Enye Hypersonic March 6, 2015 Share March 6, 2015 For those who use camera for 24 parking surveillance, do yourself a favour by connecting it to a separate battery. Most people allow the supplier to tap onto existing car battery and make promises it will cut-off blah..blah..blah. In many cases, the main battery for starting engine is drained enough, that it can't start the engine. Then you are either stuck, looking for a jump start or quarrel with your battery supplier about battery fault. It is not battery fault, but the bloody camera draining it flat. Some camera sucks power like nothing. It's like leaving a 5W bulb turn on throughout the night. Don't expect your car to start in the morning. Just need to set the cut off voltage higher. My cam installer set it at 11.8v but I made him reset it to 12.2v When I asked him why he set so low, he said 11v still can start don't worry 😨 ↡ Advertisement Link to post Share on other sites More sharing options...
Angcheek Hypersonic March 6, 2015 Share March 6, 2015 For those who use camera for 24 parking surveillance, do yourself a favour by connecting it to a separate battery. Most people allow the supplier to tap onto existing car battery and make promises it will cut-off blah..blah..blah. In many cases, the main battery for starting engine is drained enough, that it can't start the engine. Then you are either stuck, looking for a jump start or quarrel with your battery supplier about battery fault. It is not battery fault, but the bloody camera draining it flat. Some camera sucks power like nothing. It's like leaving a 5W bulb turn on throughout the night. Don't expect your car to start in the morning. How you charge the separate batt ? 2 Link to post Share on other sites More sharing options...
nazerath Turbocharged March 6, 2015 Share March 6, 2015 can anyone please recommend me good front and back car cam with motion sensor or 24 hrs recording? mine got sunstroke. 2 Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 6, 2015 Share March 6, 2015 (edited) can anyone please recommend me good front and back car cam with motion sensor or 24 hrs recording? mine got sunstroke. Get 2x G1W.. Foxoffer has them... i left mine in car in the sun and this still functioning after > 1 year.. budget 1080P cam with WDR.. Wires just let installer run them.. 2x $30 for front n back cams... Use Loop recording for 24hr recording.. but i think last only 2-3 hrs before first video written over.., more bec of SD card capacity only... Can use motion sensor but not very sensitive.. if 24 hr continual recording then no need motion sensor wat... Edited March 6, 2015 by Lurpsexx Link to post Share on other sites More sharing options...
nazerath Turbocharged March 6, 2015 Share March 6, 2015 (edited) Hi sorry what's g1w? I found fox offer. I have no problem getting from tabao too it that helps. Locally wise any shops or models ? Thanks for yr reply. http://item.taobao.com/item.htm?spm=a230r.1.14.17.tUA35U&id=19329590362&ns=1&abbucket=17#detail I think you meant this? Edited March 6, 2015 by nazerath 4 Link to post Share on other sites More sharing options...
Kb27 Supersonic March 6, 2015 Share March 6, 2015 How you charge the separate batt ? You can use the same alternator to charge. Use a relay that connects the 2nd battery to the alternator, when ignition is switched on. That way, when you switch off the engine, only the 2nd battery is connected to the camera and not to the main battery. When engine is off, camera drains 2nd battery flat, doesn't matter; bcuz the main battery is not connected, you can still start the engine. Another way is to install a battery isolator. This is similar to some Merz using auxiliary battery. 2 Link to post Share on other sites More sharing options...
Feliss Neutral Newbie March 19, 2015 Share March 19, 2015 I'm using Marbella MX6. So far so gd. But only front facing camera. Resolution is good. You can give it a try, just a lil expensive. Can get it from IT fair. Link to post Share on other sites More sharing options...
campagnolo Neutral Newbie March 26, 2015 Share March 26, 2015 I'm using Optian smart camera, front and back, so far so good. Abit pricey though, got it from a salesman from I-tracking Singapore. Link to post Share on other sites More sharing options...
lancer6238 1st Gear March 28, 2015 Share March 28, 2015 Anyone using the Itronics ITB-100 Wifi camera? I'm using the older non-Wifi version for about a year and am pretty satisfied with it. But I've read some reviews on the Wifi version having issues. I'm not sure if the sole distributor is still selling the non-Wifi version. If there's too many problems with the Wifi version, I may consider iRoad v7. The downside is I think the iRoad rear camera isn't as clear? Link to post Share on other sites More sharing options...
Columbian78 6th Gear March 28, 2015 Share March 28, 2015 (edited) Anyone using the Itronics ITB-100 Wifi camera? I'm using the older non-Wifi version for about a year and am pretty satisfied with it. But I've read some reviews on the Wifi version having issues. I'm not sure if the sole distributor is still selling the non-Wifi version. If there's too many problems with the Wifi version, I may consider iRoad v7. The downside is I think the iRoad rear camera isn't as clear? I have both the wifi and non wifi versions of itb100 on my car for approx 4 months and more than 1 year respectively. Both do not give me major technical problems. However, the video quality of the non wifi is obviously better. So if you do not really need wifi and larger 64gb storage capability, just get non wifi. Edited March 28, 2015 by Columbian78 Link to post Share on other sites More sharing options...
lancer6238 1st Gear March 29, 2015 Share March 29, 2015 I have both the wifi and non wifi versions of itb100 on my car for approx 4 months and more than 1 year respectively. Both do not give me major technical problems. However, the video quality of the non wifi is obviously better. So if you do not really need wifi and larger 64gb storage capability, just get non wifi. Thanks! I'll just get the non-wifi version then. Link to post Share on other sites More sharing options...
Baal Supersonic March 29, 2015 Share March 29, 2015 If install cam that is directly connected to battery (basically because AD wont to do it for you),will it void warranty?Cam is also with rear view. Wiring from front to back area is concealed in car ceiling. 4 Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 29, 2015 Share March 29, 2015 Hi sorry what's g1w? I found fox offer. I have no problem getting from tabao too it that helps. Locally wise any shops or models ? Thanks for yr reply. http://item.taobao.com/item.htm?spm=a230r.1.14.17.tUA35U&id=19329590362&ns=1&abbucket=17#detail I think you meant this? try this : http://www.foxoffer.com/g1w-full-hd-1080p-vehicle-blackbox-dvr-no-battery-black-p-653.html#.VRelhfyUeSo 1 Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear April 2, 2015 Share April 2, 2015 Bought the iroad V7 during IT show at 229. Installed it at nam huat and so far so good. Value for money for a 2 channel cam. Link to post Share on other sites More sharing options...
cven Clutched April 2, 2015 Share April 2, 2015 I am using iroad GT. Connect directly to car battery. Able to record for 3-4 days before the automatic voltage cuts off power. No issue starting car. You can also set what voltage to cut off. Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 2, 2015 Share April 2, 2015 (edited) try this : http://www.foxoffer.com/g1w-full-hd-1080p-vehicle-blackbox-dvr-no-battery-black-p-653.html#.VRelhfyUeSo it does fall off easily in the sun though. the suction cup. No complaints otherwise. I haven't even gotten down to running a dedicated wire for it. Still using 12v socket lol... Edited April 2, 2015 by Lala81 1 Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear April 5, 2015 Share April 5, 2015 it does fall off easily in the sun though. the suction cup. No complaints otherwise. I haven't even gotten down to running a dedicated wire for it. Still using 12v socket lol... Yup.. the suction cup always does that in direct sun and high heat.. Glad you are OK with this budget cam.. can't ask for much bells and whistles at US$60.. If you're along Geylang, can drop by Lor 39 to fix the cable.. wont take too long and much neater than loose wire hanging around... Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic April 11, 2015 Share April 11, 2015 Bought the iroad V7 during IT show at 229. Installed it at nam huat and so far so good. Value for money for a 2 channel cam. I tried to ask them to install in my car for 2ch with battery for overnight parking, but they said my car too complicated. Anyone can recomend me preferable in west area? Prefer those with conti experience ↡ Advertisement Link to post Share on other sites More sharing options...
Reverse/backup camera with dashcam recording function
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
Dashcam with GPS
Dashcam with GPS
Blackvue users - please come in AGAIN 2
IRoad X9 drains battery until it is flat
