MAZDA 6
Voxy28
7 hours ago, ER-3682 said:
Well,the car belong to You,You can use whatever Oil you like,anything wrong with your Engine,don't come here make noise....
So, you are the EO expert huh? Your info is more accurate than the Mazda user manual issit?
Not Expert,except Mazda User Manual is for Countries that cannot find 0w-20,then 5w-40 could be use...if got 0w-20 why don't use it.?This Engine is designed to use ''thin'' Oil....
  • Haha! 1
10 minutes ago, flashbang said:
Come on guys, 5W40 is the oil that works for literally every car. It won't spoil anything, especially a B&B NA Mazda engine.
My previous Nissan Sunny N13 was filled with 40wt EO. It can’t even hit 130km/h.
After I bought it, EO was changed to 30wt. It could at least hit 140km/h.
Old Mazda Engine yes,not the SkyActiv ones.
On 12/6/2019 at 9:41 AM, Chunjian89 said:
Thanks for the tips guys. Will get it changed asap.
Brought a used car and they done a free servicing before handover. Can't complaint 😂
Hi Chun,
Wun damage engine but just not efficient running with thicker eo.
Using thinner is more likely to exert excessive pressure on seals that prompts leakages but then again, just one time will also not be castrophic.
Meanwhile, enjoy more quiet engine if noticable due to thicker eo ...lol !
Cheers.
Richard
  • Haha! 1
9 hours ago, richard_crl032 said:
Hi Chun,
Cheers.
Richard
Yah Thicker Oil run Quieter..also Damage the Valvetrain....
Hi ER,
Dunno about damaging the valvetrain but as 1 bro pointed out, all are within operating conditions.
Believe not castrophic enuff to warrant immediate change .. in fact when car ages and to reduce leakage, thicker eo within specification is recommended.
Our tropical ambience temp also means that our engine unfortunately runs hotter which also means thicker oil is thinned out a bit more than winter countries.
Cheers.
Richard
  • Praise 2
On 12/9/2019 at 3:29 PM, richard_crl032 said:
Hi ER,
Cheers.
Richard
If my understanding of oil ratings is correct the rating really determines the viscosity range of the oil at cold ambient temperatures and operating temp. The lower number represents viscosity in winter and the higher number represents viscosity at operating temp.
The problems arise when during cold temps (ie winter), the oil isn't thin enough to lubricate the engine parts, so 0w-20 is important because at cold temps it's still thin enough to coat the engine parts.
The thing is, the lower winter temperatures are rated at something like -25 degC, which is way below what we get in SG.  So theoretically, 5w-40 is actually fine for the engine rated for oil that is 0w-20, because the ambient temperature of Sg means the oil will still be thin enough to operate.
Don't get me wrong, you should always follow the manufacturers specifications, but the theory says its fine.
Take a look at this diagram to give you an idea.
  • Praise 3
Just curious, so if we use 5W/30 where max. is 30 deg C, and Singapore exceeds 30 deg C, what will happen to the engine ?
Insufficient lubrication, and some minor engine wear after prolonged usage ?
5w-30 and 0w-20 is intended for cold temp countries, and 15w-50 is actually better for hot temp countries. The higher second number is the viscosity (or thickness) at 100 deg C (I think) or close to engine operating temp. You don't want the oil to thin out too quickly at operating temps, because you still need a certain viscosity to maintain good seals etc.
Basically you should always follow manufaturer recommendations, but choosing 5w-30 over 0w-20 isn't as bad as making your engine blow up (in theory), because SG weather isn't prone to cold climates.
Edited by GTO-1
Almost all Mazda 6 used 0w-20 nothing happen,even go high Speed in M'sia...even go thru 3-4 Hours jams at Custom....
Correct. Nothing should happen, because its manufacturer recommended oil and the manufacturer would have done hot weather testing to ensure the engine (and recommended oil) operates effectively across a wide band of temperatures.
Just saying that given the temperatures in Singapore, although not recommended, going with a different grade oil like 5w-30, probably won't have much impact to the engine.
It’s a fine art to balance fuel efficiency and HTHS.
I believe original spec oil 0w-20 HTHS should be around 2.6.
Just find 20wt oil with HTHS of 3 will be more than adequate.
A 0W-20 lubricant will give better protection in cold countries (which we are not) as it is less viscous. A 5W-30 will give better protection in hotter countries but as it has higher viscosity, the performance of the engine of the car will be reduced compared to a 0W-20. Normally it is a risk to use thinner lubricants but in this case as it is specified by Mazda, they assume the risk. Using 0W-20 not an issue with new engines but older engines normally need thicker lubricants for better protection.
https://www.lubricants.total.com/what-are-oil-grades
(Extract)
"Viscosity is notated with the common "XW-XX." The number preceding the "W" rates the oil's flow at 0 degrees Fahrenheit (-17.8 degrees Celsius). The "W" stands for winter, not weight as many people think. The lower the number here, the less it thickens in the cold. So 5W-30 viscosity engine oil thickens less in the cold than a 10W-30, but more than a 0W-30. An engine in a colder climate, where motor oil tends to thicken because of lower temperatures, would benefit from 0W or 5W viscosity. A car in Death Valley would need a higher number to keep the oil from thinning out too much.
The second number after the "W" indicates the oil's viscosity measured at 212 degrees Fahrenheit (100 degrees Celsius). This number represents the oil's resistance to thinning at high temperatures. For example, 10W-30 oil will thin out at higher temperatures faster than 10W-40 will."
Hi everyone, I just found this great forum when I was searching for some info about servicing mazda 6 (2016 model, 2.5L).
I'll be doing my 40K servicing soon in JB and I would like to buy most of the parts required locally. May I know:
1) what engine oil is recommended for mazda 6? Is it 0W20? What brand is good?
2) which denso iridium spark plug is recommended for mazda 6?
3) Also, where to buy the 2 items above?
Many thanks in advance. Let me know if there's any meetup. Would love to meet other mazda 6 owners and find out more in person.
