mersaylee Hypersonic June 24, 2024 Share June 24, 2024 On 6/24/2024 at 9:39 AM, Jamesc said: In the old days I always hear add curry powder to radiator to stop a leak. I imagine you just get curry soup in the radiator. One that works is break down in the middle of nowhere ask gf to take off her pantyhose. Use it as emergency fan belt. But don't need to repair so fast lah. Can repair after finish. Not add to the fuel tank for more powderful combustion meh? Cars behind better not have windows wind down...unless a curry lover...😁 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 24, 2024 Share June 24, 2024 On 6/24/2024 at 10:08 AM, Kklee said: IMHO. Premixed coolant ? I had microsopic leaks before between the seams of the radiator top and coolant fins - different material and use of water for mixing with coolant. This kind of fault a bit hard to locate. I noticed my coolant system got issue because of the coolant temp keep rising on the scangauge device. this coolant need to mix with water 1:1 before use the choice of material, in this case, plastic, made it a consumable part it happened on her previous car too, at 140,000km current car is 101,000km now last car coolant was blue colour, it dripped on to the heatshield of the exhaust manifold, that distinctive smell lead me to it 😁 the location of the pipes was easily accessible on the previous car, I replaced it at home. The plastic coolant pipe of the current car buried deep under the intake manifolds, got to take out airbox, ECU, intake manifolds, throttle body before I can reach the pipe, I will leave it to the workshop 😁 the plastic pipe become brittle after boiled in the coolant for 140,000km, it was so crispy and crushed like love letter 6 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 24, 2024 Share June 24, 2024 (edited) On 6/24/2024 at 12:33 PM, Gnahp said: this coolant need to mix with water 1:1 before use the choice of material, in this case, plastic, made it a consumable part it happened on her previous car too, at 140,000km current car is 101,000km now last car coolant was blue colour, it dripped on to the heatshield of the exhaust manifold, that distinctive smell lead me to it 😁 the location of the pipes was easily accessible on the previous car, I replaced it at home. The plastic coolant pipe of the current car buried deep under the intake manifolds, got to take out airbox, ECU, intake manifolds, throttle body before I can reach the pipe, I will leave it to the workshop 😁 the plastic pipe become brittle after boiled in the coolant for 140,000km, it was so crispy and crushed like love letter Conti cars' plastic all CMI. Designed to fail. Many cars ago I replaced a leaking plastic elbow with a brass one. Edited June 24, 2024 by Volvobrick 5 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 24, 2024 Share June 24, 2024 On 6/24/2024 at 1:09 PM, Volvobrick said: Conti cars' plastic all CMI. Designed to fail. Many cars ago I replaced a leaking plastic elbow with a brass one. German car runs at either 90 deg (NA) or 120 deg (turbo) water temperature. Hard NOT to have failed plastic at that temperature. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 24, 2024 Share June 24, 2024 On 6/24/2024 at 1:11 PM, inlinesix said: German car runs at either 90 deg (NA) or 120 deg (turbo) water temperature. Hard NOT to have failed plastic at that temperature. Wrong material selected and used then. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 24, 2024 Share June 24, 2024 On 6/24/2024 at 12:33 PM, Gnahp said: this coolant need to mix with water 1:1 before use the choice of material, in this case, plastic, made it a consumable part it happened on her previous car too, at 140,000km current car is 101,000km now last car coolant was blue colour, it dripped on to the heatshield of the exhaust manifold, that distinctive smell lead me to it 😁 the location of the pipes was easily accessible on the previous car, I replaced it at home. The plastic coolant pipe of the current car buried deep under the intake manifolds, got to take out airbox, ECU, intake manifolds, throttle body before I can reach the pipe, I will leave it to the workshop 😁 the plastic pipe become brittle after boiled in the coolant for 140,000km, it was so crispy and crushed like love letter IMHO. In my case, the workshop never use deionized or distilled water. Yeah, plastic is another issue. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 24, 2024 Share June 24, 2024 On 6/24/2024 at 1:52 PM, Kklee said: IMHO. In my case, the workshop never use deionized or distilled water. Yeah, plastic is another issue. boss, deionized and distilled water expensive ah.... even me myself drink tap water only I use distilled water Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 24, 2024 Share June 24, 2024 On 6/24/2024 at 2:10 PM, Gnahp said: boss, deionized and distilled water expensive ah.... even me myself drink tap water only I use distilled water Buy distilled drinking water lo. I use it for my car. 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged June 24, 2024 Share June 24, 2024 On 6/24/2024 at 1:52 PM, Kklee said: IMHO. In my case, the workshop never use deionized or distilled water. Yeah, plastic is another issue. Nowadays most coolant should be pre-mixed already? I know my toyota super long life coolant comes ready to pour, no adding of water. This is intentional to prevent kuku bird from cocking up the mixing process or using bad liquid 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 24, 2024 Share June 24, 2024 aiyah... typical conti problem. always oil leak coolant leak. bloody germans and french cannot get their act together after all these decades. lousy toyota wish, vios.... same radiator, coolant house and expansion tank for 10years. 2 4 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 24, 2024 Share June 24, 2024 On 6/24/2024 at 4:21 PM, Mkl22 said: aiyah... typical conti problem. always oil leak coolant leak. bloody germans and french cannot get their act together after all these decades. lousy toyota wish, vios.... same radiator, coolant house and expansion tank for 10years. Will Toyota have the same problem if it runs at 90 deg water temperature? 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 24, 2024 Share June 24, 2024 On 6/24/2024 at 2:10 PM, Gnahp said: boss, deionized and distilled water expensive ah.... even me myself drink tap water only I use distilled water IMHO. Collect after heavy rain.... pure water. 👍 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 24, 2024 Share June 24, 2024 On 6/24/2024 at 3:46 PM, t0y0ta said: Nowadays most coolant should be pre-mixed already? I know my toyota super long life coolant comes ready to pour, no adding of water. This is intentional to prevent kuku bird from cocking up the mixing process or using bad liquid IMHOO. Toyota is premix. Before that, is mix. My workshop like to use tap water. After timing belt change, radiator may have issue. Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 24, 2024 Share June 24, 2024 I understand the reasons behind both 😁 - mix 1:1 before use, save 50% of the shipping weight and storage space, it is dumb to ship and store water - pre-mixed, like mentioned by tOyOta, it saves the engine from kuku people mixing it with the wrong water or ratio 3 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 24, 2024 Share June 24, 2024 On 6/24/2024 at 7:41 PM, Gnahp said: I understand the reasons behind both 😁 - mix 1:1 before use, save 50% of the shipping weight and storage space, it is dumb to ship and store water - pre-mixed, like mentioned by tOyOta, it saves the engine from kuku people mixing it with the wrong water or ratio IMHO. At workshop, if premixed, can know exactly how much coolant is used and compare with specification. If coolant mix with water, wrong also difficult to know. 2 Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 25, 2024 Share June 25, 2024 On 6/23/2024 at 11:34 PM, Gnahp said: I noticed the coolant level of my wife's car is dropping slowly since a few months ago at the rate of around 500ml per 10,000km, that is not normal but not a big leak too, not enough to trigger the low coolant level warning in 10,000km I also couldn't find any dried up coolant traces on the engine and the engine compartment during my routine checks today I took out my borescope to check areas that I cannot see from outside found some dried up coolant traces on the seam of the plastic coolant pipe under the intake manifolds 😑 farking plastic hoses as usual in conti cars, please change to aftermarket metal parts if available, this will save you a lot of headache in the long run. 3 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 25, 2024 Share June 25, 2024 On 6/24/2024 at 11:14 AM, mersaylee said: Got mention raw or soft boiled or hard boiled...? 😁 It depends on driver. If they like it raw, go raw. If they like it soft go soft. If people like it hard go hard. 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 25, 2024 Share June 25, 2024 On 6/25/2024 at 11:57 AM, Beehive3783 said: farking plastic hoses as usual in conti cars, please change to aftermarket metal parts if available, this will save you a lot of headache in the long run. Plastic save cost. For manufacturer not owner. That plastic part from dealer can be $200. It will crack and they will make money on after market parts. ↡ Advertisement 2 2 Link to post Share on other sites More sharing options...
Coolant question
Coolant question
No Down Payment Required, 100% Finance Available
Fatty Kim going crazy again
