Ceiling fan
Bluepica
On 7/29/2025 at 3:12 PM, Lala81 said:
Newest fan to replace the failing legacy haiku.
160 dollars. Design decent for the price. 35 bucks install
Got link to that one? 🙏😁
On 7/29/2025 at 5:47 PM, rainbatt1 said:
$35 installation is very good price...own find or from the shop?
25 dollar for hdb ceiling. Mine >2.9m so 35.
Bangla installer.
Shop arranged installer. Probably bundle price. Usually it's closer to 50 for my living room fan last year.
This the link.
https://s.lazada.sg/s.X7syU
Somehow when I checked out got some additional voucher. So made it less than 160.
The remote is similar to the fanco one. Big and fat.
Suspect all same but just different brands.
The fan windspeed is good. Thumbs up. Maybe a smidge louder than the haiku. But we are comparing something that's <1/5th of a haiku price.
Realised how much of a torture I've been living with a non adjustable slow fan speed for at least half a year.
For a 56 inch fan. This is really very cheap.
Edited by Lala81
  • Praise 4
Bangla installer.
This the link.
This brand is local/SG brand?
Review good or not?
i'm looking at replacing a few ceiling fans too, and is scratching my head which/what is good...
Got come across any not-too-big ones, but can blow/cover a wide area? I've a long/big balcony and the current fan simply cannot cover the whole place...
Then still got bedrooms...
cheap and nice .......  good good
  • Haha! 1
On 8/3/2024 at 4:15 PM, Ct3833 said:
No rolex, therefore unable to verify if the photo is real 😁
One year later, then i saw your message.....
just for you
Edited by Throttle2
  • Haha! 3
Review good or not?
I dunno man. I just feel those prism types (hugger type) without downrods will have less windflow. I have 38 and 52 inch types with those.
The 52 inch one not that strong outside the immediate area.
The two strongest fans I have are obviously the 56 inch ones. Non hugger types.
Ha the correct solution is to have two smaller ceiling fans on the balcony
  • Praise 2
  • Haha! 1
this type ? but for long balcony, you may want to consider installing 2 instead of one big one.
i was reading some Gemini summary of 3 blade vs 5 blade fans b4 i ordered my fan.
I think for the bigass fans, they use multi blade cos they want to smoothen the windflow, so like less uncomfortable for those huge fans. Basically less blades is more airflow, higher efficiency but more "gusty"
For home purposes, don't think much need for > 3 blades.
  • Praise 3
Wait till Dyson comes up with a 2000 dollar blade-less ceiling fan. Then no need to argue about 3,4 or 5 blades!
  • Haha! 3
China and online got actually. Think u can search blade less ceiling fan. The blades just hidden in the body.
  • Haha! 1
Supersonic
To me Dyson is British trash 😂.  Still bladed inside somewhere in the ductwork. Add ducts means less efficient.
Supersonic
Huggers don’t have enough airflow as it is too close to the ceiling. Same with those who design a drop ceiling around the fan. Worst design. Totally no airflow to the blades.
lucky yours is some distance from the walls. But best is what throttle2 has shown, Flat ceiling. Follow KDK placement instructions will not be wrong.
Edited by Mkl22
Due to HDB ceiling heights, most short downrods and hugger fans in SG are more common.
Longer downrod fans really not common. Or like the Haiku have a longer body.
this alkova fan the downrod is quite short. But it's windspeed is strong. My living room fanco 52" is quite lackluster i feel in terms of airflow.
On 5/29/2025 at 12:55 PM, Ct3833 said:
KDK AC fan CMI, I have more than 10 of them, none of them have no noise, the noise will come back shortly after replacing the capacitor. I have so far switch some of them to DC fans, going to phase them out slowly regardless they are spolied or not.
In my opinion, there is no rocket science for fan lah. Brushless fans are standard today. The only difference are the materials for the blades and housing.
Ceiling fan is effective, provide good air circulation and it doesn't take up space. No need for brand unless you just need that badge.
  • Praise 2
Supersonic
For AC fans pretty robust. Nothing much to break except capacitor and bearings.
for DC fans a lot more to break, given that DC Inverter components these days can be really crap.
52 in...
my balcony quite... jialat. It's about 7 m by 2.3 m. The ceiling from day 1 got 2 wires for fans. the problem is this balcony by design is comprising of a sunken planter near the edge, so this means that the ceiling also has a drop at that part (cos that's the sunken planter from the floor upstairs). What this means is that my ceiling it v long (~7 m) but the width is only about ~1.5 m, and so any fan i choose cannot be too big to begin with...
when i first moved in, we installed two i think maybe 35" fans, which of course means the wind cannot reach v far.
This was not deemed a big deal as we didn't (couldn't) make use of the balcony much, but we've installed decking on the floor as well as zip blinds so now i sometimes make use of the balcony as my workstation when I WFH.
With the fans ageing (though still working) and the changing needs, i'm thinking of replacing them with (can only be slightly) bigger and better ones.
Not sure how easy it will be to install a 3rd one in the middle, if really there's no way two fans can cover the whole area well. Maybe should check the feasibility of this.
BTW, what is meant by hugger type huh?
On 7/31/2025 at 10:08 AM, Atrecord said:
52 in...
Like this.  BTW you will be at one corner of the balcony (unless whole family lying flat across it!) so maybe only on fan for that spot. No need to cool the entire space.
