mersaylee Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:09 PM, Heartlander said: I like Brompton design but really hate the internal gear hub. Granted it has its benefits like relatively maintenance free, but too many steps just to take out the rear tyre to replace inner tube. After a brief spell with burst inner tube every other week I got phobia just taking the bike out. And I always got the feeling that the cable tension on internal hub is not aligned properly thus gearing not correct, which happened time to time. So eventually got the alunminum G 山寨版 with external gear system haha. Liaoge...? 😁 ↡ Advertisement Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:20 PM, inlinesix said: I did that and also to the smallest, both ways still same result Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:17 PM, Volvobrick said: Looks like you may have to shift to the largest cog BEFORE you fold. That should increase the tension in the chain. If still too loose, shorten the chain. Will give a try again tomorrow. Tension of chain seems ok when riding, no slack at all. It is when folded, somehow the derailleur is not pulling the chain, it get dislodged. Need to figure why. Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 8:12 PM, inlinesix said: That’s why Brompton ftw🤭 Over priced British stuff. 10k for a foldie is crazy Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 I was watching this video, the chain tension is good. Need to see why I am not achieving this. Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:27 PM, Mkl22 said: Over priced British stuff. 10k for a foldie is crazy Only siao ppl pay $10k for Brommie. That’s reserve for Moulton. Someone here owns 1. Brompton easy to sell in market with lesser loss. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:25 PM, Victor68 said: Will give a try again tomorrow. Tension of chain seems ok when riding, no slack at all. It is when folded, somehow the derailleur is not pulling the chain, it get dislodged. Need to figure why. Take a close up video for us to help diagnose.... Maybe derailleur spring weak, need to screw in the small hex bolt to increase the tension. Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:36 PM, Volvobrick said: Take a close up video for us to help diagnose.... Maybe derailleur spring weak, need to screw in the small hex bolt to increase the tension. Shimano RD where got spring tensioner Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:36 PM, Volvobrick said: Take a close up video for us to help diagnose.... Maybe derailleur spring weak, need to screw in the small hex bolt to increase the tension. Sure, hope I can resolve it. Good night and I am going to dream about it till tomorrow. 😆 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:28 PM, Victor68 said: I was watching this video, the chain tension is good. Need to see why I am not achieving this. It should looks close to this Link to post Share on other sites More sharing options...
Heartlander Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:21 PM, mersaylee said: Liaoge...? 😁 Did consider that but it only comes in chromoly steel whereas the one I got is full aluminium with disc brakes. I change the gear system to Tiagra. 1 Link to post Share on other sites More sharing options...
Heartlander Turbocharged June 1, 2025 Share June 1, 2025 1 Link to post Share on other sites More sharing options...
Heartlander Turbocharged June 1, 2025 Share June 1, 2025 Link to post Share on other sites More sharing options...
Heartlander Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 9:21 PM, Victor68 said: I did that and also to the smallest, both ways still same result In case you never pedal after changing gear. For external gear system, you need to pedal after changing gear setting else the current gear will remain which might affect folding mechanism. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 1, 2025 Share June 1, 2025 On 6/1/2025 at 10:02 PM, Heartlander said: Reduce chances of chain drop...that means can still drop...😅 Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 On 6/1/2025 at 10:04 PM, Heartlander said: Yeah, seen both but none advise how to rectify if chain loosen or adjustment of the chain tensioner. I believe something got to do with the position of the chain tensioner. Wake up early to start visualizing it. 😂 1 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged June 1, 2025 Share June 1, 2025 On 6/2/2025 at 5:32 AM, Victor68 said: Yeah, seen both but none advise how to rectify if chain loosen or adjustment of the chain tensioner. I believe something got to do with the position of the chain tensioner. Wake up early to start visualizing it. 😂 the entanglement seem normal? Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 1, 2025 Share June 1, 2025 I think I got it. The position of the chain tensioner is very important. Mine may still need a slight adjustment but will leave it to monitor to see how it goes. Along the way, I did try to adjust the derailleur but don't think I could make any adjustments. I fold/ unfold a few times, it works. Will update after using it to see the result. Thank you for all the advises. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Next generation of smartphones - foldable phones
Need Recommendations for a bicycle
Foldable static sunshade
Folding bikes
Folding bikes
75km-long first phase of Round Island Route opens
Trunk Rack for Bicycle
83-Year-Old Man Fixes Bicycles At Pasir Ris Void Deck To Pay For Kidney Dialysis
