Lala81 Hypersonic September 23, 2020 Author Share September 23, 2020 haha no youtube tutorial? ↡ Advertisement Link to post Share on other sites More sharing options...
13177 Hypersonic September 23, 2020 Share September 23, 2020 1 hour ago, badlammy said: My recent DIY...got locked from outside of bedroom due to faulty door lock and whacked it. Lucky not locked from inside, else dunno use what to whack open. Lesson learnt, once see signs of faulty door lock, change immediately. Think my lesson learnt would be once see signs of faulty door lock, do not lock the door, if not kena locked inside/outside. Link to post Share on other sites More sharing options...
Watwheels Supersonic September 23, 2020 Share September 23, 2020 (edited) 2 hours ago, Xers007 said: Just drill a hole on the lid, put a nylon string, tied 2 knots one on the inner part of it and one just on top of the lid (so it will not fall into the water). Can use many more years. Talk is cheap but stainless steel is tough to do drilling. Your normal high speed steel drill bit might not be able to drill thru. It might burn and become chao tar, destroying your drill bit. You have to use drill bit that has Titanium coating aka gold colour coating. Thankfully Daiso sells them in limited sizes(don't have bigger size), still cheap at 2 bucks. They also sell stainless steel wires as well. Edited September 23, 2020 by Watwheels 1 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear September 23, 2020 Share September 23, 2020 1 hour ago, Kklim said: Anyone knows where I can buy this type of switch for table fan? Thanks.http://www.jentex.com.tw/E/body.php?web=14&PNo=2006050012 https://www.aliexpress.com/item/32825467097.html Dunno suitable or not. 😎 Link to post Share on other sites More sharing options...
Mustank Hypersonic September 23, 2020 Share September 23, 2020 1 hour ago, Kklim said: Anyone knows where I can buy this type of switch for table fan? Thanks.http://www.jentex.com.tw/E/body.php?web=14&PNo=2006050012 If no physical damage maybe is just the contact point dirty you buy contact cleaner and spray the contact points and try lor https://s.lazada.sg/s.v0ny Link to post Share on other sites More sharing options...
Xers007 Supercharged September 23, 2020 Share September 23, 2020 1 hour ago, Watwheels said: Talk is cheap but stainless steel is tough to do drilling. Your normal high speed steel drill bit might not be able to drill thru. It might burn and become chao tar, destroying your drill bit. You have to use drill bit that has Titanium coating aka gold colour coating. Thankfully Daiso sells them in limited sizes(don't have bigger size), still cheap at 2 bucks. They also sell stainless steel wires as well. ok lah... you are the master you advise... dont want to be label as cheap... Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 23, 2020 Share September 23, 2020 3 hours ago, badlammy said: My recent DIY...got locked from outside of bedroom due to faulty door lock and whacked it. Lucky not locked from inside, else dunno use what to whack open. Lesson learnt, once see signs of faulty door lock, change immediately. You karate the knob? 😮 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 23, 2020 Share September 23, 2020 3 hours ago, badlammy said: Share how leh... I was rushing to go out and my walk-in wardrobe is linked to my bedroom with no separate access. Also tried to slot a mouse pad to push the catch but cannot. So in the end whacked lor. There should be a tiny hole near the knob with a catch. Release the catch with a very small screwdriver and you should be able to remove the knob. After that unscrew the round plate to expose the mechanism. Alternatively, learn to pick a lock! 😅 Link to post Share on other sites More sharing options...
badlammy 6th Gear September 23, 2020 Share September 23, 2020 2 minutes ago, Volvobrick said: There should be a tiny hole near the knob with a catch. Release the catch with a very small screwdriver and you should be able to remove the knob. After that unscrew the round plate to expose the mechanism. Alternatively, learn to pick a lock! 😅 The previous one is handle kind, round knob is new. I did try to find the catch, really dun have. That small dent u see in the pic nothing to press in. 2 Link to post Share on other sites More sharing options...
badlammy 6th Gear September 23, 2020 Share September 23, 2020 19 minutes ago, kobayashiGT said: You karate the knob? 😮 haha...used a daiso mallet, realised I dun have a proper hammer. 2 Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 23, 2020 Share September 23, 2020 3 hours ago, Watwheels said: Talk is cheap but stainless steel is tough to do drilling. Your normal high speed steel drill bit might not be able to drill thru. It might burn and become chao tar, destroying your drill bit. You have to use drill bit that has Titanium coating aka gold colour coating. Thankfully Daiso sells them in limited sizes(don't have bigger size), still cheap at 2 bucks. They also sell stainless steel wires as well. https://www.carpentry-tips-and-tricks.com/drill-bits.html 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 23, 2020 Share September 23, 2020 1 hour ago, badlammy said: haha...used a daiso mallet, realised I dun have a proper hammer. Scare me. I tot you are a man of steel. hahhaa. Real man need tools. gotta upgrade your toolbox ya. hahah. Link to post Share on other sites More sharing options...
Kb27 Supersonic September 23, 2020 Share September 23, 2020 4 hours ago, badlammy said: haha...used a daiso mallet, realised I dun have a proper hammer. brother, you need a real man's hammer. 1 3 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 23, 2020 Share September 23, 2020 14 hours ago, Lala81 said: You going to get WiFi sockets/switches for your lights?Otherwise not much point for electrical outlets. Oh ...... generally, I would not use technologies like WiFi for permanent fixture lor. It is because these type of technologies tends to change quickly. I already have a CHEAP Xiaomi Gateway for IoT like Temperature and Humidity, Doors and Windows Security, planning to add sensor for Plant water and light sensor and PM2.5 sensor. AWESOME. What I am talking about previously is measuring current using a simple current transformer, feed to a SIMPLE Computer like raspberry pi or something and off it go to the cloud lor. Together with voltage I can monitor PF la, kWh la then hor use some analytics to correlate with WEATHER .....ya .... If I too busy, then shelve it lor by disconnecting from the DB box lor. OR don't implement it at all. It depend on WFH till when lor. My company confirm at LEAST WFH until end of the year lor. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 23, 2020 Share September 23, 2020 3 hours ago, t0y0ta said: https://www.carpentry-tips-and-tricks.com/drill-bits.html Those for drilling ceramic tiles missing. Important for walls like in the kitchen or bathroom. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 23, 2020 Share September 23, 2020 9 minutes ago, Volvobrick said: Those for drilling ceramic tiles missing. Important for walls like in the kitchen or bathroom. I haven't tried one of these for ceramic and glass. There's also a diamond tipped hole borer I think. Right now, I just use the SDS bit and blast through the tile and wall. 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 23, 2020 Share September 23, 2020 47 minutes ago, Kb27 said: I haven't tried one of these for ceramic and glass. There's also a diamond tipped hole borer I think. Right now, I just use the SDS bit and blast through the tile and wall. I used it on ceramic tiles and homogeneous tiles. It worked without cracking them. 1 Link to post Share on other sites More sharing options...
Alpha78 6th Gear September 24, 2020 Share September 24, 2020 14 hours ago, badlammy said: The previous one is handle kind, round knob is new. I did try to find the catch, really dun have. That small dent u see in the pic nothing to press in. The catch to dismantle the lock is usually on the inside, meaning the side with the twist or push lock knob. Useless lock if it can be dismantled from the outside. Anyway, I see you replaced with an atas Yale lock. Mr DIY sells door knob sets starting from $6+. ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home repair advice needed
Home renovation tips
Wheel Spacer Installation DIY
