MAZDA 6
Voxy28
Twincharged
10 hours ago, Davin said:
Hi Mazda 6 owners,
I have changed the 2019 Mazda 6 key fob battery with Maxell CR2025 lithium battery and somehow it can’t work. I can’t unlock the car doors and boots with this new battery. When I press any button on the key fob, there is red blinking light so I assume battery is working fine.
Is battery brand an issue? The existing one is from Panasonic.
Thanks in advance for any valuable feedbacks.
Cannot be,take out & refit again.
Dear all,
Need help.
I recieved a sms with a link to download and update my free map as it is going to expire in July.
Should i wait for next servicing or do it myself. When it expires, will it still work?
Lastly, to proceed a login account is needed. Do we need to register a new one the first time?
Guys i hv given the boot tray Mazda 6 2019, which for owner to remove the spare tire and enlarge the space. I thought i will be using it, but never. Decided to let it go together with air pump. All brand new. Not active here, but i put item at carousell @lawrance.gan, if any mazda 6 owner needs it.
* Not too sure if earlier batch of Mazda 6 can use or not.
Thank you.
I received my Mazda 6 2.0 executive in Jan 2019. Its overall a good ride but theres always condensation and fogging on the side mirrors on rainy days. I noticed Mazda does not have heated side mirrors. How do you all overcome this problem?
I'm actually prepared to replace the side mirrors for heated side mirrors but who does this?
The simplest and cheapest solution is to paste those antifogging film from Aliexpress or Shopee.
images?q=tbn:ANd9GcQcXIvRdXnjxueXB0Xuo9V
Hello, i'm using this. Can last for 1 quarter of a year subject to the frequency of rain encountered.
https://www.soft99.co.jp/en/products/detail/04172/
Has anyone tried to install aftermarket 360 view to your Mazda 6? Any feedbacks or recommendation who can do this?
Supercharged
I recently sent my car to an independent workshop for servicing. The package included 4L of fully synthetic engine oil. According to my car’s manual, SKYACTIV-G 2.0 requires 4.2L of engine oil with oil filter replacement. Hence, I agreed to pay for the top-up when asked by the mechanic after he emptied a 4L bottle. However, I noticed that he did not use the dipstick to check for under or over filling. Nevertheless, I gave him the benefit of doubt that he could roughly gauge the quantity from experience, and since a little under or over 200ml should not matter. When home, out of curiosity, I decided to follow the instructions in the manual to check the oil level, and found it to be a few centimetres above the maximum mark. Is this any cause for concern? Any harm to the engine if I simply stay with typical package comprising 4L of engine oil change and fall short by 200ml during servicing in future? Thanks for any advice!
Edited by kykh
Supercharged
Change engine oil never use dipstick to check? Wah liao
And if spec is 4.2 litre you will never be able to drain 4.2 litre oil out, probably 4l more than enough
  • Praise 2
Few cm is waiting for the engine  to break down due to overfilling. 4L is just about the right amount.
Take a pix of the dip stick and post it here
  • Praise 2
Supersonic
care to share which lousy workshop who cannot even be bothered to check the dip stick.
a few centimeters can be a lot. maybe you meant a few mm? like hamburger mentioned, having a picture is best to guage
Edited by Mkl22
Supercharged
For those who requested for a photo of the oil level shown on the dipstick, here it goes. I aligned the zero mark on the ruler with the maximum mark on the dipstick, and measured the oil level to be around 6.5cm above the maximum mark. Should I visit the workshop again to drain out the excess?
Supersonic
yes. immediately. the bugger never drained the oil and added another 4l making it 8L in the sump?
6.5cm is HUGE!! Actually with this much oil the engine will be choking and there should be less power
Edited by Mkl22
  • Praise 2
My colleague estima had the same issue with the workshop overfilling with that much, so they can earn that extra litre of EO poured in. More is OK according to their flawed logic.
I tried to warn him. Too late as the engine stalled and the damage done.
And yes, please let out at least half litre and check again with dip stick.
  • Praise 2
Did u check the dipstick right after a drive?
you should only check your dipstick when your engine is cool.
alternatively, wipe down ur dipstick with a piece of tissue and reinsert and check again.
  • Praise 2
Do the check on the morning before drive (Engine cold). Ensure your car is on level ground. Wipe the dip stick clean, insert n pull out to see the level.
If still above immediate drive to the workshop to drain it out.
  • Praise 2
