yellowshaun 4th Gear July 4, 2021 Share July 4, 2021 Hi shifus. My sis just went to buy this fella. Any common problems to look out for? ↡ Advertisement 1 2 Link to post Share on other sites More sharing options...
13177 Hypersonic July 4, 2021 Share July 4, 2021 27 minutes ago, yellowshaun said: Hi shifus. My sis just went to buy this fella. Any common problems to look out for? Make sure this fella is not PHV. 😅 4 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 4, 2021 Share July 4, 2021 (edited) 1 hour ago, yellowshaun said: Hi shifus. My sis just went to buy this fella. Any common problems to look out for? Looks like a frog if you don't mind it. Actually, one of the nicer model. LOL This "wide" mouth is not so big and wide and doesn't look "locked" jaw unlike many current car models. Edited July 4, 2021 by Kangadrool 3 Link to post Share on other sites More sharing options...
Ceecookie 5th Gear July 4, 2021 Share July 4, 2021 (edited) 3 hours ago, yellowshaun said: Hi shifus. My sis just went to buy this fella. Any common problems to look out for? Fuel economy is not good - this model comes with the pre-skyactiv engines which give average 8-9km/l fc. Edited July 4, 2021 by Ceecookie 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 4, 2021 Share July 4, 2021 (edited) 2 hours ago, Kangadrool said: Looks like a frog if you don't mind it. Actually, one of the nicer model. LOL This "wide" mouth is not so big and wide and doesn't look "locked" jaw unlike many current car models. You're so kind...😁 Edited July 4, 2021 by mersaylee 24 Link to post Share on other sites More sharing options...
Xer Neutral Newbie July 4, 2021 Share July 4, 2021 Gearbox problem for this model my colleague and mine both had the same gearbox problem at our 8th yr around 150k mileage. You google FN4A it's a common problem. My rpm would suddenly rev up to 5k while driving but the car remains same speed almost like engine and gearbox disconnected and the no load engine rev went shooting up. Link to post Share on other sites More sharing options...
yellowshaun 4th Gear July 4, 2021 Author Share July 4, 2021 11 hours ago, 13177 said: Make sure this fella is not PHV. 😅 Yes have done due diligence to check that out =D 52 minutes ago, Xer said: Gearbox problem for this model my colleague and mine both had the same gearbox problem at our 8th yr around 150k mileage. You google FN4A it's a common problem. My rpm would suddenly rev up to 5k while driving but the car remains same speed almost like engine and gearbox disconnected and the no load engine rev went shooting up. Thanks this is very helpful! Still got a bit to go to 150k =D 1 Link to post Share on other sites More sharing options...
yellowshaun 4th Gear July 4, 2021 Author Share July 4, 2021 So far the noticeable issue is that the air con only gets cold upon cruising. When idle just normal temp air comes out even at min temp and max fan. Link to post Share on other sites More sharing options...
UncleAtas Turbocharged July 5, 2021 Share July 5, 2021 8 hours ago, yellowshaun said: Yes have done due diligence to check that out =D Thanks this is very helpful! Still got a bit to go to 150k =D Did you guys send it to your preferred workshop to inspect the car? Mileage can always be adjusted. Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 5, 2021 Share July 5, 2021 9 hours ago, Xer said: Gearbox problem for this model my colleague and mine both had the same gearbox problem at our 8th yr around 150k mileage. You google FN4A it's a common problem. My rpm would suddenly rev up to 5k while driving but the car remains same speed almost like engine and gearbox disconnected and the no load engine rev went shooting up. Only 150k? Toyota beats that anytime. Link to post Share on other sites More sharing options...
Mkl22 Supersonic July 5, 2021 Share July 5, 2021 8 hours ago, yellowshaun said: Yes have done due diligence to check that out =D Thanks this is very helpful! Still got a bit to go to 150k =D That’s assuming the mileage display is accurate. Most of the time mileage has been clocked! Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 5, 2021 Share July 5, 2021 (edited) 9 hours ago, Xer said: Gearbox problem for this model my colleague and mine both had the same gearbox problem at our 8th yr around 150k mileage. You google FN4A it's a common problem. My rpm would suddenly rev up to 5k while driving but the car remains same speed almost like engine and gearbox disconnected and the no load engine rev went shooting up. close to 150k km and above is wear and tear though slightly early , not a product reliability or design concern. Edited July 5, 2021 by Ct3833 Link to post Share on other sites More sharing options...
Tommisan 4th Gear July 5, 2021 Share July 5, 2021 9 hours ago, yellowshaun said: So far the noticeable issue is that the air con only gets cold upon cruising. When idle just normal temp air comes out even at min temp and max fan. I had the same issue with my previous car, not Mazda 3. Best to check the aircon system, especially the compressor. Link to post Share on other sites More sharing options...
yellowshaun 4th Gear July 5, 2021 Author Share July 5, 2021 Haha yes thanks did check the condition of the leather seats, esp the left passenger seat. Very firm still all around. Other "150,000km" cars the seats were very sunken in. Also no stain of rectangular PHV decal, only round decal stain. If anybody use this car for PHV, he must be quite rich lo the FC as you guys mentioned is like 9km/l. =D I've taken PHV very often, so I am quite familiar with the sights and sounds inside a 300,000km/400,000km car. Only gave my sis green light to buy when I was sufficiently happy with the condition. Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator July 5, 2021 Share July 5, 2021 22 hours ago, yellowshaun said: Hi shifus. My sis just went to buy this fella. Any common problems to look out for? Lake View? Link to post Share on other sites More sharing options...
yellowshaun 4th Gear July 5, 2021 Author Share July 5, 2021 (edited) 31 minutes ago, BabyBlade said: Lake View? I have to give you credit ah Ms Moderator. Indeed the view from the lake is a good guess. Google reverse image search? =D Edited July 5, 2021 by yellowshaun Link to post Share on other sites More sharing options...
Ceecookie 5th Gear July 5, 2021 Share July 5, 2021 12 hours ago, Xer said: Gearbox problem for this model my colleague and mine both had the same gearbox problem at our 8th yr around 150k mileage. You google FN4A it's a common problem. My rpm would suddenly rev up to 5k while driving but the car remains same speed almost like engine and gearbox disconnected and the no load engine rev went shooting up. Thanks for sharing! I previously drove a used unit from 7-9 years old. Gearbox encountered the exact issue that below user described (gear 2-3). Mileage was rolled back so can't determine the true mileage the GB failed, but should be somewhere between 200-250k mark. https://www.focaljet.com/threads/shifting-problem.548406/post-6055418 Link to post Share on other sites More sharing options...
macrosszero Turbocharged July 5, 2021 Share July 5, 2021 I think TS got the order wrong, should ask for advice before telling sister to buy or not. Asking around after buying is just looking for endorsement. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
MAZDA 6
MAZDA 6
2026 Mazda EZ-60 / CX-6e
Bought a pre-owned Toyota in 2025? Get Your Free Servicing Here!
Mazda FC3S RX-7
Mazda FC3S RX-7
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
Bought a pre-owned Lexus in 2025? Get Your Complimentary Servicing Here!
