BanCoe Hypersonic March 27, 2021 Share March 27, 2021 33 minutes ago, Didu said: I have a couple of DC ceiling fans at home. Although not Fanco, but neither of them do like what you said. I suggest if you pass by any appliance store that sells Fanco, have the sales turn it on for you to see if they do the same thing. I have the video clip ...... I’ll send it to the agent to check it and if required ask them to arrange checking ↡ Advertisement 3 Link to post Share on other sites More sharing options...
BanCoe Hypersonic March 27, 2021 Share March 27, 2021 17 minutes ago, Jamesc said: I offer $200. I need a fan for my MIL's room. Your MIL not cheapo ..... she uses only AirCon 🥶........... that’s why she is so cool but cold to you 🤨 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 27, 2021 Share March 27, 2021 (edited) 1 hour ago, BanCoe said: Reviving the old thread........ Got this Fanco brand DC ceiling fan to replace my old trusty Liberty ( i think made in USA back then - served me well for 25 years ) but the blades cracked What I find strange is the fan first like rotates slightly counter clockwise for about 1-2 seconds like a jerk and then jerks again (like go ahead gostan) and will finally spin normal as expected Is this the way this fans work ?? Yes my fanco DC fan rotates backward slightly before spinning off as well. But i have another brand of DC fan does not have this behavior. Edited March 27, 2021 by Ct3833 3 Link to post Share on other sites More sharing options...
Kxbc Turbocharged March 27, 2021 Share March 27, 2021 My acorn DC fan does the same. Like that since day 1. Used for more than 1.5 years. Going strong. My other kdk fans (think not DC) do not do the same as the DC. But due to design issues, some plastic parts are creating noise. Will change to acorn if the kdk dies. 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic March 27, 2021 Share March 27, 2021 Ok managed to get the video ....... is yours like this @Ct3833 and @Kxbc?? IMG_4055.MP4 Link to post Share on other sites More sharing options...
Kb27 Supersonic March 28, 2021 Share March 28, 2021 Seems like there's some kind of electronic problem with pcb. DC fan shouldn't do that. They are spun by a rotating magnetic field generated by the pcb. Perhaps some components inside is not working properly and cause a temporary reverse in field starting up. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 28, 2021 Share March 28, 2021 (edited) 9 hours ago, BanCoe said: Ok managed to get the video ....... is yours like this @Ct3833 and @Kxbc?? IMG_4055.MP4 Hi, quite similar characteristics. Movie 2.mp4 Edited March 28, 2021 by Ct3833 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 28, 2021 Share March 28, 2021 8 hours ago, BanCoe said: Ok managed to get the video ....... is yours like this @Ct3833 and @Kxbc?? IMG_4055.MP4 Just don’t look up when you turn on the fan can liao. 😁 As long as it worked fine after that. 🤣 3 Link to post Share on other sites More sharing options...
BanCoe Hypersonic March 28, 2021 Share March 28, 2021 3 hours ago, Ct3833 said: Hi, quite similar characteristics. Movie 2.mp4 What make / brand was this ?? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic March 28, 2021 Share March 28, 2021 This might explain why the fan gostan first then goes forward.... 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 28, 2021 Share March 28, 2021 5 hours ago, Fcw75 said: Just don’t look up when you turn on the fan can liao. 😁 As long as it worked fine after that. 🤣 looks weird to me. Kan bu shun yan... 2 Link to post Share on other sites More sharing options...
Kxbc Turbocharged March 28, 2021 Share March 28, 2021 Mine has same movement pattern as ct3833's. Only difference is that the backward movement is less. Link to post Share on other sites More sharing options...
Ct3833 Supersonic March 28, 2021 Share March 28, 2021 (edited) 3 hours ago, BanCoe said: What make / brand was this ?? It is Jantec, I checked another DC fan out, it does not have this behavior. Anyway this one has been working, it didnt bother me. I still have many AC fans, wanted to replace them all to DC but have been procrastinating because of the $ involved. 😂 Edited March 28, 2021 by Ct3833 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 28, 2021 Share March 28, 2021 35 minutes ago, Ct3833 said: It is Jantec, I checked another DC fan out, it does not have this behavior. Anyway this one has been working, it didnt bother me. I still have many AC fans, wanted to replace them all to DC but have been procrastinating because of the $ involved. 😂 Well if the ac fan is working fine. Leave it. Unless backside itchy. Double you see much power savings by replacing. 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 28, 2021 Share March 28, 2021 (edited) 2 hours ago, Ct3833 said: It is Jantec, I checked another DC fan out, it does not have this behavior. Anyway this one has been working, it didnt bother me. I still have many AC fans, wanted to replace them all to DC but have been procrastinating because of the $ involved. 😂 why would u change unless it spoils? Minimal benefit. It's not like u switching on every fan for 16 hrs a day. Yours quite long lived. I haven't even heard of people buying AC fans for the last 10 years. Unless it's like for commerical purposes. Edited March 28, 2021 by Lala81 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic March 28, 2021 Share March 28, 2021 2 hours ago, Kxbc said: Mine has same movement pattern as ct3833's. Only difference is that the backward movement is less. Macam a high jumper...lean a bit backward then chiong towards the cross bar...😁 1 Link to post Share on other sites More sharing options...
Count_duku 4th Gear March 28, 2021 Share March 28, 2021 (edited) On 3/27/2021 at 8:22 PM, BanCoe said: Reviving the old thread........ Got this Fanco brand DC ceiling fan to replace my old trusty Liberty ( i think made in USA back then - served me well for 25 years ) but the blades cracked What I find strange is the fan first like rotates slightly counter clockwise for about 1-2 seconds like a jerk and then jerks again (like go ahead gostan) and will finally spin normal as expected Is this the way this fans work ?? I also bought a Fanco recently, like the design. It has the same behavior and works well after the initial startup. Strangely it has the forward/ reverse button on the remote control, though I don’t think I will ever want it to blow in the reverse direction. Edited March 28, 2021 by Count_duku Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 28, 2021 Share March 28, 2021 11 minutes ago, Count_duku said: I also bought a Fanco recently, like the design. It has the same behavior and works well after the initial startup. Strangely it has the forward/ reverse button on the remote control, though I don’t think I will ever want it to blow in the reverse direction. More for when you have the Aircon on and want to circulate the cold air but without the direct draft of the cold air blow down from the fan. ↡ Advertisement Link to post Share on other sites More sharing options...
JEM/Westgate ceiling collapse!
Toilet ceiling leaking
Mold/Fungus on the ceiling
Buying Ceiling fan and lighting from JB
Ceiling Fan in Car
Ceiling Fan in Car
Small little tiny bug on walls & ceiling
Help: ceiling n wall cracks are leaking water
