Saj
Knocking sound from wheels (under carriage)
1st Gear (edited)
My Hyundai Avante (70,000km) is giving me this issue and seeking advice from anyone who have experienced this before.
Six months ago, I observed a knocking sound coming briefly (about 2-3 seconds) from the front driver-side wheel area whenever I start moving off the car in the morning. The sound disappears after that till next morning. So I ignored it. However, last few months I have been driving long distance daily (~200km) and the problem has been getting worse. The sound is very frequent every time I make a turn and very obvious at slow speed. I could not notice this sound when driving in expressways. From yesterday evening, the front left wheel side started giving the knocking sound and it continues even in higher speeds/expressways and now the issue is a nuisance and I need to fix this.
1)  Is it a risk if I continue driving with this issue?
2) What could be the cause of this issue?
3) Any reliable and reasonable workshop that specializes in Korean Cars/this type of issue?
Thank you in advance!
Edited by Saj
Share this post
Supersonic
Could be upper/lower mounting, or bushings. No immediate danger but will cause uneven tyre wear.
  • Praise 4
Share this post
Moderator
Yeah. It is bushing or mounting. No hazard in driving, maybe just uncomfortable only.
I will recommend changing the whole set. The labour cost is more than the replacement parts.
Where do you stay? Maybe I can recommend somewhere near you. No point travelling so far for the repair.
Quote
- This is wear and tear issue lah. Nothing serious. Some last longer, some give way faster. 70K consider good le.
  • Praise 3
Share this post
Twincharged
Sounds like worn bushings on the anti-sway bars
Simple job any ws can settle, no need kimchi car specialist (if got such specialist to start with..)
  • Haha! 2
Share this post
Supersonic
if road is even for example on expressway there is no sound, but once u go on uneven road, got kikikokok sound, u can try changing the absorber linkage and the coffin bush first ( cos this 2 very cheap, even if try and error wrong wont cost u much)
if moving got no sound, but at stationary position u turn the steering wheel left and right got kikokiko, could be the tie rod and rack end,
absorber and absorber mount some time also got sound.
but the best thing is visit a ws let them take a look,
even the best doctor cannot cure your illness with just a few sentence right??😁
  • Praise 2
  • Haha! 1
Share this post
Moderator
Good to find a workshop that has the press machine also lah. If not the workshop have to go to another workshop to borrow the press machine. hahaha.
Share this post
Twincharged
Could be lower arm  shocks , drive shafts also, this type of problems can be diagnosed and  check by a mechanic.
  • Praise 2
Share this post
1st Gear
I stay in North-West. My current workshop could not diagnose/solve the issue during last servicing
Can anyone recommend a reliable workshop in Bt Batok, Toh Guan, CCK, Woodlands area?
Share this post
Moderator
I will recommend J's Racing. haha. Can look for boss joe.
Share this post
Hypersonic
This one kimchi expert 'Grand master' Kim Soon-ja,
:grin:
Share this post
1st Gear
Thanks everyone for your responses.
Here's an update:
Komoco checked the car and proposed to replace the following parts:
  • Front Strut (absorber) LH and RH
  • Front Bumper x 2
  • Lower Arm LH and RH
  • Ball Joint x 2
  • Front Link x 2
  • Front Bush x 2
  • Front Top Mounting
  • Rear Absorber x 2
  • Rear Bumper x 2
  • Rear Link x 2
  • Rear Bush x 2
  • Assist Arm x 2
  • Rear Top Mounting x 2
Price quoted: Parts $2,882 and Labor $760. Total $3,642
A workshop in Bukit Batok checked and proposed to replace almost the same parts (except for Rear top mounting)
Price quoted: Parts (some are original and other parts are Korean) and Labor (including wheel alignment)  Total $1,508
Job was done and test drive in 4hrs. No more sounds. Drive is as smooth as brand new!😀
  • Praise 5
  • Haha! 1
Share this post
6th Gear
Since your car so old... change outside is more worthwhile...
Share this post
Supercharged
Here's an update:
  • Front Bumper x 2
  • Ball Joint x 2
  • Front Link x 2
  • Front Bush x 2
  • Rear Absorber x 2
  • Rear Bumper x 2
  • Rear Link x 2
  • Rear Bush x 2
  • Assist Arm x 2
Does both workshop know what they are doing?
Basically they are both proposing to change EVERYTHING that can be changed in all suspension parts.
I didn't know it was this easy to earn money
  • Haha! 2
Share this post
4th Gear
Most impt spent the money and problem solved. Not many Coe car owners so lucky. And considering the age, it’s worth to change all together. U save time and labour again down the road.
  • Praise 3
Share this post
6th Gear
The mechanics from both workshops took a look and inspected the car, you didn't... so on the balance it would seem advisable to listen to them and expect that they know what they are doing...
Share this post
Hypersonic
On the hind sight, it would be good to change most under carriage wear and tear parts to get optimal performance.
Made good business sense too, of course.
Share this post
