Res2dent Neutral Newbie June 10, 2023 Share June 10, 2023 Any workshop specialised in changing lexus brake pad? ↡ Advertisement Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 10, 2023 Share June 10, 2023 On 6/10/2023 at 6:54 PM, Res2dent said: Any workshop specialised in changing lexus brake pad? What’s so special about a Lexus brake pad. Any workshop will do 3 2 Link to post Share on other sites More sharing options...
badlammy 6th Gear June 10, 2023 Share June 10, 2023 Specialised in Lexus calipers I know. 4 Link to post Share on other sites More sharing options...
Soya Supersonic June 10, 2023 Share June 10, 2023 Ain't it juz bog std toyota pads? 5 Link to post Share on other sites More sharing options...
RadX Moderator June 11, 2023 Share June 11, 2023 On 6/11/2023 at 7:08 AM, Soya said: Ain't it juz bog std toyota pads? Exactly anywy for me… u know the drill😂😂 1 Link to post Share on other sites More sharing options...
RadX Moderator June 11, 2023 Share June 11, 2023 Must ask @Freeder to recommend his fav MILF Link to post Share on other sites More sharing options...
Soya Supersonic June 11, 2023 Share June 11, 2023 On 6/11/2023 at 8:33 AM, RadX said: Exactly anywy for me… u know the drill😂😂 Knn....ppl change brake pad, u change car 2 Link to post Share on other sites More sharing options...
Freeder Hypersonic June 11, 2023 Share June 11, 2023 On 6/11/2023 at 8:34 AM, RadX said: Must ask @Freeder to recommend his fav MILF Sanitary pad yah… 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic June 11, 2023 Share June 11, 2023 On 6/10/2023 at 6:54 PM, Res2dent said: Any workshop specialised in changing lexus brake pad? Any workshop would be able to replace brakepads, it depends on whether you want original or oem, they will be able to order for you. 3 Link to post Share on other sites More sharing options...
Watwheels Supersonic June 11, 2023 Share June 11, 2023 Can use blood soaking pads or not? 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 12, 2023 Share June 12, 2023 On 6/10/2023 at 6:54 PM, Res2dent said: Any workshop specialised in changing lexus brake pad? Hello. Brake pad is an essential item for a car, any workshop will have the capability to change a brake pads. If you want OEM brake pads, you can request from the workshop, they have a network of stockist they can order the brake pads from and get it delivered to their shop for the installation. Nothing complicated about brakes, so won't have a specialised workshop just do lexus' brake. 1 Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 12, 2023 Share June 12, 2023 Generally, most shops should be able to handle this task. Make sure the shop you selected have this disc brake piston spreader for front brakes (many shops opt to using screwdriver or ply bar to drive back the brake pistons which may result in damaging the pistons n seals) As for rear disc brakes, to drive back the brake pistons is difficult and time consuming if the shop do not have a screw back piston tool to do the work At the same time it is best to do a complete brake fluid flush , preferrably with a pressure brake bleeder . Vacuum brake bleeder can also perform the work but will be slower and may not completely draw out the old fluid. 1 Link to post Share on other sites More sharing options...
Soya Supersonic June 12, 2023 Share June 12, 2023 On 6/12/2023 at 11:24 AM, Yeobh said: Generally, most shops should be able to handle this task. Make sure the shop you selected have this disc brake piston spreader for front brakes (many shops opt to using screwdriver or ply bar to drive back the brake pistons which may result in damaging the pistons n seals) As for rear disc brakes, to drive back the brake pistons is difficult and time consuming if the shop do not have a screw back piston tool to do the work At the same time it is best to do a complete brake fluid flush , preferrably with a pressure brake bleeder . Vacuum brake bleeder can also perform the work but will be slower and may not completely draw out the old fluid. Ppl ask simple innocent question abt where to change brake pad...u answer him how to change brake pad....lol 3 Link to post Share on other sites More sharing options...
RadX Moderator June 12, 2023 Share June 12, 2023 On 6/12/2023 at 1:25 PM, Soya said: Ppl ask simple innocent question abt where to change brake pad...u answer him how to change brake pad....lol He mistook where for HOw😂 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 12, 2023 Share June 12, 2023 (edited) Maybe he is changing brake pad for his MIL Lexus and he wants it to be special? Edited June 12, 2023 by Jamesc 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 12, 2023 Share June 12, 2023 Anyway all of you never answer his question. The answer is Borneo Motors. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 12, 2023 Share June 12, 2023 Don't tell me TS bot Lexus and wants to go Ah Beng and son back street car workshop? Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 12, 2023 Share June 12, 2023 TS MIA liao,time to close this thread . ↡ Advertisement Link to post Share on other sites More sharing options...
