Kklee 6th Gear November 17, 2015 Author Share November 17, 2015 Your maths sala. Should be more than 20 years if 2 x a day at 15000 gross. 2 x 365 = 730 times per year. Maybe you mean 1,500 instead? Oops, an extra zero. ↡ Advertisement Link to post Share on other sites More sharing options...
Woodstockht Clutched November 17, 2015 Share November 17, 2015 the standard car charger sold outside tend to have 2 output - 1A and 2.1A similar to a lot of those powerbank. ya lor, so won't know if it's 1A or 2.1A. Maybe can choose which output to install? I am using the HU port for reading thumbdrive for MP3 already. Besides, as correctly mentioned by Blade, wire dangling out of HU port, not cool. 1 Link to post Share on other sites More sharing options...
Streamium70 2nd Gear November 17, 2015 Share November 17, 2015 ya lor, so won't know if it's 1A or 2.1A. Maybe can choose which output to install? I am using the HU port for reading thumbdrive for MP3 already. Besides, as correctly mentioned by Blade, wire dangling out of HU port, not cool. to be more cool (with lesser $), buy a car charger that has cool LED. Link to post Share on other sites More sharing options...
Silveraltis 1st Gear November 17, 2015 Share November 17, 2015 Heres the led Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear November 18, 2015 Share November 18, 2015 Heres the led Basically its personal pref but I think its quite nice for the LED & USB port there Link to post Share on other sites More sharing options...
Silveraltis 1st Gear November 20, 2015 Share November 20, 2015 Anyone experience any creaking sound after driving. When i come out of the car i hear this greak greak sound from the back. Link to post Share on other sites More sharing options...
Kklee 6th Gear November 21, 2015 Author Share November 21, 2015 (edited) Anyone experience any creaking sound after driving. When i come out of the car i hear this greak greak sound from the back. Erm, after reading this morning, when I come back, I encountered it. Edited November 21, 2015 by Kklee Link to post Share on other sites More sharing options...
7hm Turbocharged November 21, 2015 Share November 21, 2015 ya lor, so won't know if it's 1A or 2.1A. Maybe can choose which output to install? I am using the HU port for reading thumbdrive for MP3 already. Besides, as correctly mentioned by Blade, wire dangling out of HU port, not cool. well, you could look for those current readers that plug in between your charging port and device (the reader will have another USB port to plug the device into). I have one of those and it's helpful to find out how much your charger/device/etc. actually draws or provides Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear November 22, 2015 Share November 22, 2015 Anyone experience any creaking sound after driving. When i come out of the car i hear this greak greak sound from the back. Never really notice it. Mayube cause I always wait till radio come on then i drive off. Link to post Share on other sites More sharing options...
Kklee 6th Gear November 22, 2015 Author Share November 22, 2015 (edited) Never really notice it. Mayube cause I always wait till radio come on then i drive off. You sure won't notice it - you are driving off. Edited November 22, 2015 by Kklee Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear November 22, 2015 Share November 22, 2015 You sure won't notice it - you are driving off. Oops read wrongly. I thought is before moving off. Link to post Share on other sites More sharing options...
Chongsf 1st Gear December 7, 2015 Share December 7, 2015 does your reverse cam have those parking guidelines (green and yellow) to guide you in parking to make the car straight? My reverse cam dun have those parking guidelines. Mine is the classic version. Is those parking guidelines dependent on the type of reverse cam used or dependent on the type of HU used. Link to post Share on other sites More sharing options...
Kindaixin 1st Gear December 7, 2015 Share December 7, 2015 Anyway to have the side mirror fold when you turn off engine and vice versa? During servicing can request for car door auto unlock when gear at parking. Wonder if wing mirror can do. I went to Japan and rented a Toyota car. It does that. Link to post Share on other sites More sharing options...
Chongsf 1st Gear December 7, 2015 Share December 7, 2015 Anyway to have the side mirror fold when you turn off engine and vice versa? During servicing can request for car door auto unlock when gear at parking. Wonder if wing mirror can do. I went to Japan and rented a Copied from Post 252 Step #1 Close all the doors. Make sure your parking brake is on. Don't do this on an incline especially if your choice requires the car to be shifted into Neutral. This depends on your key type: Normal key: Switch ignition to the ON position (2nd position). Smart key: Turn ignition to the IGNITION ON mode (2nd press of the start button). Do not step on the brakes or your car will start! REMINDER! Step #2 has to be done within 10 seconds of doing step #1! Step #Option==============================Shift to=====Door lock switch to 1 Lock immediately when shifting out of Park=======P=============Lock====== 2 Unlock immediately when shifting into Park=======P============Unlock===== 3 Lock when vehicle speed is about 20kpn=========N=============Lock===== 4 Unlock based on driver side door===============N============Unlock==== Shift the gear lever to either P or N. If you're already in the correct shift option, you don't need to change it. So if it says above you need to shift to P, and you're already in P, leave it. Same for N. Of course, if you're in P and need to shift to N, do it (step on the brakes to shift!). Press the driver side door lock switch to your choice for 5 seconds. Release after 5 seconds. If You're Successful If you're successful, all doors will lock then unlock. This is the signal that the setting has been turned on OR off. Yes this is horrible. The only way to know if the setting is correctly set is to try it out. This is a problem for Option #3 as it means you have to actually drive. Link to post Share on other sites More sharing options...
Ghostrider8 Clutched December 7, 2015 Share December 7, 2015 Anyway to have the side mirror fold when you turn off engine and vice versa? During servicing can request for car door auto unlock when gear at parking. Wonder if wing mirror can do. I went to Japan and rented a Toyota car. It does that. Mine is installed with auto fold side mirror when I lock the car doors. Link to post Share on other sites More sharing options...
Avalon74 Clutched December 8, 2015 Share December 8, 2015 Can anyone advise what is the profile for the Altis stock tyre? Notice both std & elegance are using Dunlop but not sure which exact model. Thanks Link to post Share on other sites More sharing options...
Blackyv Turbocharged December 8, 2015 Share December 8, 2015 Can anyone advise what is the profile for the Altis stock tyre? Notice both std & elegance are using Dunlop but not sure which exact model. Thanks im sure you can find one new altis in any carpark.. just check that tyre out lor... Link to post Share on other sites More sharing options...
Kklee 6th Gear December 8, 2015 Author Share December 8, 2015 Can anyone advise what is the profile for the Altis stock tyre? Notice both std & elegance are using Dunlop but not sure which exact model. Thanks 205/55R16 91V ↡ Advertisement Link to post Share on other sites More sharing options...
Should I sell my existing car
Toyota bZ4X (2026) Part 2
Next Generation Toyota Crown
Wheel Bearing Labour cost
Toyota Corolla Cross
