Playtime Supersonic October 28, 2021 Share October 28, 2021 41 minutes ago, Fcw75 said: It’s time to give them the adhesive remover and tell them You know what to do kids. 😁 Prepare for NS early ah ? 🤣🤣 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 28, 2021 Author Share October 28, 2021 (edited) My study table arrived from ezbuy. What's the safest way to open these? I have regular claw hammer but I don't have a crow/prybar. Scrap wood frame done with nails. Bought some cotton gloves earlier. Lol scared of splinters. Edited October 28, 2021 by Lala81 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic October 28, 2021 Share October 28, 2021 Try using a flat screwdriver and hammer it in between the wood to create a gap before using the claw hammer. Less likely to damage the surface. 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 28, 2021 Share October 28, 2021 The claw of the hammer or a chisel is sufficient to remove the tie up. Just need to break the shorter side...lay it flat on the floor first...🤕😁 1 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged October 28, 2021 Share October 28, 2021 27 minutes ago, Lala81 said: My study table arrived from ezbuy. What's the safest way to open these? I have regular claw hammer but I don't have a crow/prybar. Scrap wood frame done with nails. Bought some cotton gloves earlier. Lol scared of splinters. Any fw around? Ask them for help w a small token. Lol. 2 Link to post Share on other sites More sharing options...
Kklim Supercharged October 28, 2021 Share October 28, 2021 On 10/27/2021 at 11:14 AM, Fcw75 said: Get the 3M adhesive remover bro and the stains won’t be an issue. Other brands also can. WD40 too 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 29, 2021 Share October 29, 2021 This is kinda repair. My IKEA easy chair is constantly coming apart/screws are loosen, I think it's due to me moving it around. The mortise and tenon joint comes apart. So I disassemble the whole chair and glue all the joints and dowels together with wood glue. Now the chair is more stable and "locked" together. Damaged allen head furniture screws after using for sometime. It can be removed by appropriate size torx if need be. 5 Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 29, 2021 Author Share October 29, 2021 (edited) 13 hours ago, mersaylee said: The claw of the hammer or a chisel is sufficient to remove the tie up. Just need to break the shorter side...lay it flat on the floor first...🤕😁 Quite funny. The delivery guy (PRC) brought it over and leaned it against the wall and it started to come upright again and i quickly supported it before readjusting the base outwards to lean more against the wall. Then he say "don't worry, wont topple one" in mandarin. I'm like "..." Not sure sure where your false confidence came from since its such a narrow base and unsupported if it is upright. Edited October 29, 2021 by Lala81 4 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 29, 2021 Share October 29, 2021 8 minutes ago, Lala81 said: Quite funny. The delivery guy (PRC) brought it over and leaned it against the wall and it started to come upright again and i quickly supported it before readjusting the base outwards to lean more against the wall. Then he say "don't worry, wont topple one" in mandarin. I'm like "..." Not sure sure where your false confidence came from since its such a narrow base and unsupported if it is upright. That's ah tiong alright 😂 Bochup bohiu bo his pasar 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged October 29, 2021 Share October 29, 2021 On 10/27/2021 at 11:12 AM, Kb27 said: Did you try oil ? Any kind, cooking oil, mineral oil. See how it works. I think the adhesive will come off easily. The best way to remove sticky stuff is use gasoline, it will sure come out Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 29, 2021 Share October 29, 2021 40 minutes ago, Kb27 said: This is kinda repair. My IKEA easy chair is constantly coming apart/screws are loosen, I think it's due to me moving it around. The mortise and tenon joint comes apart. So I disassemble the whole chair and glue all the joints and dowels together with wood glue. Now the chair is more stable and "locked" together. Damaged allen head furniture screws after using for sometime. It can be removed by appropriate size torx if need be. If no wood glue available, can also insert a few toothpicks into the slot before forcing the joining part in. Link to post Share on other sites More sharing options...
Arogab Turbocharged October 29, 2021 Share October 29, 2021 6 minutes ago, Arogab said: The best way to remove sticky stuff is use gasoline, it will sure come out But I forgot to remind, be vry careful hor, no fire 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator October 29, 2021 Share October 29, 2021 19 hours ago, Lala81 said: My study table arrived from ezbuy. What's the safest way to open these? I have regular claw hammer but I don't have a crow/prybar. Scrap wood frame done with nails. Bought some cotton gloves earlier. Lol scared of splinters. I will use a hammer and a minus screw driver. knock knock then pry a bit then knock knock. Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 29, 2021 Author Share October 29, 2021 On 10/28/2021 at 7:45 PM, Lala81 said: My study table arrived from ezbuy. What's the safest way to open these? I have regular claw hammer but I don't have a crow/prybar. Scrap wood frame done with nails. Bought some cotton gloves earlier. Lol scared of splinters. With just a chisel screw driver and a claw hammer, took damn long to get this open man. Between this and the other smaller legs package, took me one hour to pry this open with one person. This table surface frame was difficult to pry open. There was one joint which took me ten mins just to get open. Comparatively the legs section one the nails were easier to pry apart. Part of this time was also reducing risk of injury. lot of exposed nails from the pieces I pried away. Which I had to hammer down to reduce risk of hurting anyone handling it later. Splinters everywhere. Had to use broom then vacuum. Lucky I had some foresight to order cotton gloves from horme when I bought stuff. Gloves have multiple splinters. One pair of cotton gloves chui by the end with multiple splinters. So not even tried to assemble it yet. That took up the free time I had today. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic October 29, 2021 Share October 29, 2021 11 hours ago, Lala81 said: Quite funny. The delivery guy (PRC) brought it over and leaned it against the wall and it started to come upright again and i quickly supported it before readjusting the base outwards to lean more against the wall. Then he say "don't worry, wont topple one" in mandarin. I'm like "..." Not sure sure where your false confidence came from since its such a narrow base and unsupported if it is upright. Haha typical response. Like our Malaysian mechanics. Till shit happens. Link to post Share on other sites More sharing options...
Mkl22 Supersonic October 29, 2021 Share October 29, 2021 24 minutes ago, Lala81 said: With just a chisel screw driver and a claw hammer, took damn long to get this open man. Between this and the other smaller legs package, took me one hour to pry this open with one person. This table surface frame was difficult to pry open. There was one joint which took me ten mins just to get open. Comparatively the legs section one the nails were easier to pry apart. Part of this time was also reducing risk of injury. lot of exposed nails from the pieces I pried away. Which I had to hammer down to reduce risk of hurting anyone handling it later. Splinters everywhere. Had to use broom then vacuum. Lucky I had some foresight to order cotton gloves from horme when I bought stuff. Gloves have multiple splinters. One pair of cotton gloves chui by the end with multiple splinters. So not even tried to assemble it yet. That took up the free time I had today. You need a pair of reinforced gloves. The cotton ones don’t cut it. Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 29, 2021 Author Share October 29, 2021 3 minutes ago, Mkl22 said: You need a pair of reinforced gloves. The cotton ones don’t cut it. Hmmm OK lah. Don't do this for a living or often. The cotton gloves are good enough. Just use and throw. I'm already reconsidering whether I want to go through this again if I order a study table for my two kids. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 30, 2021 Share October 30, 2021 14 hours ago, Lala81 said: Hmmm OK lah. Don't do this for a living or often. The cotton gloves are good enough. Just use and throw. I'm already reconsidering whether I want to go through this again if I order a study table for my two kids. I use cut resistant gloves, keep a pair or 2 around the house. It is very useful. https://shopee.sg/Cut-Resistant-Gloves-Anti-Cutting-Food-Grade-Level-5-Kitchen-Butcher-Protection-i.92566917.1733357482 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home repair advice needed
Home renovation tips
Wheel Spacer Installation DIY
