Lala81 Hypersonic September 22, 2020 Share September 22, 2020 (edited) Hi guys. Our home handyman adventures are sorta scattered all round the place in different threads. Maybe can lump here under something like makan thread. Don't think this belongs to plumber thread. So I start this off. My 555 ss water container. The lid handle fell off. Would an epoxy work? Any recommended brands? Funny thing is if it's epoxyed on originally. How come got that 3 contact points? Edited September 22, 2020 by Lala81 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Twister 5th Gear September 22, 2020 Share September 22, 2020 Those should be spot welding mark. Not expoxy. You can try Selley or Loctite Metal epoxy. Personally never try before.. 🤓 3 Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 22, 2020 Share September 22, 2020 I tried superglue and it worked. But after few times of usage, the heat got onto it and came off. 2 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 22, 2020 Share September 22, 2020 Yeah, looks like a spot weld. Not easy to fix for home diyers. I had one cheap Ikea pot handle broke off. It was also spot weld. I managed to drill a hole and put a screw/nut through. Although it's flimsy now, the handle tends to twist. If you want to epoxy, you can try those 5-min. 2-part type. But the problem is you need to find some sort of clamp to hold the parts together, and let it dry and cured for 24 hours. Then it will be rock solid and won't come off. 3 Link to post Share on other sites More sharing options...
peasant 5th Gear September 22, 2020 Share September 22, 2020 from google Food Grade Adhesives by Permabond Permabond food grade adhesives cure to a rigid solid which is non-porous for ease of cleaning, and are FDA compliant to FDA CFR 175.105 & 175.300. These epoxy adhesives offer excellent resistance to water, food, cleaning fluids and heat. i never use it before, if cannot work, dont blame me blame google 😀 1 2 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 22, 2020 Share September 22, 2020 Looks like spot weld. Best way is drill a hole through and secure with a screw. If want use 2 part epoxy, use a punch and make a few dents on both surfaces and sand the surfaces as well before applying the epoxy. But personally I wun bother with adhesive unless you are looking at temporary fix. 4 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 22, 2020 Share September 22, 2020 1 hour ago, Lala81 said: Hi guys. Our home handyman adventures are sorta scattered all round the place in different threads. Maybe can lump here under something like makan thread. Don't think this belongs to plumber thread. So I start this off. My 555 ss water container. The lid handle fell off. Would an epoxy work? Any recommended brands? Funny thing is if it's epoxyed on originally. How come got that 3 contact points? Hmmmm ....... I thought you are doing what I am about to do, rewire my home. Beside changing all the wire, also add IoT then connect to Amazon Cloud or Azure with telemetry electricity and water usage. Maybe a safe place for charging Li of phone and notebook. Anyway, I also do inspection of pots and pans periodically, like handle of pot with spot welding tends to break......Just image you are carrying a pot of hot soup and the handle GIVE WAY ...... don't know how many degree burn ...... NOT University Degree hor. So spot welding best ...... I don't agree to use epoxy or kum ..... like cannot leh. I generally throw ...... 555 is good, but I will throw. I use Zebra one ..... 2 Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 22, 2020 Share September 22, 2020 10 minutes ago, Apple-Tree said: Hmmmm ....... I thought you are doing what I am about to do, rewire my home. Beside changing all the wire, also add IoT then connect to Amazon Cloud or Azure with telemetry electricity and water usage. Maybe a safe place for charging Li of phone and notebook. Anyway, I also do inspection of pots and pans periodically, like handle of pot with spot welding tends to break......Just image you are carrying a pot of hot soup and the handle GIVE WAY ...... don't know how many degree burn ...... NOT University Degree hor. So spot welding best ...... I don't agree to use epoxy or kum ..... like cannot leh. I generally throw ...... 555 is good, but I will throw. I use Zebra one ..... Zebra quality is significantly better than 555. Now there are cheaper and worse off China brands, so 555 (itself an old China brand) seems like good stuff now. 2 1 Link to post Share on other sites More sharing options...
Ender Hypersonic September 22, 2020 Share September 22, 2020 Can use your new cordless drill to drill a hole thru the spot weld area. And a smaller hole suitable for the size of a self tapping wood screw on the handle. Your handle is plastic right? Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 22, 2020 Author Share September 22, 2020 5 hours ago, Ender said: Can use your new cordless drill to drill a hole thru the spot weld area. And a smaller hole suitable for the size of a self tapping wood screw on the handle. Your handle is plastic right? I have two. The one that isn't broken is plastic. This one is metal. Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 22, 2020 Author Share September 22, 2020 6 hours ago, Ender said: Can use your new cordless drill to drill a hole thru the spot weld area. And a smaller hole suitable for the size of a self tapping wood screw on the handle. Your handle is plastic right? Hmm I guess can consider. Will look into it. Link to post Share on other sites More sharing options...
Lala81 Hypersonic September 22, 2020 Author Share September 22, 2020 9 hours ago, Apple-Tree said: Hmmmm ....... I thought you are doing what I am about to do, rewire my home. Beside changing all the wire, also add IoT then connect to Amazon Cloud or Azure with telemetry electricity and water usage. Maybe a safe place for charging Li of phone and notebook You going to get WiFi sockets/switches for your lights?Otherwise not much point for electrical outlets. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 23, 2020 Share September 23, 2020 39 minutes ago, Lala81 said: Hmm I guess can consider. Will look into it. Ensure it's stainless screws..... 2 Link to post Share on other sites More sharing options...
Windwaver Turbocharged September 23, 2020 Share September 23, 2020 10 hours ago, Stratovarius said: Looks like spot weld. Best way is drill a hole through and secure with a screw. If want use 2 part epoxy, use a punch and make a few dents on both surfaces and sand the surfaces as well before applying the epoxy. But personally I wun bother with adhesive unless you are looking at temporary fix. Must use stainless steel screws, if not, rust will be part of your meal in time to come. 3 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 23, 2020 Share September 23, 2020 45 minutes ago, Lala81 said: Hmm I guess can consider. Will look into it. You need drill bit for metal. Don't just use any drill bit you have. The typical common drill bits are for concrete (arrow head) or wood 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 23, 2020 Share September 23, 2020 11 hours ago, Lala81 said: Hi guys. Our home handyman adventures are sorta scattered all round the place in different threads. Maybe can lump here under something like makan thread. Don't think this belongs to plumber thread. So I start this off. My 555 ss water container. The lid handle fell off. Would an epoxy work? Any recommended brands? Funny thing is if it's epoxyed on originally. How come got that 3 contact points? Can use epoxy! https://www.hunker.com/12613838/how-to-bond-metal-to-metal-without-soldering 1 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 23, 2020 Share September 23, 2020 my suggestion is to buy a new bakelite pot handle with stainless steel screw. drill a hole in the cover and put it on. forget about epoxy, wont last. 1 2 Link to post Share on other sites More sharing options...
Jman888 Moderator September 23, 2020 Share September 23, 2020 this one can? sorry i am not a handyman ↡ Advertisement 1 3 Link to post Share on other sites More sharing options...
Home repair advice needed
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
