Raynergoh 1st Gear July 26, 2019 Share July 26, 2019 Hello guys, sorry to disturb everyone, just met an issue with my mz6.. Long story short, after parking my car, switch off engine, was walking away, usually will auto lock, but noticed no sound. So used key to try to manually lock.. but car never respond.. went back in, tried to start Engine, but the start stop button began flashing in green... so used the method in manual, used the key to touch the start stop and started the engine. noticed a few anomalies... hud did not rise up (2016 mz6).. Mazda connect panel Remained switched off, whole system seems to have restarted.. brake button no more light... check engine light came on... Any bros have similar experience? Is it car batt? Key fob batt? Or something else? Also, all the interior lights are also not working Hello guys, sorry to disturb everyone, just met an issue with my mz6.. Long story short, after parking my car, switch off engine, was walking away, usually will auto lock, but noticed no sound. So used key to try to manually lock.. but car never respond.. went back in, tried to start Engine, but the start stop button began flashing in green... so used the method in manual, used the key to touch the start stop and started the engine. noticed a few anomalies... hud did not rise up (2016 mz6).. Mazda connect panel Remained switched off, whole system seems to have restarted.. brake button no more light... check engine light came on... Any bros have similar experience? Is it car batt? Key fob batt? Or something else? Also, all the interior lights are also not workingYes tried my spare key, car also no response... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
thesoul 2nd Gear July 26, 2019 Share July 26, 2019 Got it through a group buy exercise with several mz6 bros https://3dcarmat.com.sg Hi would like to know how much a set of 3dcarmat cost. for both front and back floor? Thanks Retail price should be $320. Bought it at $280 through group buy. Also, all the interior lights are also not working Also, all the interior lights are also not working Yes tried my spare key, car also no response... Cant say what went wrong, best is to tow it and get it checked at the ws if you cant even get it started. If you are still under warranty, worth going back to TEK. Else, try JDM auto or monster garage Also, all the interior lights are also not working Also, all the interior lights are also not working Yes tried my spare key, car also no response... Cant say what went wrong, best is to tow it and get it checked at the ws if you cant even get it started. If you are still under warranty, worth going back to TEK. Else, try JDM auto or monster garage 1 Link to post Share on other sites More sharing options...
Raynergoh 1st Gear July 27, 2019 Share July 27, 2019 Just update bros here for experience... went to my own ws... the problem is the result of a blown fuse.. changed fuse, things went back to normal. :) 5 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 27, 2019 Share July 27, 2019 Just update bros here for experience... went to my own ws... the problem is the result of a blown fuse.. changed fuse, things went back to normal. :) Mazda 6 seldom blow Fuse,p/s check the cause. Link to post Share on other sites More sharing options...
josephywj 1st Gear July 27, 2019 Share July 27, 2019 Thanks all for the response! I went to CCS JB yesterday to do soundproof on 4 doors and trunk. The results is quite good. The sound became âdeeperâ when car or motorcycle passed by. Less intrusive. Still a lot of noise coming through from the floor though. Need to consider doing floor soundproof to really cut down the noise significantly. :) I noticed that some times too. I asked my SA but she said itâs normal due to istop. I havenât tried disabling istop and see whether itâs the same though. I always turn off istop. Always do it when I start the engine. The button is easily accessible. I don't find it useful in singapore coz of our weather plus over time it drains the car battery faster too. 1 Link to post Share on other sites More sharing options...
MI6 Clutched July 28, 2019 Share July 28, 2019 Hi, wanted to know most of you out there uses 95 or 98 petrol. Is there any difference in performance with 98 over 95? Thanks again. 1 Link to post Share on other sites More sharing options...
alex976 5th Gear July 28, 2019 Share July 28, 2019 Hi, wanted to know most of you out there uses 95 or 98 petrol. Is there any difference in performance with 98 over 95? Thanks again. Try to use 98 cos of the high compression ratio of the engine 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 28, 2019 Share July 28, 2019 Hi, wanted to know most of you out there uses 95 or 98 petrol. Is there any difference in performance with 98 over 95? Thanks again. If budget allow..use 98...Engine Run smoother & cleaner... Hi, wanted to know most of you out there uses 95 or 98 petrol. Is there any difference in performance with 98 over 95? Thanks again. If budget allow..use 98...Engine Run smoother & cleaner... Hi, wanted to know most of you out there uses 95 or 98 petrol. Is there any difference in performance with 98 over 95? Thanks again. If budget allow..use 98...Engine Run smoother & cleaner... Link to post Share on other sites More sharing options...
MI6 Clutched July 28, 2019 Share July 28, 2019 Another quick question....all you guys who got your Mazda 6 this year, are they built in 2018 or 2019? Mine is built in 2018, got it in this month. Link to post Share on other sites More sharing options...
sgsmith 1st Gear July 28, 2019 Share July 28, 2019 Another quick question....all you guys who got your Mazda 6 this year, are they built in 2018 or 2019? Mine is built in 2018, got it in this month. How to check year of build? 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 28, 2019 Share July 28, 2019 How to check year of build? There should be a piece of paper given to you from LTA...when the Car is Register... Link to post Share on other sites More sharing options...
takumi_ming Clutched July 28, 2019 Share July 28, 2019 Hello. I parked my 8 month old Mazda 6 beside a lorry yesterday and got a chip off my side passenger window probably from the lorry driver opening the door. Does anyone know if this is covered under warranty by TEK? Or any glass repair workshop to repair this pls? Thanks in advance 1 Link to post Share on other sites More sharing options...
josephywj 1st Gear July 29, 2019 Share July 29, 2019 Another quick question....all you guys who got your Mazda 6 this year, are they built in 2018 or 2019? Mine is built in 2018, got it in this month. I got mine early this month Manufactured in 2018. No difference from 2019 right? Try to use 98 cos of the high compression ratio of the engineMy FC for 95 is either better or same as the 98. A bit hard to justify the need for 98 leh..additional $15 per tank plus no difference in performance for me. My previous xc60 98 big difference in performance. Plus singapore's 95 is considered premium fuel already...just my 2 cents worth 1 Link to post Share on other sites More sharing options...
Alfc 5th Gear July 29, 2019 Share July 29, 2019 I got mine early this month Manufactured in 2018. No difference from 2019 right? My FC for 95 is either better or same as the 98. A bit hard to justify the need for 98 leh..additional $15 per tank plus no difference in performance for me. My previous xc60 98 big difference in performance. Plus singapore's 95 is considered premium fuel already...just my 2 cents worth Quite surprised you still got last year's stock. I thought this car is selling well and stocks would be fast moving. Link to post Share on other sites More sharing options...
josephywj 1st Gear July 29, 2019 Share July 29, 2019 (edited) Quite surprised you still got last year's stock. I thought this car is selling well and stocks would be fast moving.Maybe because mine was a test drive unit...?...haha.. Edited July 29, 2019 by josephywj 1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear July 29, 2019 Share July 29, 2019 (edited) Is the iStop also a kind of cylinder deactivation?Hi s2s1, Quite different ... istop stop engine completely i.e. all cylinders to improve FC and happen only when in complete stop. Cylinder deactivation stops only selected cylinders and happens even car is moving. Cheers. Richard Edited July 29, 2019 by richard_crl032 1 Link to post Share on other sites More sharing options...
MI6 Clutched July 29, 2019 Share July 29, 2019 Thanks for all the answers. The reason I ask about the manufactured date is because I realised that my 'Instrument Cluster Display' the one right in front of the steering wheel is of the older version think is called Type B. The newer version is Type A. All this time I thought my is the newer version until I saw on youtube where they feature the Type A. I'm disappointed, so my car is probably from older stock. No one would know the difference if you're a newbie looking at M6 for the first time! Sure would like to know how many of u guys got the Type A Cluster Display. Thanks again 1 Link to post Share on other sites More sharing options...
Nkw0820 1st Gear July 29, 2019 Share July 29, 2019 (edited) Thanks for all the answers. The reason I ask about the manufactured date is because I realised that my 'Instrument Cluster Display' the one right in front of the steering wheel is of the older version think is called Type B. The newer version is Type A. All this time I thought my is the newer version until I saw on youtube where they feature the Type A. I'm disappointed, so my car is probably from older stock. No one would know the difference if you're a newbie looking at M6 for the first time! Sure would like to know how many of u guys got the Type A Cluster Display. Thanks again I think you are misunderstanding.For Mazda 6 Standard is multi-dot display (non colour) For Mazda 6 Executive is multi dot display (With colour) For Mazda 6 Luxury is 7” multi dot display (Center) Thanks for all the answers. The reason I ask about the manufactured date is because I realised that my 'Instrument Cluster Display' the one right in front of the steering wheel is of the older version think is called Type B. The newer version is Type A. All this time I thought my is the newer version until I saw on youtube where they feature the Type A. I'm disappointed, so my car is probably from older stock. No one would know the difference if you're a newbie looking at M6 for the first time! Sure would like to know how many of u guys got the Type A Cluster Display. Thanks again I think the YouTube review is for 2018 Mazda 6 2.5T so it is slightly different with our Mazda 6.For example, the Mazda 6 in Malaysia come with trunk open lever inside the cabin which don’t have it for Singapore market. Edited July 29, 2019 by Nkw0820 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Honda City 4th Gen
Honda City 4th Gen
2025 Mazda 6e
2025 Mazda 6e
2026 8th Generation Lexus ES
2026 Mazda EZ-60 / CX-6e
Camry, Accord, Teana which is more Luxurious?
