Washing machine repair
Hamburger
Hypersonic
That's pretty shortlived for a washing machine.
I generally buy extended warranty for washing machines.
BD has the cheapest 5 year warranties usually.
Extended warranty dont really need for washing machine, esp nowadays generally washing machine quite cheap. Unless you buy those expensive washing machine?!
$700 to $1000+ is not cheap lor, one year vs extended to 5 yrs worth considering lor.
front loaders aren't that cheap until u won't want to repair them.
Top loaders then buy and throw.
okay . . guess I'll drop by BD this weekend.
This WM I bought from one neighbourhood shop . . . colleague recommended one [:(]
Buy LG. 5 yr warranty.
LG better than SS? :huh:
Only on the direct drive system? Same as Samsung. Other usual parts which are more likely to spoil no such things. Unless u purchase yourself the warranty
Samsung front loaders are expensive I feel. No point paying the premium for them. Australian reviews aren't too awesome as well. I rate them on par with LG.
1 hour ago, Kezg1 said:
hi All.....anyone know of Washing Machine repair man to recommend ?? Thanks in advacnce
It is better to describe what your problem is that others may also have encountered?
Sometimes it is NOT worth repairing because parts are expensive or machine just too old and inefficient.
If after 2-3 years, used regularly at least 2 or 3 times a week, then worth consider replacing the machine, unless it is a Miele.
  • Praise 2
..rattling sound and water keep flowing out and cannot be contain inside the bucket...only can spin now...so any idea what is the problem??
Rattling sound - if it happens for every load and of recent event, your shocks (suspension) gone
water keep flowing out - see if your filter is clogged which should be found at the bottom of your washing machine with a door usually
Spin now only - because sensors detect contradictory signals
Action
clean your filter if it does not work then highly likely your PCB lorry up
  • Haha! 2
Action
Minister for trade and industry 1😂👍
Buy a front load and move on😄
The common wm problems are belt worn(like no power), ball bearing worn (screeching, seizure), seal needs replacement (leaking) or logic board got issue(rare). The motor is usually quite reliable across most brands.
Of course the longevity of the wm also depends on the users. Most of the time users overload the wm. If your wm is rated at 10kg but ppl overload it with 20kg, your wm will no doubt fail prematurely. The typical kiasu user who wants to save time, save detergent, save water will kill the wm even faster.
Edited by Watwheels
  • Haha! 1
My drainage hose suddenly leaking out of water at the drainage hole when water is drained out from the washer, my kitchen become ponding siah!
This is my second time my washer has such problem! Different brand somemore. Headache. 😓
Edited by 13177
This one is drainage hole chock lah
thses type you need you clear the hole
use those drainage chock clearer
  • Praise 3
