CAI - My version
Andrewkb
Yeah ... very simple .. just a 330Ohm resistor, 1 super bright LED. ... find the VTEC cable from ECU (I figured that it's output, so it shouldn't short the ECU) so hook it up and now it works !!! [:)]
Actually there are tons of DIY articles out there [:p] I just follow step by step ...
Took me a while before I had the courage and figured that I shouldn't cork up that bad to mess up the ECU :-P
Ask me to do on another car is a diff story ...
So far ok ... but I put my hand there, when radiator fan is blowing ....can feel air blowing OUT of the snorkel !!!
Huh ??? Blowing OUT ?
Look at this pic ... the WRC Rally car has air ventilation on the roof ... similar to my undercarriage scoop ... so I guess Venturi effect doesn't apply here ?
So air will still go into the intake instead of being SUCKED out ?!
OK got it....need a LED with 330 ohm resistor , negative side to ground and the other to the ECU side which is the yellow/grren stripped wire......and that's it....right?
Simple as that!!!
You can either find the pin on the ECU or tap from the VTEC Solenoid ...
BTW, you got a Honda ??
Aiyah ... power to weight ratio .. U still win [sly]
Tried a AR156 and left a deep impression in me .. till today ... maybe 10yrs later .. can buy one COE AR156 as leisure car ... err .. provided the economy is going uphill for the next 10 yrs [bigcry]
