Vtim 3rd Gear August 6, 2003 Share August 6, 2003 on a stream....dun pray pray i tell you......that stream move off veli the fast hor yes, very fast for a Stream 120+ on the wheel, about 180 on the crank ↡ Advertisement Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie August 6, 2003 Share August 6, 2003 ah...got it....now for Q&A......leaving it at the end of the compartment seems to be sucking the hotair thats raising while its moving......wouldn't it be better to put in front? i go tapau first, just back from meeting and another at 1.30....damn sian Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie August 6, 2003 Share August 6, 2003 wah dyno liao ah Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 Err ... why mine so slow huh ... Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 6, 2003 Share August 6, 2003 yes, he even have the print out Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 It sits as a snorkel on top of the bonnet ... so the heat passes BEHIND the intake ... the front protrude out onto the bonnet ... machiam like WRX kind lah .. but smaller and thinner slit ... Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 6, 2003 Share August 6, 2003 I wonder it will have enough air for high speed driving as the air should be of less pressure on the bonnet surface Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 6, 2003 Share August 6, 2003 (edited) Andrew, My advice.. since with all the various pattern of CAI you have, how do you know whether it works ? I suggest you get a Air-FUel Meter to monitor the riches at various RPM, Speed to determine... and also a ext thermometer in your air-box to monitor the temperature. How I troubleshoot is using the Air-Fuel Meter and Thermometer. Every mornig I travel the same scratch of road and I see how the fuel behaves... Different angle produces different mass intake, and the length of the tube matters. my 2 cents.. else without AF Meter, you don't know if you are too rich or lean. (besides having the right temperature position). All the above method is based on On the road Layman troubleshooting.. of cos if you have a OBD reader hook up while driving is the best.. Edited August 6, 2003 by Cool Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 Dyno showed 10PS improvement and slight torque improvement. But that's dyno, not on the road. Tell you what, I sacrify my car ... you pay $$$ to buy the set, I sacrify to install in my car and let you experiment. OK Hehehehe ... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 OBD reader cost too much ... Where does the AF meter hook to ? I would be interested to get one ! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 6, 2003 Share August 6, 2003 I see... Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 6, 2003 Share August 6, 2003 OBD is a joke lar.. crazy to own one.. My experience was this.. the last trip to MErsing, at full throttle at 180, my AF meter shows me very rich. (i.e. not enuff air), I had to rip of the con firewall to achieve 10% of stoich... So when you position, your CAI, layman gauge is idle RPM should be abuot 780rpm, runnning lean but no knocking. My CAI was open pod directly to the fog light opening..so my idle had vast different..and eventally, I used E-manage to adjust my idle RPM. However, at full throttle, it is difficult. I had to hear from engine knocking (i have the device), relie on the AR Meter to give me a acceptable reading. No way you can adjust the position of the CAI on the run Attached is a AF Meter.. I am using AutoMeter, open pod is APEXI dual tunnel and Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 6, 2003 Share August 6, 2003 Tap from the O2 sensor at your exhaust manifold or just before the catalytic converter...if not tap from ECU also can... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 I know people who own OBDII reader .. simple one .. that's how I know my Engine Coolant Temperature. See this: http://www.techtom.co.jp/cmx100.html Else, those PDA type ..software + cable also US$300 More gilat products: http://www.techtom.co.jp/FCM2000.html Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 6, 2003 Author Share August 6, 2003 Now I gotta rely on your for the ECU pin Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 6, 2003 Share August 6, 2003 that's a BIG sacrify on my part TKK hor! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 6, 2003 Share August 6, 2003 I also don't know, got to check around liao... Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 6, 2003 Share August 6, 2003 he got Buddy-Club ECU, mini-compressor & lots of other thing added in ↡ Advertisement Link to post Share on other sites More sharing options...
Google Maps latest version
Different version of 3M Clay Bar
Which version of 倚天
Which version of 倚天
Subaru S204 sti version 9 limited edition show piece car
Mitsubishi Colt Version R discussion
Toyota Corona (Big backside version)
Which version of the iPhone 6/7/8/n..would you rather own?
Bill gates invented NEWater
