Kb27 Supersonic April 4, 2024 Share April 4, 2024 On 4/4/2024 at 3:58 PM, Ct3833 said: A roller of my folding door is badly damaged, i could not even lossen the nut because the screw is bent and damaged, i intend to saw it off. Any other better way of removing it ? An oscillating multi-tool with carbide blade ? ↡ Advertisement 2 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 4, 2024 Share April 4, 2024 On 4/4/2024 at 5:36 PM, Kb27 said: An oscillating multi-tool with carbide blade ? too high tech for me, i am a hammer and hand saw guy. Finally took it out. Now have to go buy a compatible one. 5 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic April 4, 2024 Share April 4, 2024 (edited) On 4/4/2024 at 6:43 PM, Ct3833 said: too high tech for me, i am a hammer and hand saw guy. Finally took it out. Now have to go buy a compatible one. A hack saw! Now that's something I don't have. But I have electric saw. PS I have a folding door also roller bolt bent but still can slide. Let you finish your job first ie whether you can get the roller back in before I decide to replace or not.... Edited April 4, 2024 by Volvobrick Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 4, 2024 Share April 4, 2024 On 4/4/2024 at 6:45 PM, Volvobrick said: A hack saw! Now that's something I don't have. But I have electric saw. PS I have a folding door also roller bolt bent but still can slide. Let you finish your job first ie whether you can get the roller back in before I decide to replace or not.... After the brute force sawing...😂 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 6, 2024 Share April 6, 2024 (edited) On 4/4/2024 at 6:45 PM, Volvobrick said: A hack saw! Now that's something I don't have. But I have electric saw. PS I have a folding door also roller bolt bent but still can slide. Let you finish your job first ie whether you can get the roller back in before I decide to replace or not.... You are another high tech lah. Now i have a problem, i am unable to insert the new wheel into the track unless i dismantle both side of the folding doors before i could remove the track to insert the wheel, the doors are big and heavy, quite sian. Edited April 6, 2024 by Ct3833 2 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 8, 2024 Share May 8, 2024 (edited) On 4/4/2024 at 6:45 PM, Volvobrick said: A hack saw! Now that's something I don't have. But I have electric saw. PS I have a folding door also roller bolt bent but still can slide. Let you finish your job first ie whether you can get the roller back in before I decide to replace or not.... Bro, i gave up, called in a handyman, he got his worker to help him, i suspect he is moonlighting but that did not bother me. what they did was they used two steel rods to pry open the track , insert the new wheel before clamping back the track to near original shap again. Damage is $250 Edited May 8, 2024 by Ct3833 6 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged May 8, 2024 Share May 8, 2024 On 4/6/2024 at 10:45 AM, Ct3833 said: You are another high tech lah. Now i have a problem, i am unable to insert the new wheel into the track unless i dismantle both side of the folding doors before i could remove the track to insert the wheel, the doors are big and heavy, quite sian. In situation like this, mcf advice is to change house. 🤣 250 is on the high end for me. But at least your problem is solved. 9 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 6:22 PM, Ct3833 said: Bro, i gave up, called in a handyman, he got his worker to help him, i suspect he is moonlighting but that did not bother me. what they did was they used two steel rods to pry open the track , insert the new wheel before clamping back the track to near original shap again. Damage is $250 OK I may be able to save 250 now I know how to do it.... 😆 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 4:41 PM, Stratovarius said: In situation like this, mcf advice is to change house. 🤣 250 is on the high end for me. But at least your problem is solved. Is it $250 for landed, $200 for condo and $150 for HDB? 🤣 5 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 8, 2024 Share May 8, 2024 (edited) On 5/8/2024 at 7:11 PM, Stratovarius said: In situation like this, mcf advice is to change house. 🤣 250 is on the high end for me. But at least your problem is solved. Never say never, who knows after tomorrow i can afford to change house 😁 Edited May 8, 2024 by Ct3833 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 7:13 PM, Volvobrick said: OK I may be able to save 250 now I know how to do it.... 😆 Good luck. Let me know you manage to do it, i will 拜你为师 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 7:23 PM, Mkl22 said: Is it $250 for landed, $200 for condo and $150 for HDB? 🤣 Next time when they ask me for address, i will say i drive COE car😰 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 7:50 PM, Ct3833 said: Next time when they ask me for address, i will say i drive COE car😰 It doesn’t matter. Got Land => Rich 3 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 8, 2024 Share May 8, 2024 On 5/8/2024 at 7:49 PM, Ct3833 said: Good luck. Let me know you manage to do it, i will 拜你为师 I just cemented back some tiles that popped out. Tomorrow will see if they stick! 2 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 25, 2024 Author Share May 25, 2024 Respect 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 25, 2024 Share May 25, 2024 On 5/8/2024 at 8:18 PM, Volvobrick said: I just cemented back some tiles that popped out. Tomorrow will see if they stick! So far how is it ? 😅 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 25, 2024 Share May 25, 2024 On 5/25/2024 at 12:30 PM, Ct3833 said: So far how is it ? 😅 Well cemented! Put on some plaster to slope the edge and painted over the plaster. A bit ugly but it's at one corner. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 25, 2024 Share May 25, 2024 On 5/25/2024 at 10:59 AM, Lala81 said: Respect But why? 🤔 ↡ Advertisement Link to post Share on other sites More sharing options...
Home repair advice needed
Home Aircon
Home Aircon
Home renovation tips
Wheel Spacer Installation DIY
