sharing options...
whiz18 Clutched March 26, 2016 Share March 26, 2016 Anyone knows of any car camera that can record even at the sides when parked and engine is off? you want record 360 deg of your car? not very common for people to record the sides. Link to post Share on other sites More sharing options...
Bennyong11 Neutral Newbie March 27, 2016 Share March 27, 2016 you want record 360 deg of your car? not very common for people to record the sides.Yes if possible:) Link to post Share on other sites More sharing options...
whiz18 Clutched March 27, 2016 Share March 27, 2016 Yes if possible:) share with me the info of the camera if you managed to find it. :) Link to post Share on other sites More sharing options...
Kklee 6th Gear March 27, 2016 Author Share March 27, 2016 Yes if possible:) For clarity, use 4. Link to post Share on other sites More sharing options...
Chongsf 1st Gear March 27, 2016 Share March 27, 2016 I would like to ask any bros here who install blackvue wth powermagic pro (pmp) face the same problem. As the fuse box is located on the left hand side. My question is my installer installed the pmp (with on/off switch) on the left hand side because the pmp pro has to be installed near to the fuse box. As I have the tendency to off the camera at home, I found it difficult to reach the pmp to switch off. Link to post Share on other sites More sharing options...
Andy123 1st Gear March 28, 2016 Share March 28, 2016 Anyone have experience drive shaft front sound 'tok' when start moving car? Link to post Share on other sites More sharing options...
Fizal82 March 30, 2016 Share March 30, 2016 Bro will this be legal? Will vicom inspection fail this thing if checked? If software, then everything patch will set it back? Hehe. Hw much cost involved. Hardware bypass as asked? It's not illegal bro.. Hahaha! Those aftermarket pioneer Headunits can play videos while in Motion too.. Link to post Share on other sites More sharing options...
Fizal82 March 30, 2016 Share March 30, 2016 Any one had changed speaker ? It is bad quality sound from original set speakerThe original speakers sucks big time, my friend bought the twitters from bm and it sounds flat.. Haha! The original Headunit is quite good. I changed my speakers recommended by my installer Sky. Some German brand speaker that cost me around $400+. It comes with a set of two front speakers, tweeters and installation. Superb Sound!!!! Link to post Share on other sites More sharing options...
Andy123 1st Gear March 30, 2016 Share March 30, 2016 The original speakers sucks big time, my friend bought the twitters from bm and it sounds flat.. Haha! The original Headunit is quite good. I changed my speakers recommended by my installer Sky. Some German brand speaker that cost me around $400+. It comes with a set of two front speakers, tweeters and installation. Superb Sound!!!!Could you please share you model here ,,thanks ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota bZ4X
2022 Toyota bZ4X
Toyota Land Cruiser Mini
Nissan QashQai 2014 Part 2
Is this Altis bodykits optional??
