Bonafidestack 4th Gear June 7, 2019 Share June 7, 2019 Anyone experience this before? I didn't check the note is passed to me by the hawker. Then this morning when I take out my note i realised it's torn. Nowadays not all bank have people station there. What do you all do with torn note? any tips? ↡ Advertisement Link to post Share on other sites More sharing options...
Vid Hypersonic June 7, 2019 Share June 7, 2019 Give me lor... I'll take all your torn notes 6 Link to post Share on other sites More sharing options...
Jayy25 6th Gear June 7, 2019 Share June 7, 2019 Anyone experience this before? I didn't check the note is passed to me by the hawker. Then this morning when I take out my note i realised it's torn. Nowadays not all bank have people station there. What do you all do with torn note? any tips? IMG_0995.jpg if you return to the bank, this will probably worth only $8 plus. that sneaky hawker very smart.... pass that torn bill to you... so in the end your lunch/dinner cost more now since that bill has been depreciated when one part of it had been "written off" Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 7, 2019 Share June 7, 2019 Pass all torn ones you have to me...I have enough scotch tape... Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 7, 2019 Share June 7, 2019 Stick it back with clear tape if you don't want to Q at bank to exchange it. Liquidate it ASAP. Link to post Share on other sites More sharing options...
Jman888 Moderator June 7, 2019 Share June 7, 2019 if you return to the bank, this will probably worth only $8 plus. that sneaky hawker very smart.... pass that torn bill to you... so in the end your lunch/dinner cost more now since that bill has been depreciated when one part of it had been "written off" i thought pass it to the bank they will exchange with you, no? 1 Link to post Share on other sites More sharing options...
RadX Moderator June 7, 2019 Share June 7, 2019 Pass me I bank for you foc... my bank no q one hahah Link to post Share on other sites More sharing options...
Kusje Supersonic June 7, 2019 Share June 7, 2019 go bank and change la. what a question. it's 10 bucks. if it is $2, then throw it away, no need to waste time. I once received a 1USD coin instead of 1 SGD coin. Knn, kanna cheated. Threw the coin away also. Link to post Share on other sites More sharing options...
PSP415 Supersonic June 7, 2019 Share June 7, 2019 Tape it and go exchange with the bank. $10 for $10. If got issues, go MAS to do it. As long as set of serial numbers intact, no problem. Otherwise can frame it or laminate it as a reminder to check the change, if u want to avoid the hassle. Safe ride Cheers 3 Link to post Share on other sites More sharing options...
Ronkovic 5th Gear June 7, 2019 Share June 7, 2019 Tape it and go exchange with the bank. $10 for $10. If got issues, go MAS to do it. As long as set of serial numbers intact, no problem. Otherwise can frame it or laminate it as a reminder to check the change, if u want to avoid the hassle. Safe ride Cheers Yes, just stick it with scotch tape and exchange at bank, or re-circulate by using it to purchase something after you've patched it. Just note that with regards to serial numbers, if you wish to have a full refund of the amount - both sets of complete serial numbers must be on the note, If the note is half torn and only holds one full serial number and without / partial second serial number, you will only get half the amount. 3 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged June 7, 2019 Share June 7, 2019 Scotch tape the notes and use in NTUC auto-cashier machines. Link to post Share on other sites More sharing options...
BanCoe Hypersonic June 7, 2019 Share June 7, 2019 (edited) At least you receive torn notes can exchange one back .... I kenna coins in foreign currency, never usually check the coins until I come home or give other people then I kenna or later check ..... KNN kenna shortchange with Malaysian and even Thai one also got, by the time can’t remember which shop I also went Edited June 7, 2019 by BanCoe 2 Link to post Share on other sites More sharing options...
Bonafidestack 4th Gear June 7, 2019 Author Share June 7, 2019 I use clear tape and stick it back and pay back to the exact hawker just now. Hahaha. He didn't realise. 4 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 7, 2019 Share June 7, 2019 Buy again from the same hawker and use the $10. Did you give him a $50? ↡ Advertisement Link to post Share on other sites More sharing options...
I tried Sliplo and here's what I think.
What to do with inheritance?
What is your favourite radio channel?
