Bluepica 4th Gear January 2, 2015 Share January 2, 2015 Happy new YEar! I got 3 radio clocks (those plug into wall supply) of different brand at home. Everytime after tallying the time with my handphone, few weeks later 3 of them sure go faster than the actual time. Even the radio clocks at my cousin's home also behaving the same thing.... it can go as fast as 20mins from the actual time. Anyone have the same problem? Is it cause for the supply frequency of our wall outlet which should be 50hz right? ↡ Advertisement Link to post Share on other sites More sharing options...
Ender Hypersonic January 2, 2015 Share January 2, 2015 It's normal that clock or watches are not as accurate as the phone, which is sync to a time server. Eve normal Casio quartz watch are spec at +-15 or 20 sec per month.. But the one that is 20 mins off after a few weeks, is not acceptable. Link to post Share on other sites More sharing options...
Jtb 6th Gear January 2, 2015 Share January 2, 2015 Yr 1st bty connection was alkaline, most probably clock rhythm definitely will chg.future clock just insert everyday black bty or other bty without alkaline. Info alkaline current is higher. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 2, 2015 Share January 2, 2015 Same problem for my old alarm clock. It moves so fast it's 30mins faster after a couple of months and I have to recalibrate it. I got feed up and use my Android phablet. It can set to go off only on weekdays and not on weekends. I only set it once and hardly have to touch it ever since except for the last two weeks where PH is in the mid week. It's alot more accurate dan any digital alarm clock that I had before. Link to post Share on other sites More sharing options...
Celicar Turbocharged January 2, 2015 Share January 2, 2015 Try bringing the clocks to your office. Confirm will slow down.... 14 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged January 2, 2015 Share January 2, 2015 (edited) Happy new YEar! I got 3 radio clocks (those plug into wall supply) of different brand at home. Everytime after tallying the time with my handphone, few weeks later 3 of them sure go faster than the actual time. Even the radio clocks at my cousin's home also behaving the same thing.... it can go as fast as 20mins from the actual time. Anyone have the same problem? Is it cause for the supply frequency of our wall outlet which should be 50hz right? I dont believe in fengshui/old wives' tale etc but if all 3 clocks are ticking fast, there might be somethings to take note of. As someone might just say, time's up. Edited January 2, 2015 by Vhtfhwlego Link to post Share on other sites More sharing options...
Mustank Hypersonic January 2, 2015 Share January 2, 2015 (edited) Happy new YEar! I got 3 radio clocks (those plug into wall supply) of different brand at home. Everytime after tallying the time with my handphone, few weeks later 3 of them sure go faster than the actual time. Even the radio clocks at my cousin's home also behaving the same thing.... it can go as fast as 20mins from the actual time. Anyone have the same problem? Is it cause for the supply frequency of our wall outlet which should be 50hz right? you got a wrap drive engine at a home issit Edited January 2, 2015 by Mustank Link to post Share on other sites More sharing options...
Gnahp Twincharged January 2, 2015 Share January 2, 2015 AC main powered clock timing is not quartz governed, they count 50Hz from the mains supply and equate that to 1 second. The small error in the 50Hz signal will accumulate over time and gives an inaccurate time display. I bet the $3 IKEA battery powered clock is more accurate than the clock radio because the timing circuitry is governed by the quartz oscillation which is way more accurate than the Singapore Power 50Hz signal. 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 2, 2015 Share January 2, 2015 I think the clock depends on the weather. Hot and it runs faster. Link to post Share on other sites More sharing options...
The_Bear Turbocharged January 2, 2015 Share January 2, 2015 Radio wave clocks are the in thing in Japan right now but sadly we do not receive the signal in Singapore. http://www.seikowatches.com/support/ib/pdf/SEIKO_7B26_E.pdf Link to post Share on other sites More sharing options...
Ender Hypersonic January 2, 2015 Share January 2, 2015 AC main powered clock timing is not quartz governed, they count 50Hz from the mains supply and equate that to 1 second. The small error in the 50Hz signal will accumulate over time and gives an inaccurate time display. I bet the $3 IKEA battery powered clock is more accurate than the clock radio because the timing circuitry is governed by the quartz oscillation which is way more accurate than the Singapore Power 50Hz signal. Learnt something Link to post Share on other sites More sharing options...
Bluepica 4th Gear October 1, 2015 Author Share October 1, 2015 Last time I complaint about clock tick faster.... But since few months ago, all the radio clocks has been rocking slower than usual... Every week have to readjust to at least 5mins .... Apa ni?? Link to post Share on other sites More sharing options...
Kangadrool Supersonic October 1, 2015 Share October 1, 2015 what happened siah? I noticed my wall quartz clock and all my automatic watches also go slower. Need to adjust every fortnightly. Last time I complaint about clock tick faster.... But since few months ago, all the radio clocks has been rocking slower than usual... Every week have to readjust to at least 5mins .... Apa ni?? Link to post Share on other sites More sharing options...
Ktglfc Hypersonic October 1, 2015 Share October 1, 2015 They are telling you to slow down lah Time to change Link to post Share on other sites More sharing options...
Kb27 Supersonic October 1, 2015 Share October 1, 2015 My digital clock also run slower now. Must be the haze. Link to post Share on other sites More sharing options...
Mustank Hypersonic October 1, 2015 Share October 1, 2015 Alien come Link to post Share on other sites More sharing options...
Scion Turbocharged October 1, 2015 Share October 1, 2015 when you are young, time seems to move slowly (never finishing homework, never finishing exams...) when you are old, time seems to move very fast (another year passed, another year older) ↡ Advertisement 1 Link to post Share on other sites More sharing options...
All about Electric Cars Part 2
BYD Sealion 7
BYD Sealion 7
Aion Y Plus
Aion Y Plus
Ferrari Luce EV
Ferrari Luce EV
2022 Toyota bZ4X
2022 Toyota bZ4X
