badlammy 6th Gear December 2, 2021 Share December 2, 2021 5 minutes ago, Fcw75 said: Yah man, lithium don’t like heat. What did you do with it? Throw at reckless driver? Hahaha Cable can still use to read direct voltage. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Othello Supersonic December 2, 2021 Share December 2, 2021 31 minutes ago, Fcw75 said: My Baseus toy also came. 😁 wow, yours damn DUA KEE, damn THICK ! 😎 mine .... lose. Will know who to call liao, when I need your THING 😁 6 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 2, 2021 Share December 2, 2021 Just now, badlammy said: Cable can still use to read direct voltage. Baseus no have this but definitely good to have. Btw, if early morning before starting car, what should be the battery voltage? Is 11.3V still normal? Below what is considered weak battery? Link to post Share on other sites More sharing options...
Kb27 Supersonic December 2, 2021 Share December 2, 2021 the bigger the lithium-ion, the more problematic. just look at the PMDs fire. 1 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 2, 2021 Share December 2, 2021 (edited) 4 minutes ago, Othello said: wow, yours damn DUA KEE, damn THICK ! 😎 mine .... lose. Will know who to call liao, when I need your THING 😁 @kobayashiGT 不识货。 Yours is 9000mah, I also have one. Go big or go home! But Utrai even bigger. 😁 You can have my THING anytime you want bro. 😍🤣 Just a WhatsApp msg away, nearby anyway. Edited December 2, 2021 by Fcw75 3 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 2, 2021 Share December 2, 2021 8 minutes ago, Fcw75 said: Baseus no have this but definitely good to have. Btw, if early morning before starting car, what should be the battery voltage? Is 11.3V still normal? Below what is considered weak battery? For me, its the CCA that matters more. Once hit 40% if its full capacity, starter pack should be on standby liao. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 2, 2021 Share December 2, 2021 4 minutes ago, Hamburger said: For me, its the CCA that matters more. Once hit 40% if its full capacity, starter pack should be on standby liao. You have a voltmeter bro? Link to post Share on other sites More sharing options...
badlammy 6th Gear December 2, 2021 Share December 2, 2021 14 minutes ago, Fcw75 said: Baseus no have this but definitely good to have. Btw, if early morning before starting car, what should be the battery voltage? Is 11.3V still normal? Below what is considered weak battery? For direct reading, I try to keep 12V minimum. If using those cig adapter readers, maybe ard 11.7V. 11.3V bit too low liao... 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2021 Share December 2, 2021 13 minutes ago, Fcw75 said: @kobayashiGT 不识货。 Yours is 9000mah, I also have one. Go big or go home! But Utrai even bigger. 😁 You can have my THING anytime you want bro. 😍🤣 Just a WhatsApp msg away, nearby anyway. Oh. sound abit. erm.. too friendly. 🤣 thanks thanks! I just changed my car battery. Don't think will die on me. hahahaha. 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2021 Share December 2, 2021 26 minutes ago, Fcw75 said: Yah man, lithium don’t like heat. What did you do with it? Throw at reckless driver? Hahaha I pass it to my father. My father used to be a TV repair man, so he like to dismantle stuff and look at the puny IC board. hahahahahahahahahah. I think now at semakau wastefill liao. 😂 The cable are still in my car. Next time if my car cannot start i will plug the cable and ask other car for battery only. 🤣 Must be baseus one ah. hahahaahha 1 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 2, 2021 Share December 2, 2021 3 minutes ago, badlammy said: For direct reading, I try to keep 12V minimum. If using those cig adapter readers, maybe ard 11.7V. 11.3V bit too low liao... Ok noted with thanks. Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 2, 2021 Share December 2, 2021 11 minutes ago, Fcw75 said: You have a voltmeter bro? Bro, get one of this gadgets. Cheap and good. It measures the CCA, impedenace, voltage etc. A bad battery will have more than 10 mohms and its almost unusable. 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2021 Share December 2, 2021 18 minutes ago, Hamburger said: Bro, get one of this gadgets. Cheap and good. It measures the CCA, impedenace, voltage etc. A bad battery will have more than 10 mohms and its almost unusable. Need a new one! The plastic is peeling! hahahaha. Link to post Share on other sites More sharing options...
Othello Supersonic December 2, 2021 Share December 2, 2021 (edited) 18 minutes ago, kobayashiGT said: Need a new one! The plastic is peeling! hahahaha. then old one pass to you right ? Anyway, your office should have all these gadgets. Then if need I walk over and T-Loan 🤣 Edited December 2, 2021 by Othello 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 2, 2021 Share December 2, 2021 1 hour ago, Othello said: wow, yours damn DUA KEE, damn THICK ! 😎 mine .... lose. Will know who to call liao, when I need your THING 😁 DUA KEE and BLACK! Just like mine. Yours is...... puny white..... How to do a good job? 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 2, 2021 Share December 2, 2021 3 minutes ago, Othello said: then old one pass to you right ? Anyway, your office should have all these gadgets. Then if need I walk over and T-Loan 🤣 Quotz have lah, my office doesn't have. I cannot go down and just take leh. You wanna see me go out of job ah. hahahahaha. My father have this sanwa multimeter thou. I use this to test my battery health. hahahahaha. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 2, 2021 Share December 2, 2021 1 hour ago, kobayashiGT said: Quotz have lah, my office doesn't have. I cannot go down and just take leh. You wanna see me go out of job ah. hahahahaha. My father have this sanwa multimeter thou. I use this to test my battery health. hahahahaha. Multimeter can't check your battery health. It can only check state-of-charge. Example, your alternator is working fine, it charged the battery with 14Vdc. So after you switch off engine, let the battery voltage sink down a bit to its nominal value, if you read 12.6V or so, it means it's fully charge (state-of-charge). However, this alone does not tell you the true condition of the battery. You need a digital battery analyser to read the CCA to tell you what condition it's in, after it's fully charged. 5 Link to post Share on other sites More sharing options...
Beregond Supersonic December 2, 2021 Share December 2, 2021 11 minutes ago, Kb27 said: Multimeter can't check your battery health. It can only check state-of-charge. Example, your alternator is working fine, it charged the battery with 14Vdc. So after you switch off engine, let the battery voltage sink down a bit to its nominal value, if you read 12.6V or so, it means it's fully charge (state-of-charge). However, this alone does not tell you the true condition of the battery. You need a digital battery analyser to read the CCA to tell you what condition it's in, after it's fully charged. buy those cheapskate battery tester that ws love to use also can ( those type when u can pull or press a button and can check its crank power) those cheap 1 u pull too long can see smoke come out🤣) ↡ Advertisement Link to post Share on other sites More sharing options...
Used Mercedes buyer spends $40,000 on repairs
A Snowstorm Trapped 50 People in a Remote Pub With an Oasis Tribute Band for 3 Days
Tesla app also got outage, owners can't start car
Well done Traffic Police Officers & passerbys for helping car driver to push stalled car from junction!
Video: Malaysia Racism Experiment 2.0 – Car Breakdown
Hong Kong MTR 6 Hours Breakdown
Rear seat belt stuck
