Mustank Hypersonic January 15, 2018 Share January 15, 2018 i was replacing my old esmaco (17 yrs liao) fan......easier to fix as can use back the older anchor bolts from the older mounting. If no have.....cialat! Got to tap the electrical and lay down the wiring! Kana zap a few times while fixing the fans and led lights....ððð can.....need a bit of experience thats all. Helped my friend to mount my 1st fan, then 2nd wan did it own my own and this wan also. Maybe I should use the skill future fund to learn ↡ Advertisement Link to post Share on other sites More sharing options...
Evillusion Supersonic January 15, 2018 Share January 15, 2018 Omg.. haha u are scaring me sia.. but bo bian. Mrs. wanted with light so bo bian. It’s an impromptu and impulse buy.. was there with friends to shop for their new flat end up buy for myself. Haha thise are older fans....elmark. lights always blow.....kns! The curreng led should last longer but my oc says she dislikes fans with lights after those bad experience. So i bought the cheaper one......with lights it will add another rm 150- 200 more. Lucky my cornice have lights....so i changed all of 16 of them......Maybe I should use the skill future fund to learn just remember to off the switch at the db box.....much safer. I was lazy.....just switched off at the switch...thats why kana zap.... Link to post Share on other sites More sharing options...
Sadan 6th Gear January 15, 2018 Share January 15, 2018 no need to repair ... buy new KDK! just replace. simple. or are you just talking about the KDK LED lights which is spoilt?Was replying to @kusje about LED light replacement for KDK/ Panasonic.. was told really troublesome. haha If main pairs/ repair cost is high, really worth to replace a new unit from Malaysia. Link to post Share on other sites More sharing options...
Mustank Hypersonic January 15, 2018 Share January 15, 2018 Was replying to @kusje about LED light replacement for KDK/ Panasonic.. was told really troublesome. haha If main pairs/ repair cost is high, really worth to replace a new unit from Malaysia. Buy this type lorE27 bulb Spoil just change But is old fashion Link to post Share on other sites More sharing options...
Evillusion Supersonic January 15, 2018 Share January 15, 2018 Buy this type lor E27 bulb Spoil just change this wan is like my old elmark. The bulb kept on blowing.......dont know how many times i changed them......after a few month another bulb will blow.......i tulan liao....so i changed to esmaco without lights and changed my cornices to light holder type. After 17 yrs of heavy usage (by oc) the motor starts to give out a grinding sound....both of them. So i changed to kdk dc fans. Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 15, 2018 Share January 15, 2018 this wan is like my old elmark. The bulb kept on blowing.......dont know how many times i changed them......after a few month another bulb will blow.......i tulan liao....so i changed to esmaco without lights and changed my cornices to light holder type. After 17 yrs of heavy usage (by oc) the motor starts to give out a grinding sound....both of them. So i changed to kdk dc fans.Yeah. The inductance of the motor is causing problems with the bulb. I assume you are not using the old fashion incandescent bulb, but the compact flourescent or the led one? The lazy circuit designer never isolate properly. Link to post Share on other sites More sharing options...
13177 Hypersonic January 15, 2018 Share January 15, 2018 Was replying to @kusje about LED light replacement for KDK/ Panasonic.. was told really troublesome. haha If main pairs/ repair cost is high, really worth to replace a new unit from Malaysia. For LED light replacement, it is true that you cannot buy and replace yourself? Link to post Share on other sites More sharing options...
Evillusion Supersonic January 15, 2018 Share January 15, 2018 Yeah. The inductance of the motor is causing problems with the bulb. I assume you are not using the old fashion incandescent bulb, but the compact flourescent or the led one? The lazy circuit designer never isolate properly.something new i learn.....thank you. Yes.....the old one were incandescent.......now the current ones are those without lights......kdk kz15....... Link to post Share on other sites More sharing options...
Sadan 6th Gear January 15, 2018 Share January 15, 2018 For LED light replacement, it is true that you cannot buy and replace yourself?From what the staff told me.. seems impossible to replace the LED ourself..like it’s hidden at some corner. Haha 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 15, 2018 Share January 15, 2018 LED lights should come with a AC adapter, aka LED driver. Then you just connect the adapter to the 230Vac, located inside the fan. Most problem comes from the LED driver. If they die, you don't have lights until you replaced the driver. Link to post Share on other sites More sharing options...
DACH Supersonic January 15, 2018 Share January 15, 2018 Maybe I should use the skill future fund to learn Good. Go learn something useful to enrich your skills and knowledge. Don't waste your time on "piak piak" and things like that. Not good for the mind. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 15, 2018 Share January 15, 2018 thise are older fans....elmark. lights always blow.....kns! The curreng led should last longer but my oc says she dislikes fans with lights after those bad experience. So i bought the cheaper one......with lights it will add another rm 150- 200 more. Lucky my cornice have lights....so i changed all of 16 of them...... 20171128_131949.jpg 20171129_205637.jpg just remember to off the switch at the db box.....much safer. I was lazy.....just switched off at the switch...thats why kana zap....ððð Haha 16 ? I counted , you have at least 4 storey. Link to post Share on other sites More sharing options...
Evillusion Supersonic January 15, 2018 Share January 15, 2018 Haha 16 ? I counted , you have at least 4 storey.those 16 are in the hall....havent count the rooms and balcony..... Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 15, 2018 Share January 15, 2018 (edited) LOL..... Unker everytime you kenna zap your COE kenna extend 10 years automatik lah; HOwever parts under the belly button might be affected the other way around need to do weight balance. Can share how did you do it? Edited January 15, 2018 by Sdf4786k Link to post Share on other sites More sharing options...
Mustank Hypersonic January 16, 2018 Share January 16, 2018 Good. Go learn something useful to enrich your skills and knowledge. Don't waste your time on "piak piak" and things like that. Not good for the mind. Who sayPiak piak is good hor Link to post Share on other sites More sharing options...
BanCoe Hypersonic January 16, 2018 Share January 16, 2018 I never done it as my fan still working (but I remember) one of my sons room they put a kind of lead shot stuck to a double side tape; How they do it only I guess they know ; and also its got some thing to do with 3 blades vs 4 blades or something like that need to do weight balance. Can share how did you do it? Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 16, 2018 Share January 16, 2018 I never done it as my fan still working (but I remember) one of my sons room they put a kind of lead shot stuck to a double side tape; How they do it only I guess they know ; and also its got some thing to do with 3 blades vs 4 blades or something like that this is the part that preventing me from DIY lor Link to post Share on other sites More sharing options...
D3badge 6th Gear January 16, 2018 Share January 16, 2018 i had a nightmare with my first ceiling fan with lights. Thats why i try not to purchase a fan with lights. What happen? Fan spin light move? What brand are you using? ↡ Advertisement Link to post Share on other sites More sharing options...
JEM/Westgate ceiling collapse!
Toilet ceiling leaking
Mold/Fungus on the ceiling
Buying Ceiling fan and lighting from JB
Ceiling Fan in Car
Ceiling Fan in Car
Small little tiny bug on walls & ceiling
Help: ceiling n wall cracks are leaking water
