Jamesc Hypersonic May 3, 2020 Share May 3, 2020 All the drivers that crash there can blame CB. They can say if not for CB then won't crash. Normally too many cars how to chiong and crash? CB lah now so few cars so go a "bit" fast only and this happens. We all know lousy driver all got excuse one so they can add this one to their list and use it. This one no need to pay copy right. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 3, 2020 Share May 3, 2020 All the cars that crash there seem to be older cars. Maybe don't have ESC? If newer cars then have ESC then maybe the ESC would have brake the back wheel to stop the tail from sliding out and prevent the crash. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear May 3, 2020 Share May 3, 2020 11 minutes ago, inlinesix said: Press brake in the middle of the turn will shift the car weight balance to the front. This will test the bite of front tyre. And then, turn steering to the left. Wouldn't that break tyre traction? Wouldn't that cause fishtailing or oversteer? Throttle has to be very smooth in slippery condition. Then they brake somemore turn some more end up lose friction angle at the front, lose traction at the end, car rotates and all 4 wheels at sea. 1 Link to post Share on other sites More sharing options...
Jeffreybry Clutched May 3, 2020 Share May 3, 2020 Interesting stuff here 😎 Link to post Share on other sites More sharing options...
1fast1 Supersonic May 3, 2020 Share May 3, 2020 7 hours ago, inlinesix said: Press brake in the middle of the turn will shift the car weight balance to the front. This will test the bite of front tyre. And then, turn steering to the left. Wouldn't that break tyre traction? That's what LFB is for. Left foot braking. It's the only safe way to scrub speed mid corner. 1 Link to post Share on other sites More sharing options...
Gunzy 4th Gear May 3, 2020 Share May 3, 2020 This strip could be causing problem when driven over at high speed (>110km/h) especially when wet... 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 3, 2020 Share May 3, 2020 There are many attributes but those are just excuses. Is the skill or rather, lack of it. 4 Link to post Share on other sites More sharing options...
Vinceng Turbocharged May 3, 2020 Share May 3, 2020 On 5/2/2020 at 12:30 PM, Yewheng said: Now this video need to update.. Today just got another accident at the same spot.. Darn these drivers.. How mamy times must get into accident in just 1 month? Haiz.. More accidents on the same stretch. 2 cars skidded at the same spot, one after another Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 4, 2020 Share May 4, 2020 (edited) 19 hours ago, inlinesix said: Press brake in the middle of the turn will shift the car weight balance to the front. This will test the bite of front tyre. And then, turn steering to the left. Wouldn't that break tyre traction? well , if u drive a mid engine car like MR2, u be having a fun time with snap over steer on lift off mid corner Edited May 4, 2020 by Sdf4786k 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 4, 2020 Share May 4, 2020 18 hours ago, Jamesc said: All the cars that crash there seem to be older cars. Maybe don't have ESC? If newer cars then have ESC then maybe the ESC would have brake the back wheel to stop the tail from sliding out and prevent the crash. Some will then say, a FWD will crash. A RWD one will be able to power slide thru safely. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 4, 2020 Share May 4, 2020 9 hours ago, Gunzy said: This strip could be causing problem when driven over at high speed (>110km/h) especially when wet... Yes partially. Cause the strips are more slippery in the wet, plus usually they are also slightly depressed thus unsettling the balance of the car in a bend. And when one goes are a higher speed, the unskilled will panic and slam the brakes and we know the end result. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 4, 2020 Share May 4, 2020 Just to mention, the slip road to join KPE from ECP( city) has a bump in the road due to ground subsistence right after the start of the left bend. Go at 60kmh or higher and you can feel your rear end shift out. I travel there frequently, but wonder why no one has crashed yet! Haha Link to post Share on other sites More sharing options...
Phluvcat 6th Gear May 4, 2020 Share May 4, 2020 (edited) Public service announcement - Jln Buroh towards West Coast Highway direction just after coming down the bridge over Pandan River, 3rd lane huge pothole can probably fit a whole 17-incher inside when laid flat. Be careful. That said, roads nowadays got sucky maintenance and patching works, especially now - lack of maintenance. Edited May 4, 2020 by Phluvcat 4 Link to post Share on other sites More sharing options...
Beanoyip Turbocharged May 4, 2020 Share May 4, 2020 19 minutes ago, Mkl22 said: Some will then say, a FWD will crash. A RWD one will be able to power slide thru safely. And AWD will just drive through like a BOSS! 5 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 4, 2020 Share May 4, 2020 (edited) 8 minutes ago, Phluvcat said: Public service announcement - Jln Buroh towards West Coast Highway direction just after coming down the bridge over Pandan River, 3rd lane huge pothole can probably fit a whole 17-incher inside when laid flat. Be careful. That said, roads nowadays got sucky maintenance and patching works, especially now - lack of maintenance. Debris of tree trunk on right of Lane 1 expressway Edited May 4, 2020 by inlinesix Link to post Share on other sites More sharing options...
Phluvcat 6th Gear May 4, 2020 Share May 4, 2020 6 minutes ago, inlinesix said: Debris of tree trunk on right of Lane 1 expressway Hahaha which expressway and which chainage? Anyway me safely back home 😁 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 4, 2020 Share May 4, 2020 12 minutes ago, Phluvcat said: Hahaha which expressway and which chainage? Anyway me safely back home 😁 AYE around Tuas Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 4, 2020 Share May 4, 2020 (edited) 36 minutes ago, Beanoyip said: And AWD will just drive through like a BOSS! not necessary .. challenging the law of physics ... not so easy... on a brighter note Edited May 4, 2020 by Sdf4786k ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
Mercedes Owners Thread
Boomers on the road should take mandatory tests
PSA: Driving in Malaysia and How To Handle Accidents and Theft
2027 Mercedes C-Class
Any good private driving instructor to recommend?
