Tianmo Hypersonic December 5, 2022 Share December 5, 2022 Anyone of you set up a home power back up? Can share what UPS you are using and/or what other power back up you using. Comments and feed backs on the pro and cons will be good. I am looking to set up something to back up power for my computer systems, including all the wireless system, so that can still operate for a while when there is a power failure or trip. Also looking to get a 600w to 1200w power bank for standby power. Any recommendations? ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 5, 2022 Share December 5, 2022 You do bitcoin mining ? 15 Link to post Share on other sites More sharing options...
Beanoyip Turbocharged December 5, 2022 Share December 5, 2022 SG context, need to have backup power????? Check out ecoflow. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator December 6, 2022 Share December 6, 2022 9 hours ago, Ct3833 said: You do bitcoin mining ? He is the kingpin for the darkweb mah. hahah. tikkok ranger always need a corner one. hahaha. 1 10 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 6, 2022 Share December 6, 2022 10 hours ago, Tianmo said: Anyone of you set up a home power back up? Can share what UPS you are using and/or what other power back up you using. Comments and feed backs on the pro and cons will be good. I am looking to set up something to back up power for my computer systems, including all the wireless system, so that can still operate for a while when there is a power failure or trip. Also looking to get a 600w to 1200w power bank for standby power. Any recommendations? Even if you have a UPS, during a power outage, the distribution unit of your telco would have stopped, so even you could maintain wifi running within your house, you will not have network out of your unit. Of course if you are trying sync your data from cache to the permanent storage before doing a proper shutdown, then it makes sense. 3 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 6, 2022 Share December 6, 2022 Maybe you want to check with solar installer. They may have energy solution for you. The only 1 know is Tesla Powerwall. For large power, Anker Singapore might have 1,300. IF not, https://www.goalzero.com.sg/collections/portable-power-stations/products/yeti-1500x-portable-power-station Goal Zero has up to 6,000 3 Link to post Share on other sites More sharing options...
Soya Supersonic December 6, 2022 Share December 6, 2022 11 hours ago, Ct3833 said: You do bitcoin mining ? He dun want any disruption while watching Jap AV cannot meh? 10 Link to post Share on other sites More sharing options...
RadX Moderator December 6, 2022 Share December 6, 2022 11 hours ago, Tianmo said: Anyone of you set up a home power back up? Can share what UPS you are using and/or what other power back up you using. Comments and feed backs on the pro and cons will be good. I am looking to set up something to back up power for my computer systems, including all the wireless system, so that can still operate for a while when there is a power failure or trip. Also looking to get a 600w to 1200w power bank for standby power. Any recommendations? Shift house stay next to sgh and tap their substation 😂 8 Link to post Share on other sites More sharing options...
Ender Hypersonic December 6, 2022 Share December 6, 2022 You need 24 hour security surveillance? 1 Link to post Share on other sites More sharing options...
Tkseah Turbocharged December 6, 2022 Share December 6, 2022 Maybe got too much money dunno where to spend... 😆 4 Link to post Share on other sites More sharing options...
RadX Moderator December 6, 2022 Share December 6, 2022 i suspect he keeping dead bodies...so need 24/7 sub zero temp..or @Tohto tenant der 10 Link to post Share on other sites More sharing options...
kermitfm 4th Gear December 6, 2022 Share December 6, 2022 UPS is designed to work for a short period only for the purpose of (a) providing interruption free power to critical systems during very short power outages (<30 minute) or (b) providing a controlled shutdown in the event of longer power outages. For key installations which require longer power backup, the backup will be supplemented by alternate power source like generators for extended outages. Depending on your need, a 15 mins - 30 mins UPS should suffice. It would be good to have UPS app on the computer to detect the power outage and initiate a controlled backup and shutdown after X minutes of power unavailability. Have a look at some of the more popular UPS available (e.g. APC, Eaton) for home/general use to familiar yourself with the specs and features of the wide range of UPS available. 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 6, 2022 Share December 6, 2022 12 minutes ago, kermitfm said: UPS is designed to work for a short period only for the purpose of (a) providing interruption free power to critical systems during very short power outages (<30 minute) or (b) providing a controlled shutdown in the event of longer power outages. For key installations which require longer power backup, the backup will be supplemented by alternate power source like generators for extended outages. Depending on your need, a 15 mins - 30 mins UPS should suffice. It would be good to have UPS app on the computer to detect the power outage and initiate a controlled backup and shutdown after X minutes of power unavailability. Have a look at some of the more popular UPS available (e.g. APC, Eaton) for home/general use to familiar yourself with the specs and features of the wide range of UPS available. Buy a laptop. 🤣 1 4 Link to post Share on other sites More sharing options...
RadX Moderator December 6, 2022 Share December 6, 2022 2 minutes ago, Mkl22 said: Buy a laptop. 🤣 be careful as this is his version of lapTOP 10 Link to post Share on other sites More sharing options...
BanCoe Hypersonic December 6, 2022 Share December 6, 2022 I give you healthier choice ……. 9 Link to post Share on other sites More sharing options...
Mustank Hypersonic December 6, 2022 Share December 6, 2022 5 Link to post Share on other sites More sharing options...
Tianmo Hypersonic December 6, 2022 Author Share December 6, 2022 KNN, I dont know what to say. Joker never taken seriously, and Jokers never take it seriously. 7 Link to post Share on other sites More sharing options...
RadX Moderator December 6, 2022 Share December 6, 2022 3 minutes ago, Tianmo said: KNN, I dont know what to say. Joker never taken seriously, and Jokers never take it seriously. U shd know la😁😁 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Audiophile home headphone system
Simple home DIY repairs
Home Aircon
Home Aircon
Home repair advice needed
Reverse/backup camera with dashcam recording function
Carbonics Cold Air Intake System - Full Handmake CF
Help needed on backup for my Mac - DAS, NAS and other solutions
Home renovation tips
