Jtb 6th Gear June 29, 2021 Share June 29, 2021 https://www.lazada.sg/products/a-b-power-glue-i1016448996-s3735410618.html?spm=a2o42.searchlist.list.1.25fa4483KAevVe&search=1 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kklim Supercharged August 5, 2021 Share August 5, 2021 (edited) Anyone knows how I can disable the dimming function on this?https://ibb.co/xF5PVs1 On/off switch is to left of the dimmer knob. Bypass the knob and wire straight to switch? Edited August 5, 2021 by Kklim Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 5, 2021 Share August 5, 2021 (edited) 13 minutes ago, Kklim said: Anyone knows how I can disable the dimming function on this?https://ibb.co/xF5PVs1 On/off switch is to left of the dimmer knob. Bypass the knob and wire straight to switch? Probably. Or just spend a few dollars get a new 3 gang switch. Remember to switch off at the DB first. Me also never use the dimmers as all the old tungsten bulbs have been replaced by CFL or LED. But I just leave the dimmer knobs at max. There are more important things to worry about. Maybe you can glue the knob at max so no itchy finger can change it! Edited August 5, 2021 by Volvobrick Link to post Share on other sites More sharing options...
Victor68 Turbocharged August 5, 2021 Share August 5, 2021 19 minutes ago, Kklim said: Anyone knows how I can disable the dimming function on this?https://ibb.co/xF5PVs1 On/off switch is to left of the dimmer knob. Bypass the knob and wire straight to switch? If you are not good with elect, don't lah. Just leave it at max or buy dimmable LED bulbs. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 5, 2021 Author Share August 5, 2021 On 6/29/2021 at 11:30 AM, mersaylee said: The inner grout lines may be still damp when you apply anything. Keep it out of bound for a day or use hairdryer to heat up the lines before application with sealant property. Horme should have... https://www.horme.com.sg/ Don't you all need to remove the grout to get a good application? I no practical experience. That's what youtube shows me. Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 5, 2021 Share August 5, 2021 2 minutes ago, Lala81 said: Don't you all need to remove the grout to get a good application? I no practical experience. That's what youtube shows me. I lazy...just paste over the gap when it's dry 😁 Good quality type would last a long time... Link to post Share on other sites More sharing options...
Karoon Turbocharged August 5, 2021 Share August 5, 2021 (edited) Anyone could recommend a cheap, durable transparent electric kettle? Bought ones from Giant, NTUC etc (already 3) with 1 year warranty and they each die after a year. (Need transparent to give comfort its not a gecko pool) Tried diy troubleshoot using multimeter. The problem is always the toggle switch. You can remove it and give it a hammer, it will work for a few more days, then die. Edited August 5, 2021 by Karoon 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 5, 2021 Author Share August 5, 2021 Just now, Karoon said: Anyone could recommend a cheap, durable boiler jug? Bought ones from Giant, NTUC etc (already 3) with 1 year warranty and they each die after a year. Tried diy troubleshoot using multimeter. The problem is always the toggle switch. You can remove it and give it a hammer, it will work for a few more days, then die. I dunno what's your definition of cheap. They all tend to spoil after a few years IMO. I'm on my 3rd electrical kettle. Each lasts about 2+ years. Had philips, taiyo. Now using a cornell one which I'm the most pleased with. About 50+ Link to post Share on other sites More sharing options...
Karoon Turbocharged August 5, 2021 Share August 5, 2021 9 minutes ago, Lala81 said: I dunno what's your definition of cheap. They all tend to spoil after a few years IMO. I'm on my 3rd electrical kettle. Each lasts about 2+ years. Had philips, taiyo. Now using a cornell one which I'm the most pleased with. About 50+ Cheap for this equipment would be below $30. Unfortunately the ones i own really really few years. Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 5, 2021 Author Share August 5, 2021 (edited) 1 minute ago, Karoon said: Cheap for this equipment would be below $30. Unfortunately the ones i own really really few years. Well the ones i buy are about 50-60 dollar types. So ROI is roughly the same lah My first jug damaged something in the DB box when it shorted. Lol cost me money to repair somemore. My 2nd jug i think something went wrong cos it started heating up the exterior and handle abnormally so decided to junk it for safety. Edited August 5, 2021 by Lala81 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 5, 2021 Share August 5, 2021 13 minutes ago, Karoon said: Anyone could recommend a cheap, durable transparent electric kettle? Bought ones from Giant, NTUC etc (already 3) with 1 year warranty and they each die after a year. (Need transparent to give comfort its not a gecko pool) Tried diy troubleshoot using multimeter. The problem is always the toggle switch. You can remove it and give it a hammer, it will work for a few more days, then die. I repaired my kettle twice for the same problem. Broken plastic part or dislodged thermal sensor. Already standby a new one in the store room. Have to standby as I want one with an analogue thermometer which is harder to find. Suggest you just buy cheap ones online. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 5, 2021 Share August 5, 2021 19 minutes ago, Lala81 said: I dunno what's your definition of cheap. They all tend to spoil after a few years IMO. I'm on my 3rd electrical kettle. Each lasts about 2+ years. Had philips, taiyo. Now using a cornell one which I'm the most pleased with. About 50+ Giant ones can be 20 or less.... Link to post Share on other sites More sharing options...
Lala81 Hypersonic August 5, 2021 Author Share August 5, 2021 (edited) 3 minutes ago, Volvobrick said: Giant ones can be 20 or less.... I see. Since i boil water everyday, don't mind paying bit more. Haha i always hear people curse at powerpac stuff or what not. Though i like Powerpac torches Edited August 5, 2021 by Lala81 1 Link to post Share on other sites More sharing options...
Victor68 Turbocharged August 5, 2021 Share August 5, 2021 (edited) I use mine at least once a day. It last a few years. What could be the problem ? The way you handle it , like washing or something? That may solve your long term problem. Edited August 5, 2021 by Victor68 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged August 5, 2021 Share August 5, 2021 1 hour ago, Lala81 said: Don't you all need to remove the grout to get a good application? I no practical experience. That's what youtube shows me. It depends. If the grout is fully filled to the top of the tile then need to scrap a few mm off. If it's half filled, you can apply directly on top. But I will still scrap a bit off for better adhesion. 1 Link to post Share on other sites More sharing options...
Karoon Turbocharged August 5, 2021 Share August 5, 2021 3 hours ago, Lala81 said: I see. Since i boil water everyday, don't mind paying bit more. Haha i always hear people curse at powerpac stuff or what not. Though i like Powerpac torches Yup. My latest that broke down is a powerpac. Link to post Share on other sites More sharing options...
Ahwhye 6th Gear August 5, 2021 Share August 5, 2021 5 hours ago, Karoon said: Anyone could recommend a cheap, durable transparent electric kettle? Bought ones from Giant, NTUC etc (already 3) with 1 year warranty and they each die after a year. (Need transparent to give comfort its not a gecko pool) Tried diy troubleshoot using multimeter. The problem is always the toggle switch. You can remove it and give it a hammer, it will work for a few more days, then die. if you scare gecko getting into the kettle, can consider this one https://www.philips.com.sg/c-p/HD9316_03/viva-collection-kettle it has a strainer or filter or whatever you called that at the spout, can block out creepy crawly. using one, few year liao pretty lasting 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 5, 2021 Share August 5, 2021 I got this from Popular bookstore for $27.90 when it’s on sale. Brand is Sona. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home repair advice needed
Home renovation tips
