SGMCF328 Turbocharged October 17, 2022 Share October 17, 2022 Everything also can cheat. It is not only bad for our environment, but our health too. 😷 Source: https://www.straitstimes.com/singapore/transport/emission-cheating-devices-installed-in-some-trucks-and-buses-in-singapore SINGAPORE - Some diesel trucks and buses in Singapore have been fitted with devices that override the systems meant to clean up their exhaust emissions, The Straits Times has learnt. Popularly known as "defeat devices", they are sold online and allow vehicles to bypass emission standards and, in doing so, spew out high levels of nitrogen oxide - a poisonous greenhouse gas. Vehicle owners can save thousands of dollars each year by skimping on the exhaust treatment solution, known as AdBlue, which removes nitrogen oxide from diesel vehicle's exhaust emissions. At least one local workshop was found to offer an "AdBlue removal service", in addition to freelance mechanics who install such devices for a fee. In response to queries, the National Environment Agency (NEA) said it does not regulate the use of such cheat devices. But the agency, which sets vehicle emission standards here, added that it takes a serious view of devices that may bypass teh control of pollutant emissions. NEA also said it will work with inspection centres to monitor the use of such devices and enhance its regulations where necessary. It is not known how prevalent such devices are in Singapore. They are illegal in most European countries. Based on data from the Land Transport Authority, there are 172,996 diesel-powered vehicles as at Aug 31. The majority of those that are eight years old or newer would require AdBlue to operate properly. Diesel engine emissions include nitrogen oxide. When diesel vehicle is running, AdBlue, which is stored in a separate tank, is automatically injected into the exhaust system to convert the harmful fumes into nitrogen and water before the gases leave the vehicle's tailpipe. AdBlue is used in many diesel trucks and buses on Singapore roads. Globally, the exhaust treatment fluid is widely adopted by vehicle manufacturers to meet tightening emission standards. Keeping the vehicle topped up with AdBlue costs around 4 per cent to 5 per cent of the amount spent on diesel fuel. Commercial vehicles that clock high mileage will need to refill AdBlue more frequently. The solution is available at petrol stations as well as specialised AdBlue sellers. For private cars that do not cover so many kilometers, the top-up is usually done as part of the annual service at workshops. The price of Adblue is influenced by the rising cost of natural gas, a key ingredients used in its production. Currently, Adblue costs between $1.70 per litre to over $2 a litre, up 30 per cent from prices in 2021. In addition to saving on AdBlue refills, the cheat device enables the vehicle to be driven, even if the emission-control system is broken. Breakdowns can be caused by poor maintenance or by using lubricants that are meant for older diesel vehicles, which are cheaper to buy but are not suitable for these engines. Fixing such control systems is expensive. Mr Chew Guan Do, 62, who manages a fleet of trucks, said the bill easily exceeds $2,000 when control systems on the tipper trucks fail. Diesel vehicles also seem to need such repair more frequently as they age, adding downtime on top of hefty bills. There are different types of cheat devices - but their main function is to hookwink the vehicle's sensors to think there is AdBlue in the system when there is none. The simplest version of such devices, which are available online for as little as $40, plugs directly into a vehicle's diagnostic port. This type of devices, which takes the vehicle's emission-cleaning system out of play, can be removed before regular inspections. Experts said the vehicle will function normally and pass the tests, if it is otherwise roadworthy. A freelance engine-tuning expert, who spoke on the condition of anonymity, said he has programmed a truck's computer to bypass the emission control system and has not had any issues. Many of these hacks promise improved fuel efficiency and increase engine performance. With the added horsepower, the engine will produce even more poisonous exhaust gases. ↡ Advertisement 3 2 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 17, 2022 Share October 17, 2022 Heng my one euro 2 no need eat expensive stuff 5 Link to post Share on other sites More sharing options...
SGMCF328 Turbocharged October 17, 2022 Author Share October 17, 2022 6 minutes ago, Mustank said: Heng my one euro 2 no need eat expensive stuff But your COE expiring in a few years time right? You can never win our government one.😝 1 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic October 17, 2022 Share October 17, 2022 (edited) I also enquire before when the company's diesel truck DPF has the flashing warning light come on. The DPF can be replace with one that wont show any warning light and can pass inspection. Cost about a thousand odd dollars, original easily about $3K to $5K depending what is replaced. The DPF is quite ex to replace. I didnt ask much about it cos I wasnt keen. Could be this device they will install. I used a DPF cleaner that solved the warning light issue. Cleaner only cost $15. If I were to bring to workshop and flush the DPF with water also need to pay about $350 for labour. Not surprising about cheat device. I mentioned a friend's old gen Toyota Fortuner(petrol) before. Warning light about the exhaust light up, went to workshop and found out there is an electric motor and a fan that pumps outside air into the exhaust to dilute the exhaust emission. The motor failed, need replacement. LoL...and this is legal? This is an original part. It was unbelievable. I believe ppl be it workshop or car maker will try all sorts of way to beat the test. Edited October 17, 2022 by Watwheels 2 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic October 17, 2022 Share October 17, 2022 "In response to queries, the National Environment Agency (NEA) said it does not regulate the use of such cheat devices." Closing both eyes, not their problem? It should be considered tempering of the emissions control system with sever consequences. Layman like me can give a better response to the JLB. We should impound vehicles found with such devices. 2 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 17, 2022 Share October 17, 2022 1 minute ago, Volvobrick said: "In response to queries, the National Environment Agency (NEA) said it does not regulate the use of such cheat devices." Closing both eyes, not their problem? It should be considered tempering of the emissions control system with sever consequences. Layman like me can give a better response to the JLB. We should impound vehicles found with such devices. Because it fall under LTA. JLB works in silo Link to post Share on other sites More sharing options...
Mustank Hypersonic October 17, 2022 Share October 17, 2022 Idkfa iddqd showmethemoney Link to post Share on other sites More sharing options...
Mustank Hypersonic October 17, 2022 Share October 17, 2022 Reminds me of gnr song Been hidin' out And layin' low It's nothing new ta me Well They're out ta get me They won't catch me I'm f**king innocent They won't break me Link to post Share on other sites More sharing options...
Mustank Hypersonic October 17, 2022 Share October 17, 2022 24 minutes ago, SGMCF328 said: But your COE expiring in a few years time right? You can never win our government one.😝 After coe expire, I probably take bus Liao can’t afford coe for now, I 潇洒走一回 2 Link to post Share on other sites More sharing options...
Soya Supersonic October 17, 2022 Share October 17, 2022 Everyday JB bas, lori & motorbike spew much more smoke in sg n nothing is being done They must be laughing at this news 3 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 17, 2022 Share October 17, 2022 6 minutes ago, Soya said: Everyday JB bas, lori & motorbike spew much more smoke in sg n nothing is being done They must be laughing at this news I see more Local trucks putting out black smoke. In Sg, we have cheapo you Sai. 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged October 17, 2022 Share October 17, 2022 my friend asking why no hav spouse cheating device huh 🙉🙊🙈 will be selling like hotcakes 😁😁😁😋😋😋 1 Link to post Share on other sites More sharing options...
Gizmore Supercharged October 17, 2022 Share October 17, 2022 49 minutes ago, SGMCF328 said: The simplest version of such devices, which are available online for as little as $40, plugs directly into a vehicle's diagnostic port. This type of devices, which takes the vehicle's emission-cleaning system out of play, can be removed before regular inspections. Experts said the vehicle will function normally and pass the tests, if it is otherwise roadworthy. I don't quite understand how it works here. So plug in the device and the error goes away. During inspection, unplug the device, but wouldn't the error comes back up again? Unless the error takes a while to surface. i.e. must drive over a certain distance for the ECU to detect no Adblue and shows the error. If so, then I think the inspection is not robust enough. Anybody can enlighten? 1 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 17, 2022 Share October 17, 2022 14 minutes ago, Inlinefour said: my friend asking why no hav spouse cheating device huh 🙉🙊🙈 will be selling like hotcakes 😁😁😁😋😋😋 You spouse can track your phone hor 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 17, 2022 Share October 17, 2022 14 minutes ago, Gizmore said: I don't quite understand how it works here. So plug in the device and the error goes away. During inspection, unplug the device, but wouldn't the error comes back up again? Unless the error takes a while to surface. i.e. must drive over a certain distance for the ECU to detect no Adblue and shows the error. If so, then I think the inspection is not robust enough. Anybody can enlighten? For adblue, ECU will flash error when low or no adblue. Comes inspection, with adblue added back into diesel, NOX will goes back to legal level. Link to post Share on other sites More sharing options...
Gizmore Supercharged October 17, 2022 Share October 17, 2022 1 minute ago, inlinesix said: For adblue, ECU will flash error when low or no adblue. Comes inspection, with adblue added back into diesel, NOX will goes back to legal level. I see... Then ODB port needs to have a LTA seal on it to prevent such attachment from being used. If workshop need to access the port for diagnostic, remove seal, then vehicle go back to LTA to get it sealed back after servicing. Link to post Share on other sites More sharing options...
ER-3682 Supersonic October 17, 2022 Share October 17, 2022 VW "Dieselgate" worst.. Link to post Share on other sites More sharing options...
ER-3682 Supersonic October 17, 2022 Share October 17, 2022 AdBlue too expensive.?Maybe can collect Human & Animal's Urine..& pour in,work the same..i heard.🤣 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Bring back HSR to ‘excite the world again’, says Najib
Crazy weather in Singapore ?
The BMW G87 M2 is here
CNA Insider 5 things you might not know about Singapore’s split with Malaysia, in Separation: Declassified
