Sdf4786k Twincharged September 23, 2020 Share September 23, 2020 11 hours ago, Hamburger said: I tried superglue and it worked. But after few times of usage, the heat got onto it and came off. food related stuff cannot use superglue.. Heat does not play well with superglue as well. ↡ Advertisement Link to post Share on other sites More sharing options...
Somewhat1975 6th Gear September 23, 2020 Share September 23, 2020 suggest not to try those unknown glue on food related stuff. These glue, welding, and bonding materials might not be food graded. throw away and buy a new one lah. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic September 23, 2020 Share September 23, 2020 10 minutes ago, Jman888 said: this one can? sorry i am not a handyman Need quite a few... 😅 Link to post Share on other sites More sharing options...
Alpha78 6th Gear September 23, 2020 Share September 23, 2020 29 minutes ago, Somewhat1975 said: suggest not to try those unknown glue on food related stuff. These glue, welding, and bonding materials might not be food graded. throw away and buy a new one lah. Agree. Safer way is to buy a similar handle that comes with screw thread (and maybe screws included), then punch the holes in the lid and secure with screws. 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 23, 2020 Author Share September 23, 2020 Thanks for the advice. I didn't know spot welding looks like that when it breaks apart. Its an inexpensive item, so just seeing if can be salvaged (not that it's unusable now), but a SS container used to let hot/boiling water cool down to room temp without a handle lid is pretty useless haha Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 23, 2020 Share September 23, 2020 15 minutes ago, Lala81 said: Thanks for the advice. I didn't know spot welding looks like that when it breaks apart. Its an inexpensive item, so just seeing if can be salvaged (not that it's unusable now), but a SS container used to let hot/boiling water cool down to room temp without a handle lid is pretty useless haha Use this. 😂 Removable but if kalao on your foot not my prob. 5 Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 23, 2020 Author Share September 23, 2020 1 minute ago, Stratovarius said: Use this. 😂 Removable but if kalao on your foot not my prob. HAHAHA. That's quite funny. 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged September 23, 2020 Share September 23, 2020 Just drill a hole on the lid, put a nylon string, tied 2 knots one on the inner part of it and one just on top of the lid (so it will not fall into the water). Can use many more years. 2 Link to post Share on other sites More sharing options...
badlammy 6th Gear September 23, 2020 Share September 23, 2020 1 hour ago, Lala81 said: Thanks for the advice. I didn't know spot welding looks like that when it breaks apart. Its an inexpensive item, so just seeing if can be salvaged (not that it's unusable now), but a SS container used to let hot/boiling water cool down to room temp without a handle lid is pretty useless haha Huh inexpensive all the more shd just replace mah. Expensive then try to salvage, no? Link to post Share on other sites More sharing options...
badlammy 6th Gear September 23, 2020 Share September 23, 2020 My recent DIY...got locked from outside of bedroom due to faulty door lock and whacked it. Lucky not locked from inside, else dunno use what to whack open. Lesson learnt, once see signs of faulty door lock, change immediately. 2 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 23, 2020 Author Share September 23, 2020 7 minutes ago, badlammy said: Huh inexpensive all the more shd just replace mah. Expensive then try to salvage, no? Only a small component of it is spoilt mah. Just the lid handle. This one is like 20% broken, so ask lor. If the main handle break, of course throw away lah. It's not about the $ issue. There are many things i throw away and discard if I find them unusable. I honestly didn't even notice it wasn't a screw on handle like my other one, until it broke. 3 Link to post Share on other sites More sharing options...
mersaylee Hypersonic September 23, 2020 Share September 23, 2020 1 hour ago, Stratovarius said: Use this. 😂 Removable but if kalao on your foot not my prob. Use ten, one for each finger safer lift the lid, Thanos style Link to post Share on other sites More sharing options...
Kklim Supercharged September 23, 2020 Share September 23, 2020 Anyone knows where I can buy this type of switch for table fan? Thanks.http://www.jentex.com.tw/E/body.php?web=14&PNo=2006050012 Link to post Share on other sites More sharing options...
Leo72 6th Gear September 23, 2020 Share September 23, 2020 (edited) 45 minutes ago, badlammy said: My recent DIY...got locked from outside of bedroom due to faulty door lock and whacked it. Lucky not locked from inside, else dunno use what to whack open. Lesson learnt, once see signs of faulty door lock, change immediately. No need to whacked or damaged the lock. There is a trick to open locked door with this type of lock, can easily open it within 5 minutes with the right stuff. I didn't know this type of lock can be easily open until 2008. Edited September 23, 2020 by Leo72 more comment 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged September 23, 2020 Share September 23, 2020 45 minutes ago, mersaylee said: Use ten, one for each finger safer lift the lid, Thanos style Eh Thanos only has 1 Gauntlet leh... Link to post Share on other sites More sharing options...
Xers007 Supercharged September 23, 2020 Share September 23, 2020 3 minutes ago, Leo72 said: No need to whacked or damaged the lock. There is a trick to open locked door with this type of lock, can easily open it within 5 minutes with the right stuff. I didn't know this type of lock can be easily open until 2008. I ever tried using a credit card to open such lock but failed. So came the locksmith, he use the same card and open the door in 5 secs. 😭 15 bucks gone just like that... 1 Link to post Share on other sites More sharing options...
badlammy 6th Gear September 23, 2020 Share September 23, 2020 3 minutes ago, Leo72 said: No need to whacked or damaged the lock. There is a trick to open locked door with this type of lock, can easily open it within 5 minutes with the right stuff. I didn't know this type of lock can be easily open until 2008. Share how leh... I was rushing to go out and my walk-in wardrobe is linked to my bedroom with no separate access. Also tried to slot a mouse pad to push the catch but cannot. So in the end whacked lor. Link to post Share on other sites More sharing options...
Xers007 Supercharged September 23, 2020 Share September 23, 2020 45 minutes ago, Kklim said: Anyone knows where I can buy this type of switch for table fan? Thanks.http://www.jentex.com.tw/E/body.php?web=14&PNo=2006050012 It gotta be at taobao... but must find exactly the same kind as the hole on the fan body might not fit well. search this 风扇琴键档 in taobao site. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Wheel Spacer Installation DIY
