New coins are magnetic.!
ER-3682
Surprised our new series coins are magnetic [thumbsdown] [stick to magnet],older series are non-magnetic,cut costs.? :D ,older coins used Nickel based material,new one made of steel.??
Time to invest on powerful magnets and use them on coin operated machines. :p
Edited by Watwheels
Or is the new series coin that you tried is fake!!!!!!
Direct from bank,what do you think.?You go try yourself..
Hypersonic
Can stick on notes or not? magnetic stick on coins, heavy to carry away leh :D
If can stick on notes, sui lah !
Easy to stick out ATM notes :))
Nickel is a magnetic material so will be attracted by magnetic force. Magnetic materials are steel, iron, cobalt and nickel.
Supercharged
oh... that is not common knowledge?
i discovered it the first day i started using them.
kept sticking to the phone cover.
irritating like hell.
Yeap. The new coins have a steel core (to cut cost, steel is cheaper than copper-nickel used in older coins). And they are lighter too...
Magnetic but they never stick to each other?
2 'magnetisable' metals don't stick to each other, only to magnets.
Unless u make it a magnet by stroking it with another magnet.
The north pole is also magnetic but u don't see ships stuck there. I think the correct term is ferrogammo or something...
Edited by Bavarian
Twincharged
They are made of ferrous metals and magnetic but not magnetized yet. so wont stick to each other. Can try using a magnet to magnetize your coins and see if they stick or not.
Supersonic
There's a bit of ferrous metal inside the coin.
I can pick it up by magnetic screwdriver, but after magnetizing the coins. they won't stick to each other.
Probably too little ferrous metal inside.
