Suhaimiebrahim 1st Gear May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. ↡ Advertisement Link to post Share on other sites More sharing options...
SuPerBoRed Twincharged May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. IIRC.... it means engine is not running at 100% output.. please send to workshop for piece of mind... Link to post Share on other sites More sharing options...
Desmojon 1st Gear May 4, 2015 Share May 4, 2015 Commonly known as CEL "Check Engine Light" Can be many reasons but get it check as soon as possible. Many workshops have an engine diagnostic tool to find out what is exactly wrong. Good luck 1 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. To let you know that the engine is still in the engine bay. 2 Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. Like what the above forumer say, it's "check engine light". Mean the engine detected a fault in the system, what you can do is to disconnect and reconnect your battery aka "reset" the ECU memory and see if the fault came back or one off fault. If it came back, you can use a scan gauge tool to scan see what's the problem and get it repair, most likely it's O2 sensor problem. Link to post Share on other sites More sharing options...
cllq 6th Gear May 4, 2015 Share May 4, 2015 Like what the above forumer say, it's "check engine light". Mean the engine detected a fault in the system, what you can do is to disconnect and reconnect your battery aka "reset" the ECU memory and see if the fault came back or one off fault. If it came back, you can use a scan gauge tool to scan see what's the problem and get it repair, most likely it's O2 sensor problem. If it is O2 sensor, just get the wires rewired. Common prob Link to post Share on other sites More sharing options...
Jman888 Moderator May 4, 2015 Share May 4, 2015 To let you know that the engine is still in the engine bay. If engine is there, there won't be any light. Only when it was missing then the light is on Link to post Share on other sites More sharing options...
The_Bear Turbocharged May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. It means engine damaged. Someone shot you in the engine. Click the repair kit to return engine to original condition. Sorry, played too much WoT. Link to post Share on other sites More sharing options...
Knoobie Supercharged May 4, 2015 Share May 4, 2015 To let you know that the engine is still in the engine bay. my friend told me the light is to tell you that there is suspicion of engine being stolen thats why the "check engine light" is shown to tell you to ensure your engine is still in engine bay leh. 1 Link to post Share on other sites More sharing options...
Obey_my_dog 2nd Gear May 4, 2015 Share May 4, 2015 It means engine damaged. Someone shot you in the engine. Click the repair kit to return engine to original condition. Sorry, played too much WoT. Hahaha this one takes the cake.... ;P Link to post Share on other sites More sharing options...
Toyo 1st Gear May 4, 2015 Share May 4, 2015 Hi bros, Need your feedback and advise. Recently, saw this symbol looks like an engine block appear on my instrument display. Look in the manual and it says " sent car to Toyota dealer" What exactly this symbol mean and is it a major problem to the car? I have not sent my car for checking yet. Have a nice day ahead. ECU detected a fault. Workshop has the tool to diagnose the fault. The last time I encounter this, i send to workshop and the fault diagnosed was engine misfiring. End up I have to change all the spark plugs Link to post Share on other sites More sharing options...
Opel17 6th Gear May 4, 2015 Share May 4, 2015 ECU detected a fault. Workshop has the tool to diagnose the fault. The last time I encounter this, i send to workshop and the fault diagnosed was engine misfiring. End up I have to change all the spark plugs Exactly what my engine suffered several months ago on the way back from Genting. Usually manual would advise to drive/"limp" at slower pace to workshop, since there is something not right with the engine. Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 4, 2015 Share May 4, 2015 Normally, Japenis cars no problem one, can still drive around for few days if no time to send to Toyota, Honda, etc. I drove Honda Steam with CEL light on in Japan for one week also no problem. No steam come out also. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic May 4, 2015 Share May 4, 2015 Normally, Japenis cars no problem one, can still drive around for few days if no time to send to Toyota, Honda, etc. I drove Honda Steam with CEL light on in Japan for one week also no problem. No steam come out also. Japanese cars also do not warn its drivers of a lot of issues too...I noticed. Save cost on sensors. Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear May 4, 2015 Author Share May 4, 2015 Thank you and appreciate all bros for your good advise humor!!!!! Have a nice day ahead Link to post Share on other sites More sharing options...
7hm Turbocharged May 4, 2015 Share May 4, 2015 What the hell is this check engine light? ... SC2 haha. It's like, this general engine problem light, generally is send to workshop for retrieving diagnostic code... Link to post Share on other sites More sharing options...
Mustank Hypersonic May 4, 2015 Share May 4, 2015 What the hell is this check engine light? ... SC2 haha. It's like, this general engine problem light, generally is send to workshop for retrieving diagnostic code... Link to post Share on other sites More sharing options...
7hm Turbocharged May 4, 2015 Share May 4, 2015 (edited) https://www.youtube.com/watch?v=tvK-fyh-bAE&start=13 at 13secs is what I always think of when someone mention this light... or I see it myself Edited May 4, 2015 by 7hm ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Any recommended workshop with reasonable labour charges?
