Kklee 6th Gear September 25, 2024 Share September 25, 2024 On 9/25/2024 at 10:48 AM, ER-3682 said: @Kklee i think 98 more additives...more smell. IMHO. Perhaps. My concern is more of whether it can combust fully given that the timing can only advance that much. 🤔 ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 25, 2024 Share September 25, 2024 On 9/25/2024 at 10:52 AM, ER-3682 said: Same as why V-Power why sometime they selling at Fuelsaver 98 Price...just wonder why Shell have 2 types of 98 Petrol.? Shell marketing? Just like car manufacturers must have a Halo Product. I think Shell has V-power in every market it operates. But not all has the same octane. Malaysia V-power is RON97 Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 25, 2024 Share September 25, 2024 On 9/25/2024 at 11:10 AM, Kklee said: IMHO. Perhaps. My concern is more of whether it can combust fully given that the timing can only advance that much. 🤔 If Fuel-Air Ratio is correct..sure can fully combust. Link to post Share on other sites More sharing options...
mersaylee Hypersonic September 25, 2024 Share September 25, 2024 Just drop to lower gear and drag at high rpm for a while lah...clear carbon with whatever ron...hope no need to go workshop for engine or gearbox overhaul...😂 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 25, 2024 Share September 25, 2024 On 9/25/2024 at 12:21 PM, mersaylee said: Just drop to lower gear and drag at high rpm for a while lah...clear carbon with whatever ron...hope no need to go workshop for engine or gearbox overhaul...😂 Within 5 sec, you already exceed speed limit 😂 Link to post Share on other sites More sharing options...
mersaylee Hypersonic September 25, 2024 Share September 25, 2024 On 9/25/2024 at 12:38 PM, inlinesix said: Within 5 sec, you already exceed speed limit 😂 Gear satu dua wont lah...hit hardware limit niah...😅 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear September 25, 2024 Share September 25, 2024 On 9/25/2024 at 11:17 AM, ER-3682 said: If Fuel-Air Ratio is correct..sure can fully combust. IMHO. Thus if AFR is a variable and to achieve full combustion, then it should be possible to have improve FC ( depending on design ) when the ECU either reduce the fuel or advances the ignition timing. Just like the specific energy for different octane fuel can be very similar, higher compression and more advanced in ignition timing can lead to more power. Again, better FC? 🤔 Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 25, 2024 Share September 25, 2024 On 9/25/2024 at 1:12 PM, Kklee said: IMHO. Thus if AFR is a variable and to achieve full combustion, then it should be possible to have improve FC ( depending on design ) when the ECU either reduce the fuel or advances the ignition timing. Just like the specific energy for different octane fuel can be very similar, higher compression and more advanced in ignition timing can lead to more power. Again, better FC? 🤔 FC control by Right Leg. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged September 25, 2024 Share September 25, 2024 On 9/25/2024 at 8:15 AM, Mkl22 said: this one hard to say. each brand kaki kong kaki song. Unless you borescope the cylinder walls regularly, no way to tell. this is my thought too 👍 1 Link to post Share on other sites More sharing options...
Beehive3783 Twincharged September 26, 2024 Share September 26, 2024 On 9/25/2024 at 9:15 AM, Volvobrick said: Higher Octane allows higher compression ratio without knocking. Whether rpm is 1000 or 10000 the compression ratio remains the same. Anyway who drives around at 6000 rpm all the time except chow bengs? First time i heard RON100 allows the engine to hold high rpm for longer 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 26, 2024 Share September 26, 2024 (edited) On 9/26/2024 at 1:21 PM, Beehive3783 said: First time i heard RON100 allows the engine to hold high rpm for longer Not surprising as most ppl here never use RON100 before. I used it Mini as well as MYVI. Edited September 26, 2024 by inlinesix Link to post Share on other sites More sharing options...
Bezbee 5th Gear March 4, 2025 Share March 4, 2025 My car just popped up a "Top Up Coolant" message this morning. I am going to buy a 1.5L coolant (red) this evening from a seller to top it up myself. First time doing this myself, it should not go wrong so long I pour into the correct tank right ?😅 I asked Seller if it is a premix, he told me to mix 50part coolant with 50part water ...but if coolant has been changed some time ago (like mine in 2022), then can just pour direct inside 🤔 Any advice ? Link to post Share on other sites More sharing options...
inlinesix Hypersonic March 4, 2025 Share March 4, 2025 (edited) On 3/4/2025 at 3:20 PM, Bezbee said: My car just popped up a "Top Up Coolant" message this morning. I am going to buy a 1.5L coolant (red) this evening from a seller to top it up myself. First time doing this myself, it should not go wrong so long I pour into the correct tank right ?😅 I asked Seller if it is a premix, he told me to mix 50part coolant with 50part water ...but if coolant has been changed some time ago (like mine in 2022), then can just pour direct inside 🤔 Any advice ? Just add water will be enough. Get mechanic to check whether got leak or not. Edited March 4, 2025 by inlinesix 2 Link to post Share on other sites More sharing options...
Bezbee 5th Gear March 4, 2025 Share March 4, 2025 Add water can liao ? I am handing over my car to dealer this month ... so I didn't want to spend $$ going to mechanic. I thought to just top up the coolant first and get rid of the irritating message on dashboard 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged March 4, 2025 Share March 4, 2025 first time ah... wait until the engine cooled down before opening the cap fill to the MAX level, don't overfill it if "Top Up Coolant" message appear again send it to workshop, there is a leak somewhere 2 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged March 4, 2025 Share March 4, 2025 On 3/4/2025 at 3:59 PM, Bezbee said: Add water can liao ? I am handing over my car to dealer this month ... so I didn't want to spend $$ going to mechanic. I thought to just top up the coolant first and get rid of the irritating message on dashboard if that's my car I will keep topping it up with tap water until I hand over to the dealer 😁 2 4 Link to post Share on other sites More sharing options...
PSP415 Supersonic March 4, 2025 Share March 4, 2025 (edited) On 3/4/2025 at 3:20 PM, Bezbee said: My car just popped up a "Top Up Coolant" message this morning. I am going to buy a 1.5L coolant (red) this evening from a seller to top it up myself. First time doing this myself, it should not go wrong so long I pour into the correct tank right ?😅 I asked Seller if it is a premix, he told me to mix 50part coolant with 50part water ...but if coolant has been changed some time ago (like mine in 2022), then can just pour direct inside 🤔 Any advice ? Seriously, why not let the mechanic hoist car up to check whether there are visible leaked water/coolant marks. If wan to top up with just water, try using distilled water. Otherwise, mix 50/50 coolant and water is ideal. My experience with leaking water coolant led me to change radiator, water pump with thermostat assbly and oil filter housing. Wear and tear issues. The oil filter housing was critical for me as coolant is threatening to cross over to engine oil. Would have cost me much more to rectify. It was almost a near miss cos tot radiator and water pump replaced liao, all's well until a bit pool of brand new coolant was on the floor the very next morning. Just sharing. Yours may not be as serious. Stay safe Cheers NB : just saw that you intend to sell car/hand over to dealer. Haiz. Hope u getting a brand new ride. Me conscience no allow to leave problems to next buyer. Hopefully, dealer got conscience to do a proper repair. Fat hope. But then, the golden rule is to standby at least $3-4k for repairs if getting a 2nd hand ride. Edited March 4, 2025 by PSP415 Link to post Share on other sites More sharing options...
Bezbee 5th Gear March 4, 2025 Share March 4, 2025 Thank you for the advice. Ok I will try adding water after work, engine should have cool down and hopefully the message goes away. Else will just try to add the coolant, the bottle cost only $13, so I don't mind buying. But I will go with the advice to add water first. My car is 9.5year old liao, perhaps water is the best.🤣 ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant question
Coolant question
No Down Payment Required, 100% Finance Available
