Gnahp Twincharged December 4, 2025 Share December 4, 2025 On 12/4/2025 at 10:31 PM, Ahwhye said: Phillips screws always slip because all people use one size of driver to screw different sizes and different types of cross-shape-looking screws lah! aka anyhow screw lah. https://en.wikipedia.org/wiki/List_of_screw_drives And that slipping is intended is a myth. yeah, I took it with a pinch of salt 😁 I noticed internet has more junks lately, people just anyhow whack it slips because people using the wrong size or the wrong type ↡ Advertisement 2 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic December 5, 2025 Share December 5, 2025 On 12/5/2025 at 4:56 AM, Gnahp said: yeah, I took it with a pinch of salt 😁 I noticed internet has more junks lately, people just anyhow whack it slips because people using the wrong size or the wrong type The centre PH1 is either labeled wrongly or stamped wrongly. 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged December 5, 2025 Share December 5, 2025 On 12/5/2025 at 8:46 AM, Volvobrick said: The centre PH1 is either labeled wrongly or stamped wrongly. good eyes 😁 centre one is just a PH1 instead of indicated JIS 3 Link to post Share on other sites More sharing options...
Kangadrool Supersonic December 5, 2025 Share December 5, 2025 On 12/4/2025 at 10:54 PM, Mkl22 said: Ask PUB. PUB used to give out water saving thimbles exactly like ysc3 said. hate those thimbles that cause tiny stream water to squirt out and spilling all over the place. Many public toilets using them now. What you can do is to adjust the valve to control the flow, if you have the open/close valve installed along the pipe before tha tap. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 5, 2025 Share December 5, 2025 On 12/5/2025 at 4:56 AM, Gnahp said: yeah, I took it with a pinch of salt 😁 I noticed internet has more junks lately, people just anyhow whack it slips because people using the wrong size or the wrong type 😁 7 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 5, 2025 Share December 5, 2025 On 12/4/2025 at 8:50 PM, Lala81 said: Interesting. I thought a cross design is just a very natural design. And some would say it's by design to cam out, others will disagree and say it's a faulty design. To reduce damage to phillips screwhead, you need to apply sufficient pressure and make sure the driver doesn't jump off when the screw hits resistance. A clutch in the driver is used to break the power spin and take the load off the screwhead instead. If you see those numbers on the driver, that's the clutch setting. Better design that reduce cam out, are pozidriv, square or robertson and torx, e-torx, etc. When you see those screws or bolts in an automobile assembly, they are mainly NOT phillips. When you let the driver free spin without doing real work, you're damaging both surfaces. It's the same with drilling. When you drill, go slow and watch the sliver of metal shavings come out. That's drilling. If you go fast, and not cutting metal, you're just damaging the drill bit and heating up both surfaces. 4 Link to post Share on other sites More sharing options...
Gnahp Twincharged December 19, 2025 Share December 19, 2025 I noticed the washing machine (top loader) was acting unusual just now during the wash cycle, I can heard it spins normally but the clothes and water didn't move in the drum it will drain and spin dry, it just won't wash, although the motor was spinning and sounds normal (got sound but no action) after I hanged the clothes, gathered my tools, wanted to dismantle it and check the drum right before I start work, I saw this wedging between the wash plate and the drum it was so tight till I need to use a pliers to pull it out then I try to run the machine again, this time the washer plate is spinning like normal luckily nothing break but I think the poor belt was slipping like crazy during the last wash because of the jammed wash plate by the coin 9 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 20, 2025 Share December 20, 2025 It's an frequent affair to mine...no matter how many reminders to my children to clear all pockets before washing...I myself still often guilty and got scolded by wifey...😂 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 20, 2025 Share December 20, 2025 (edited) On 12/20/2025 at 12:54 AM, Gnahp said: I noticed the washing machine (top loader) was acting unusual just now during the wash cycle, I can heard it spins normally but the clothes and water didn't move in the drum it will drain and spin dry, it just won't wash, although the motor was spinning and sounds normal (got sound but no action) after I hanged the clothes, gathered my tools, wanted to dismantle it and check the drum right before I start work, I saw this wedging between the wash plate and the drum it was so tight till I need to use a pliers to pull it out then I try to run the machine again, this time the washer plate is spinning like normal luckily nothing break but I think the poor belt was slipping like crazy during the last wash because of the jammed wash plate by the coin Well you get 50cents for all your hard work. Only way to get rid of it will be to put it into a vending machine and let them deal with it. For some vending, you get a new coin when you slot your coin in, and push the coin return lever. Don’t really have to buy anything. 😆 Edited December 20, 2025 by Mkl22 5 Link to post Share on other sites More sharing options...
Gnahp Twincharged December 20, 2025 Share December 20, 2025 On 12/20/2025 at 8:54 AM, mersaylee said: It's an frequent affair to mine...no matter how many reminders to my children to clear all pockets before washing...I myself still often guilty and got scolded by wifey...😂 we have: pack of tissue paper turned into pulp coins money (bank notes) keys passport sweets (candy) EZ-link card IC 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 20, 2025 Share December 20, 2025 On 12/20/2025 at 8:54 AM, mersaylee said: It's an frequent affair to mine...no matter how many reminders to my children to clear all pockets before washing...I myself still often guilty and got scolded by wifey...😂 Most dreaded is tissue paper left in the pocket that went for a wash cycle. That's why I don't use tissue paper but rather napkin that wound not disintegrate into smithereen 3 Link to post Share on other sites More sharing options...
Gnahp Twincharged December 20, 2025 Share December 20, 2025 On 12/20/2025 at 9:54 AM, Mkl22 said: Well you get 50cents for all your hard work. Only way to get rid of it will be to put it into a vending machine and let them deal with it. For some vending, you get a new coin when you slot your coin in, and push the coin return lever. Don’t really have to buy anything. 😆 wah, you champion, one look can tell it is a 50 cents the other side of the coin Link to post Share on other sites More sharing options...
Kb27 Supersonic December 20, 2025 Share December 20, 2025 On 12/20/2025 at 12:54 AM, Gnahp said: I noticed the washing machine (top loader) was acting unusual just now during the wash cycle, I can heard it spins normally but the clothes and water didn't move in the drum it will drain and spin dry, it just won't wash, although the motor was spinning and sounds normal (got sound but no action) after I hanged the clothes, gathered my tools, wanted to dismantle it and check the drum right before I start work, I saw this wedging between the wash plate and the drum it was so tight till I need to use a pliers to pull it out then I try to run the machine again, this time the washer plate is spinning like normal luckily nothing break but I think the poor belt was slipping like crazy during the last wash because of the jammed wash plate by the coin You will need to try and remove the plate and clean what's underneath, some day. There's more gunk from what's below. Usually it's a bolt or screw of some kind to loosen the plate. The difficult part is lifting it straight up and out. 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged December 20, 2025 Share December 20, 2025 On 12/20/2025 at 10:35 AM, Kb27 said: You will need to try and remove the plate and clean what's underneath, some day. There's more gunk from what's below. Usually it's a bolt or screw of some kind to loosen the plate. The difficult part is lifting it straight up and out. I watched a few videos, it is not easy things may seized up after many years of gunk accumulation not sure if I want to do that but I think it is filthy inside Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 20, 2025 Author Share December 20, 2025 (edited) On 12/20/2025 at 10:56 AM, Gnahp said: we have: pack of tissue paper turned into pulp coins money (bank notes) keys passport sweets (candy) EZ-link card IC Always screw my kids when they leave tissue paper inside pocket. But sometimes it can also be some lining of things like mattress protectors disintegrating etc. On 12/20/2025 at 10:56 AM, Gnahp said: we have: pack of tissue paper turned into pulp coins money (bank notes) keys passport sweets (candy) EZ-link card IC Edited December 20, 2025 by Lala81 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 20, 2025 Share December 20, 2025 On 12/20/2025 at 10:52 AM, Lala81 said: Always screw my kids when they leave tissue paper inside pocket. But sometimes it can also be some lining of things like mattress protectors disintegrating etc. I cannot screw the kids cause Lim peh also did it before. Just vacuum up and wash the whole lot again. You learn from your own f**k ups. 😆 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 20, 2025 Author Share December 20, 2025 On 12/20/2025 at 1:18 PM, Mkl22 said: I cannot screw the kids cause Lim peh also did it before. Just vacuum up and wash the whole lot again. You learn from your own f**k ups. 😆 I'm the one who cleans it up. So I have the right to screw them. And it's not just the clothes. The drum needs to be wiped and worst case is need a few hot cycles Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 20, 2025 Share December 20, 2025 On 12/20/2025 at 10:58 AM, Hamburger said: Most dreaded is tissue paper left in the pocket that went for a wash cycle. That's why I don't use tissue paper but rather napkin that wound not disintegrate into smithereen That one I'd get scolding for at least a week...😅 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Home repair advice needed
Home renovation tips
