  • Search this thread
  • Reply to this topic
22 replies to this topic | 15 praises
#1
Posted 16 August 2019 - 12:28 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
I have a weird AC Issue.
It doesn’t occur in Singapore as drive max is only 1 hour+
Last Long weekend I went to Malaysia and drove my vehicle for 5 6 hours non stop. At around 120 to 150km/h
Ac seems to not work after 3 4 hours of driving and was blowing out not so cold air. Front driver seat was fine but passenger is suffering.
Upon reaching Singapore. Speed was reduced to 90 100km/h. AC start to blow out freezing cold air again.
Temp gauge was half way point which is normal. Coolant EO all in its reasonable limit
At the point of time. NSHW outside temperature is about 38 to 40c range
Edited by Lightsabre, 18 August 2019 - 11:08 AM.
#2
Posted 16 August 2019 - 01:26 PM
Jtb
  • Premium member
    Jtb
    6th Gear
    Author Image
    3,639
fresh or circulation mode
#3
Posted 16 August 2019 - 01:57 PM
Optramagnum
  • Premium member
    Optramagnum
    6th Gear
    Author Image
    2,748
Sound eerie esp when it is 7th month now.. Hahaha, just joking.
My guess is that the temp of coolant is too high for the radiator to cool it down after prolong high speed driving. Quite common.
#4
Posted 16 August 2019 - 04:29 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,700
A lack of refrigerant.
You should get it check for leaks. If no leak then flush out the old and replenish the refrigerant.
Feel so rich. Or just an illusion?
#5
Posted 16 August 2019 - 09:56 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
But the C And H needle did not move at all. Is it normal? All the way at half way point
Edited by Goldenvodka, 16 August 2019 - 09:56 PM.
#6
Posted 17 August 2019 - 06:56 AM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,368
i would think is your radiator and condensor issue. as they age the fins maybe clog with dirt and dust and probably oil causing the optimal efficency of the radiator and condensors.
this is normal i guess as the fins and coils inside cannot disperse the heat properly hence is hot. travelling at 120-150kn/hr does helps the colling down of engine but likely cause is still narrow down to radiator and condenser aging.
moreover AC system also is linked to both radiator and condensor as part of one system.
just my 2 cents thoughts.
Edited by StreamRSZ, 17 August 2019 - 06:57 AM.
#7
Posted 17 August 2019 - 07:12 AM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,829
Is the volume or air coming out still the same? Then it isn’t a frozen evaporator. Then likely compressor issue or the compressor clutch not engaging at higher rpm.
#8
Posted 17 August 2019 - 07:30 AM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
Is the volume or air coming out still the same? Then it isnât a frozen evaporator. Then likely compressor issue or the compressor clutch not engaging at higher rpm.
Did not feel any difference in air flow.
I Guess for the time being just live with it. No point changing the compressor at this moment
Did a small test in the carpark. When vehicle is idling. Ac works fine with compressor engaged and fan spinning normally
Edited by Goldenvodka, 17 August 2019 - 07:34 AM.
#9
Posted 17 August 2019 - 07:33 AM
Flying_genie
  • Flying_genie
    5th Gear
    Author Image
    2,306
Outside temperature so high? Doesn’t sound right. You may have a faulty thermostat.
#10
Posted 17 August 2019 - 07:44 AM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    17,693
I think it is likely the compressor too. if you dont go NSHW or long duration driving too often, I dont think you will face the problem again. Next time if you fcce the problem again, you may want to find a rest point to let the compressor cool down for a while before you drive on and see if it helps improve the situation.
Edited by Ct3833, 17 August 2019 - 07:45 AM.
#11
Posted 17 August 2019 - 01:21 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
Can it be engine heat is too strong causing air conditioning is not performing normally?
#12
Posted 17 August 2019 - 05:01 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,368
like what i mentioned, the issue could be your radiator and condensor. heat cannot properly escape due to aging radiator and condensor.
#13
Posted 17 August 2019 - 05:20 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,829
Eh? How can it be? Isn’t the airflow at 140kmh higher than 90kmh?
Pretty sure it’s compressor and gas related as the rpm at 140kmh is probably at least 4k vs 3k or less at 90kmh. The compressor used in the swift is clutch driven and not a variable displacement one.
Edited by Mkl22, 17 August 2019 - 05:28 PM.
Ct3833 praised this
#14
Posted 17 August 2019 - 07:55 PM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,368
maybe you are right also. but anyway if you dont often msia than just live with it. by right at 140km/hr engine should also be cool enough to cool down engine and also coolant.
TS can send to workshop to check on gas level. if gas level is not at the normal range than could be like what you say compressor issue.
But if the gas level is at the normal range than it could likely be something else as i mentioned.
Edited by StreamRSZ, 17 August 2019 - 07:56 PM.
#15
Posted 17 August 2019 - 08:14 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    69,129
Frankly asking here also make you confused with all the theories.
Bring to a aircon workshop better.
But since it’s working well here, just leave it.
#16
Posted 17 August 2019 - 09:01 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    17,693
Cannot be.
#17
Posted 18 August 2019 - 09:39 AM
Comage
  • Comage
    Clutched
    Author Image
    41
85% of the time, air con issues are due to a worn out compressor. For compressors, make sure to always get brand new and never salvaged or reconditioned parts.
#18
Posted 18 August 2019 - 10:19 AM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    69,129
I think you are exaggerating la. Maybe 50% of the time. There’s so many other components that make up the aircon system. Condenser, cooling coil, etc.
#19
Posted 19 August 2019 - 12:20 PM
spinergy25
  • spinergy25
    Author Image
    12
there's a possibility that the cooling cool is frozen at that period of time, thus halted the cooling effect.
at higher speed, your engine RPM is higher, and it spins your compressor at a higher RPM, pushing your compressor to cool the cooling cool faster and cooler until it reaches a freezing point, especially if AC temperature is set at the lowers (coolest).
next time, you can try, to adjust the temperature not so cold, thus allowing the thermostat to have some time gap to cool down before it keeps freezing the cooling coil.
Just sharing my old experience.
Edited by spinergy25, 19 August 2019 - 12:22 PM.
#20
Posted 20 August 2019 - 10:18 PM
Apple-Tree
  • Premium member
    Apple-Tree
    6th Gear
    Author Image
    2,609
Wah, so many pattern.
Actually, most compressor can only tahan up to 4500~5000rpm max.  Beyond that, either the compressor will break or the pressure become too high lor.
It is likely that the pressure become too high and the pressure sensor flagged to trip the compressor lor
And why pressure become too high, over fill of gas and even oil lor.
For me, I hardly or never top up gas or oil lor ...... and when I did, the evaporator died a few months after.  Of course, could be aging la, or already leaking.  This is really hor, beyond my scope lor.....
So, if aircon is already working, why fix it lor. No top up la, cleanse pipe la ..... whatever.  What ? Aircon got smell ? Just turn the temp to max for 5~10mins and all smell cooked lor ........
Dynamics Mechanic Pte Ltd
Tong Lee Wee Auto Acc Pte Ltd
Tong Lee Wee Auto Acc Pte Ltd  |  Rating   Submit Review
Reviewed by D_orai  |  2nd Gear
I was looking to change my incandescent turn signal light bulbs to LED ones so I chanced upon this shop while doing my tyre rotation at a nearby shop. I went into the office to enquire about the availability of the LED bulbs and the owner of the shop (presumably) tried to find the bulb from the wide collection he had in stock. After which, he claimed that he had the bul... » Read More
Reviewed by Vinceng  |  NOS-ed
Sent a sms to enquire about magnetic sun shade and no reply. Called the mobile number and there was no answer. But no regrets as I got what I wanted at a much cheaper price elsewhere.
Related Motor Directory search on sgCarMart.com : Air Conditioning
Quick Reply
Tags: speed, suzuki, issues and 1 more...
