Lala81 Hypersonic November 21, 2023 Author Share November 21, 2023 On 11/21/2023 at 3:56 PM, Kb27 said: Front load has less problem with water scum. The black stuff, I understand is bcuz of softener interacting with the detergent. But I can't stop my wife from using softener. Softener can be replaced by vinegar, I read. I don't use softener. Not really required in our tropical environment. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2023 Share December 11, 2023 (edited) For DIY guys, don't pass up this offer for $15 only for a good quality deWALT set, limited time only https://www.amazon.sg/dp/B00C1XZITM Edited December 11, 2023 by Kb27 8 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 6:44 PM, Kb27 said: For DIY guys, don't pass up this offer for $15 only for a good quality deWALT set, limited time only https://www.amazon.sg/dp/B00C1XZITM Any recommendations for good masonry drill bit? Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 6:44 PM, Kb27 said: For DIY guys, don't pass up this offer for $15 only for a good quality deWALT set, limited time only https://www.amazon.sg/dp/B00C1XZITM Thanks but 1/3 of the bits are useless square ones which I have never come across ever. Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 7:08 PM, mersaylee said: Any recommendations for good masonry drill bit? I use Irwin. So far ok. But I diy so don’t drill that many holes anyway. If it’s a normal non sds, then I say forget it. Just buy a sds rotary hammer with bit and punch holes easily. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 7:20 PM, Mkl22 said: Thanks but 1/3 of the bits are useless square ones which I have never come across ever. SQ bits are mostly for woodworking. I used this pocket screw bcuz it's versatile, has a wide head, self drilling, half thread to pull 2 pieces of wood together. https://www.amazon.sg/SML-C125-100-Pocket-Screws-Maxi-Loc-100/dp/B0000DD5H1/ 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 7:08 PM, mersaylee said: Any recommendations for good masonry drill bit? I just bought a few from Horme. It's Makita SDS bits, bcuz I need to make a big hole in the wall. https://www.horme.com.sg/product.aspx?id=10945 You can buy a set from Makita, it's durable and quite cheap. https://shopee.sg/-SG-Stock-Makita-5-Pcs-Japan-SDS-PLUS-Drill-Bit-Set-D-00795-D-17784-i.3890606.306713998 3 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 7:20 PM, Mkl22 said: Thanks but 1/3 of the bits are useless square ones which I have never come across ever. Yeah, I have a cheap set with triangle bits. At least those screws I have seen and used the bits before. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2023 Share December 11, 2023 On 12/11/2023 at 8:12 PM, Volvobrick said: Yeah, I have a cheap set with triangle bits. At least those screws I have seen and used the bits before. I just took out 2 triangle screws. The only thing to do, is to throw them away and replaced with normal phillips head. Otherwise, you might regret the next time you want to take them out again, and this time you can't find the correct tool. These triangle heads are for anti-tampering and serve no other purposes. 1 Link to post Share on other sites More sharing options...
Se3h3ng 2nd Gear December 11, 2023 Share December 11, 2023 Any idea where can i get these? Its for shelf support… tried buying for those hardware stores under block but they dont have. Shoppee itself sell in a bundle of 20 pieces and needs to wait for shipping… Link to post Share on other sites More sharing options...
Kb27 Supersonic December 13, 2023 Share December 13, 2023 Another deal with Amazon, $9.19, regular price is $30, Bosch drill bit set, for impact drivers, imperial size. https://www.amazon.sg/gp/product/B01H0NV5GM/ 1 Link to post Share on other sites More sharing options...
Ender Hypersonic December 15, 2023 Share December 15, 2023 LOL.. 🤣 2 4 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 20, 2023 Share December 20, 2023 (edited) If you were using the same screwdriver for normal everyday usage; and decided to use it for electrical work, the long metallic shank is a potential disaster. I had accidentally short circuited the AC supply due to a socket electrical contacts being placed very closed together. It's my fault for not being careful enough to a use a proper insulated screwdriver. But I think just heat-shrinking the shank will save the trouble. The cost is only a few cents. You can also choose your own colour scheme of the heat-shrink tube to denote the driver head for easy identification. Here, I decide to use green for PH2. The unshrunk tube diameter is 8mm, just nice for this screwdriver. Edited December 20, 2023 by Kb27 5 Link to post Share on other sites More sharing options...
Ender Hypersonic December 20, 2023 Share December 20, 2023 On 12/16/2023 at 2:26 AM, Ender said: LOL.. 🤣 NExt time if you buy luxury furniture from taobao, you might want to check what's underneath. 😅 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 21, 2023 Share December 21, 2023 Got a small strip of unused real estate on the wall. I was able to hang up a 30x100cm pegboard. So can organize and store more stuff. At the top of the board, I install an additional blue tapcon (concrete screw) for extra holding power. This was easy over the top drilling and direct insert the screw without having to remove the board to put wall plug. That's the advantage of tapcon. 4 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 21, 2023 Author Share December 21, 2023 On 12/21/2023 at 9:54 AM, Kb27 said: Got a small strip of unused real estate on the wall. I was able to hang up a 30x100cm pegboard. So can organize and store more stuff. At the top of the board, I install an additional blue tapcon (concrete screw) for extra holding power. This was easy over the top drilling and direct insert the screw without having to remove the board to put wall plug. That's the advantage of tapcon. hah in singapore, they use it to hang kids toys Link to post Share on other sites More sharing options...
Kb27 Supersonic December 21, 2023 Share December 21, 2023 On 12/21/2023 at 10:14 AM, Lala81 said: hah in singapore, they use it to hang kids toys pegboard is quite useful. can hang all kinds of stuff. 😁 Link to post Share on other sites More sharing options...
Tianmo Hypersonic December 21, 2023 Share December 21, 2023 On 12/20/2023 at 9:09 AM, Ender said: NExt time if you buy luxury furniture from taobao, you might want to check what's underneath. 😅 I am thinking, if I pass him a bench, can he transform it into a 5 stars sofa for me. ↡ Advertisement 1 2 Link to post Share on other sites More sharing options...
Audiophile home headphone system
Home Aircon
Home Aircon
Home repair advice needed
Home renovation tips
