Ct3833 Supersonic April 18 Share April 18 On 4/18/2026 at 1:05 PM, Volvobrick said: Polish one time body ache 1 week needing 3 sessions of massage. Income less than recovery expenses! Some money is just not for us to save🤣. But look at it positively, body still can move is a blessing.😃 ↡ Advertisement 2 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic April 19 Share April 19 On 3/24/2026 at 9:57 AM, Mkl22 said: does this also work to get rid of watermarks for shower glass? Since Rain X will help the water glide down from car windscreen. If apply Rain X on shower screen , will it help reduce water mark? Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 19 Share April 19 On 4/19/2026 at 10:37 AM, Tohto said: Since Rain X will help the water glide down from car windscreen. If apply Rain X on shower screen , will it help reduce water mark? I won't use rainX or any other brand on plastic screen...glass wise should be fine Link to post Share on other sites More sharing options...
Tohto Hypersonic April 19 Share April 19 On 4/19/2026 at 10:48 AM, mersaylee said: I won't use rainX or any other brand on plastic screen...glass wise should be fine Mine glass screen 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 19 Author Share April 19 On 4/19/2026 at 10:37 AM, Tohto said: Since Rain X will help the water glide down from car windscreen. If apply Rain X on shower screen , will it help reduce water mark? It should. That's what i originally bought the rain-X for. but my toilets glass screen is already quite jialat liao. So bit can't be bothered anymore. Every few months just try my best. Got no helper and no energy/time to keep cleaning it. 1 Link to post Share on other sites More sharing options...
Kklim Supercharged April 19 Share April 19 On 4/19/2026 at 10:59 AM, Lala81 said: It should. That's what i originally bought the rain-X for. but my toilets glass screen is already quite jialat liao. So bit can't be bothered anymore. Every few months just try my best. Got no helper and no energy/time to keep cleaning it. Try using white vinegar to remove the marks Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 19 Share April 19 (edited) On 4/19/2026 at 10:37 AM, Tohto said: Since Rain X will help the water glide down from car windscreen. If apply Rain X on shower screen , will it help reduce water mark? You need the glass to be clean. Also it can flake later on and be patchy. so I wouldn’t. Edited April 19 by Mkl22 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 I'm trying to install a wall mounted pull up bar. I'm kinda confused how this mounting bolts are supposed to work. I also read from some buyers that the mounting bolts given are incorrect. So I'm bit confused. I have eight of these (4 on each side). 1 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 OK sorta found out it works. 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic April 25 Share April 25 On 4/25/2026 at 5:05 PM, Lala81 said: I'm trying to install a wall mounted pull up bar. I'm kinda confused how this mounting bolts are supposed to work. I also read from some buyers that the mounting bolts given are incorrect. So I'm bit confused. I have eight of these (4 on each side). I used these bolts to install heavy fan and tv. First you measure the correct size hole to be drilled into masonry, typically, 6, 8, 10mm. The hole depth should be about the whole length of the bolt, minus the top 1 cm or so, so the top part of the thread should be sticking out. Insert the sleeve with the split end at the bottom. Then you insert your load (tv, bar, etc) over the bolt thread, followed by washer, spring washer, and finally the nut. As you tightened the nut, the bolt will move upwards (outwards). The bottom will split the sleeve open jamming it against the wall of the hole, so it won't ever come out. Now your load is hanging onto the immovable bolt. If you decide to remove your load later on, the threaded part of the bolt will be left there sticking out. In some cases, you might want to level the top, which means cutting out the thread. 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 Need to buy a 14mm sds drill bit first. 3 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic April 25 Share April 25 (edited) On 4/25/2026 at 5:37 PM, Lala81 said: Need to buy a 14mm sds drill bit first. 14mm sounds like mounting the chin up bar for elephant! Sure so big? And 8 bolts! Edited April 25 by Volvobrick 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 On 4/25/2026 at 5:42 PM, Volvobrick said: 14mm sounds like mounting the chin up bar for elephant! Sure so big? And 8 bolts! The expansion sleeve and the end of the bolt diameter is 14mm. The bolt itself is only a M10 They scared Bui Bui kia hang off the bar mah. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 25 Share April 25 On 4/25/2026 at 5:36 PM, Kb27 said: I used these bolts to install heavy fan and tv. First you measure the correct size hole to be drilled into masonry, typically, 6, 8, 10mm. The hole depth should be about the whole length of the bolt, minus the top 1 cm or so, so the top part of the thread should be sticking out. Insert the sleeve with the split end at the bottom. Then you insert your load (tv, bar, etc) over the bolt thread, followed by washer, spring washer, and finally the nut. As you tightened the nut, the bolt will move upwards (outwards). The bottom will split the sleeve open jamming it against the wall of the hole, so it won't ever come out. Now your load is hanging onto the immovable bolt. If you decide to remove your load later on, the threaded part of the bolt will be left there sticking out. In some cases, you might want to level the top, which means cutting out the thread. Sometimes can hammer the bolt in and it will be flush then putty over. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 25 Share April 25 On 4/25/2026 at 5:48 PM, Lala81 said: The expansion sleeve and the end of the bolt diameter is 14mm. The bolt itself is only a M10 They scared Bui Bui kia hang off the bar mah. I think 4bolts enough liao. 8 is overkill. The bar will break before the bolt comes out 3 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 25 Author Share April 25 On 4/25/2026 at 6:48 PM, Mkl22 said: I think 4bolts enough liao. 8 is overkill. The bar will break before the bolt comes out It's 4 per side leh. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 25 Share April 25 (edited) On 4/25/2026 at 7:38 PM, Lala81 said: It's 4 per side leh. Yes I know. Hence just 2 diagonally can Liao. 4 per side is over over kill Edited April 25 by Mkl22 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home repair advice needed
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
