Coolant level going down
Sash1401
Getting air bubbles out of the car cooling system especially European cars is time consuming and very frustrating for both mechanics and car owners.
Air bubble locks can result in overheating in the cooling system and without special coolant refilling tools it is just not possible to remove 100% of all the bubbles.
Many shops in Singapore have now employ innovative coolant refilling system tools to greatly improve their productivity.
Edited by Yeobh
On 6/23/2024 at 11:34 PM, Gnahp said:
I noticed the coolant level of my wife's car is dropping slowly since a few months ago
at the rate of around 500ml per 10,000km, that is not normal but not a big leak too, not enough to trigger the low coolant level warning in 10,000km
I also couldn't find any dried up coolant traces on the engine and the engine compartment during my routine checks
today I took out my borescope to check areas that I cannot see from outside
found some dried up coolant traces on the seam of the plastic coolant pipe under the intake manifolds 😑
updates
changed the pipe today
since the intake manifold got to be removed to access to this plastic coolant pipe
I took the opportunity to ask the workshop to do walnut blasting to the intake ports/valves too
at 110,000km, carbon started to form at the back of the intake valves already
  • Praise 5
On 9/25/2024 at 7:23 AM, ER-3682 said:
@Gnahp What Petrol you used.?95 or 98.?Which Brand.?
cheapo Shell 95 since new, with 1~2 tankful of malaysia petrol every year
this engine is direct injection only
so no petrol get sprayed into the intake ports to clean the back of the valves and intake ports
  • Praise 2
On 9/25/2024 at 7:49 AM, ER-3682 said:
@Gnahp Will 98 or V-Power give cleaner Engine.?
this one hard to say. each brand kaki kong kaki song. Unless you borescope the cylinder walls regularly, no way to tell.
Edited by Mkl22
  • Praise 3
For DI, carbon accumulation is normal regardless of Petrol used.
Nothing beat RON100
Edited by inlinesix
  • Haha! 1
Nothing beat RON100
octane is octane and fuel additive to clean are totally different.
  • Praise 4
I know.
We have always been saying clear carbon.
With RON100, the engine can hold at a higher RPM.
Wouldn’t it be cleaner engine?
On 9/25/2024 at 9:11 AM, inlinesix said:
I know.
Higher Octane allows higher compression ratio without knocking. Whether rpm is 1000 or 10000 the compression ratio remains the same.
Anyway who drives around at 6000 rpm all the time except chow bengs?
Edited by Volvobrick
  • Praise 2
But but with higher RPM, both intake and exhaust valve will operate at a more aggressive angle.
In the era of turbo, who drive at 6000RPM?
You only get RON100 in Msia easily.
Nothing beat RON100
Just Wonder why Singapore Caltex stopped RON 100 Petrol.?
On 9/25/2024 at 10:25 AM, inlinesix said:
Low volume.
In Msia, only Petron sells it.
Then must well,stop selling 98 Techron Platinum...same as V-Power.
That mean it is even lower volume than 98 Techron Platinum.
The margin might be good but it doesn't move for months.
IMHO.
The question I have is,  with the same air fuel mixture but same ignition timing,
will a higher octane fuel have more complete combustion vs regular octane fuel ? 🤔
I took reference from sometime back, someone who de-cat,  during startup,  ron98 produce more pungent emission (by smell) over ron95.  IIRC.
Same as why V-Power why sometime they selling at Fuelsaver 98 Price...just wonder why Shell have 2 types of 98 Petrol.?
